Concrete Mix Design for M15 grade
Concrete Mix Design for M15 grade of concrete
M15 is most favorite grade of concrete for doing PCC works.
Concrete mix Design for M15 Grade concrete with fly ash is as follows;
OPC Cement 53 Grade – 224 Kg
Fly ash – 56 Kg
Water Cement ratio (w/c) – 0.55
Free Water – 154 liters
20mm Metal / Aggregates – 575 Kg
10mm Metal / Aggregates – 530 Kg
Crush Sand – 1033 Kg
Admixture Dosage – 0.6%
Admixture – 1.68 Kg
Density of Concrete – 2573 Kg/cum
  • M15 with Fly ash.xlsx
Reactions: MAR
MAR
Founder Member
Fly ash – 56 Kg
Admixture – 1.68 Kg
Excellent
