Check List For Plumbing Works (Concealed Water Line in Toilets)
Check List For Concealed Toilet Plumbing Works consist of following points;
  1. Chasing in Walls
  2. Laying of Pipe in Position
    • Diameter of Domestic Line
    • Diameter of Flush Line
  3. No. of Points and It’s Position
  4. Layout checked w.r.t
  5. Tile Layout
  6. Pressure Testing
  7. Anti-Corrosive treatment to pipes
  8. Concealing of Pipe and Date
Check list is a important record it helps us in order to get work done correctly and it ensure we do not miss any point to check which is important from aspect of Quality of work.
Kindly use it as reference document only to create Checklist. You are free to modify edit, delete add any content in it and use it as per your requirement. find enclosed herewith the detailed Check List For Plumbing Works (Concealed Water Line in Toilets)
  • Check List For Concealed Toilet Plumbing.doc
Reactions: ShrikantGupta
