Concrete mix Design for M200 Grade concrete, a Triple Blend with Fly ash and Micro silica is as follows;
this is a sample mix did for doing trials and never used in actual construction as i never got opportunity to do it.
OPC Cement 53 Grade – 888 Kg
Fly ash – 118 Kg
Micro silica – 178 Kg
Water Cement ratio (w/c) – 0.2
Free Water – 236 liters
20mm Metal / Aggregates – 0 Kg
10mm Metal / Aggregates – 491 Kg
Crush Sand – Kg
River Sand – 492 Kg
Admixture Dosage – 1.2 %
Admixture – 14.2 Kg
Density of Concrete – 2419 Kg/cum
Fly ash – 118 Kg
Crush Sand – Kg
River Sand – 492 Kg
Admixture – 14.2 Kg
