Checklist for Internal Painting Works
Checklist for internal painting works consist of following points;
checklist is a important record it helps us in order to get work done correctly and it ensure we do not miss any point to check which is important from aspect of Quality of work.
Kindly use it as reference document only to create Checklist. You are free to modify edit, delete add any content in it and use it as per your requirement. find enclosed herewith the detailed check list for internal panting work
- Material
- Approved Make
- Type
- Shade
- Surface Prepared
- Preparation of Paints & primer
- Hardware installed are covered
- Application of Primer
- Application of Putty
- Scrapping and Application of Primer
- Application of First Coat of Paint
- Application of Second Coat of Paint
- Application of Third Coat of Paint
- Cleaning
- Hardware Fittings
- Removing of Covers
- Floors
- Windows, Glass, Pipes etc.
- Surface Finish
- Coverage/Reconciliation of coverage
