concrete design mix calculations
dear all
find enclosed herewith the detailed design mix calculations for concrete grade m15 to m60. this can be treated as an out lay only. the design mix shall be designed according to your site condition and material availability. it is purely an example of how to do the calculation for various grade of concrete mix
rgards
srinivasan
  • concrete mix design working.xls
no doubt. for a lean concrete you can use m15 as a nominal mix.as on today we are using manufactured sand in concrete it is advisable to do a design mix for any sort of concrete to ensure the durability and quality of concrete.to do a design mix at site you are not wasting any time and money.in that case why can't to do a concrete with design mix which gives stability quality and save your money
