Concrete Mix Design for M10 grade
Concrete Mix Design for M10 grade of concrete
M10 is lean mix concrete and can be used in any nonstructural work.
Mostly use for PCC Works
Concrete mix Design for M10 Grade concrete with pure PPC cement only is as follows;
PPC Cement 53 Grade – 220 Kg
Water Cement ratio (w/c) – 0.6
Free Water – 132 liters
20mm Metal / Aggregates – 666 Kg
10mm Metal / Aggregates – 539 Kg
Crush Sand – 1038 Kg
Admixture Dosage – 0.6%
Admixture – 1.32 Kg
Density of Concrete – 2596 Kg/cum
  • M10 PPC.xlsx
Reactions: MAR
Concrete mix Design for M10 Grade concrete with fly ash is as follows;
OPC Cement 53 Grade – 176 Kg
Fly ash – 44 Kg
20mm Metal / Aggregates – 653 Kg
10mm Metal / Aggregates – 537 Kg
Crush Sand – 1047 Kg
Admixture – 1.32 Kg
Density of Concrete – 2590 Kg/cum
  • M10 with Fly ash.xlsx
Reactions: MAR
Concrete mix Design for M10 Grade concrete with GGBS is as follows;
OPC Cement 53 Grade – 100 Kg
GGBS – 120 Kg
Water Cement ratio (w/c) – 0.7
Free Water – 154 liters
20mm Metal / Aggregates – 710 Kg
10mm Metal / Aggregates – 468 Kg
Crush Sand – 1003 Kg
Admixture Dosage – 1 %
Admixture – 2.2 Kg
Density of Concrete – 2558 Kg/cum
  • M10 with GGBS.xlsx
Reactions: MAR
Concrete mix Design for M10 Grade concrete with GGBS for Pumping is as follows;
OPC Cement 53 Grade – 120 Kg
GGBS – 130 Kg
Free Water – 150 liters
20mm Metal / Aggregates – 795 Kg
10mm Metal / Aggregates – 354 Kg
Crush Sand – 1017 Kg
Admixture – 2.5 Kg
Density of Concrete – 2568 Kg/cum
  • M10 with GGBS for pumping.xlsx
Reactions: MAR
