Check List For Fencing and Gates Work
Check List For Fencing and Gates consist of following points;
  1. Approved Drawing whether available?
  2. Layout done / Checked
  3. Material
    • Approved Make
    • Type
    • Size
  4. Location of Erection
  5. Size of the Gate or Fencing
  6. Fabrication Details
    • Jointing Details
    • Grinding of Welded Joints
    • Provisions for Electrical Fittings
    • Sleeve for the Cable
    • Locking Arrangements
    • Easily Operational
  7. Painting
    • Application of Primer
    • First Coat of Paint
    • Second Coat of Paint
  8. Cleaning
  9. Adequate precautions against Pilferage
Kindly use it as reference document only to create Checklist. You are free to modify edit, delete add any content in it and use it as per your requirement. find enclosed herewith the detailed check list for fencing and gates work.
  • Checklist for fencing and gates.doc
