Checklist for External Painting Works
Checklist for External Painting Works consist of following points;
  1. Material
    • Approved Make
    • Type
    • Shade
  2. Erection of Scaffold
  3. Preparation of surface (Thoroughly cleaned & dusted off) as per manufacturers specification
  4. All openings/ Cracks filled in with approved material & method
  5. Surface ready for Painting / not (Y/N)
  6. Preparation of paints (Thinning of paints) as per manufacturers specification (Write proportions in Remarks)
  7. Application of Priming Coat
  8. Curing of the Priming Coat
  9. Application of First Coat of Paint
  10. Application of Second Coat of Paint after complete drying of first coat
  11. Coverage (Area painted / Volume of paints) (Sq.ft / ltr) as per manufacturer specification.
  12. Desired Finishing of Paints as per specification
  13. Additional Coat, if desired finish not achieved / as instructed by Engineer In-charge
  14. Dismantling of Scaffold
    • Removing of Covers for Windows
    • Floors
checklist is a important record it helps us in order to get work done correctly and it ensure we do not miss any point to check which is important from aspect of Quality of work.
Kindly use it as reference document only to create Checklist. You are free to modify edit, delete add any content in it and use it as per your requirement. find enclosed herewith the detailed check list for external panting work
i need work method statment of various activity such as a plumbing , door fixing , window fixing , toilet waterproofing , floooring , dado fixing , kitchen otta fixing , gypsum plaster .
