Checklist for Fabrication Structural Steel Works
1 Use Specified Materials
a) Grade of Steel
b) Surface Treatment
c) Size of Steel Members
d) Square ness At Right Angles
e) Defect Free
2 Provide Structural Openings With Allowance As Per Approved Shop Drawing
3 Provide Anchorage As Per Shop Drawing
4 Joining Method Specified
a) Welding
Type of Electrode
Weld Size
Slag / Inclusion Free
Qualified Welders
b) Bolting
Bolt Size and Type
Holes Drilled And Cut
Thread Through Nut
Tighten With Wrench
5 Finish Steel Work With
a) Layout According To Drawing
b) Plumb / Levels / Lines Within Tolerance
c) Join Material And details
d) Defect Free
e) Touch Up Priming
6 Grout Base Frames or Cast in Frames
7 Seal Gaps At Frame / Wall
8 Fire Rated Doors Inspected
9 Provide Coating
a) Paint
b) Fire Rated
Kindly use it as reference document only to create Checklist. You are free to modify edit, delete add any content in it and use it as per your requirement. find enclosed herewith the detailed Checklist for Fabrication Structural Steel Works
  • Checklist for Fabrication Structural Steel Works.doc
