Check List For Plumbing Works (Internal Drainage)
Check List For Plumbing Works (Internal Drainage) consist of following points;
  • Diameter of Soil /Waste Pipe
  • Materials of Pipe
  • Make of Pipe
  • All fittings & Clean outs
  • Slopes
  • Outlet position / Finishing around Openings
  • Testing of Pipe
  • All Outlets covered
  • Approved for Waterproofing
Kindly use it as reference document only to create Checklist. You are free to modify edit, delete add any content in it and use it as per your requirement. find enclosed herewith the detailed check list for Check List For Plumbing Works (Internal Drainage)
  • Check List For Plumbing Works _Internal Drainage_.doc
