Checklist for fixing the door sub frame
Checklist should consist of following points;
- Hacking of all R.C.C surfaces before fixing frames.
- Check dimension of frame and opening size as per drawing
- Check wood section as per drawing
- Check wood type as per specification
- Check wood frame is anti-termite treated.
- Check for cracks,knots in frames
- Check for planing of wood
- Check for moisture content of wood as per permissiable limit
- Check for black Japan/ coal tar applied on frame facing wall surface
- Check for plumb of frame
- Check for holdfast fixed as per specification
- Check for holdfast is grouted as per specification.
- Check for plumb of frame after fixing.
- Check wood primer applied after fixing
