Comparison of steel schedule new and old schedule different ?
Hello All,
i have Two steel scheduls and i need Compare the both steel schedule and need to find the different new and old steels ? is there any programmed Excels ?
I did not understood your question and what you are trying to achieve with it.
Comparing 2 schedules for what? the revision is done only in cases where structural consultant do find some flaws in design or their is some changes did happen in final structure for which he did design.
Even in case where you would like to do compare, nothing will help you because you need to compare both schedule side by side and understand what are the changes done and in which sections of the structure.
If you have something on your mind which is different from what i written kindly do post more about what exactly you are looking for and stop watching Youtube as its create such kind of confusion on mind.
