Concrete Mix Design for M25 grade
Concrete mix Design for M25 Grade concrete with pure cement is as follows;
OPC Cement 53 Grade – 320 Kg
Water Cement ratio (w/c) – 0.47
Free Water – 150 liters
20mm Metal / Aggregates – 795 Kg
10mm Metal / Aggregates – 338 Kg
Crush Sand – 433 Kg
River Sand – 550 Kg
Admixture Dosage – 1 %
Admixture – 3.2 Kg
Density of Concrete – 2590 Kg/cum
  • M25 With Pure Cement.xlsx
Reactions: Mehboob and MAR
Concrete Mix Design for M25 Grade concrete with pure cement and crush sand is as follows;
OPC Cement 53 Grade – 340 Kg
Water Cement ratio (w/c) – 0.44
20mm Metal / Aggregates – 812 Kg
10mm Metal / Aggregates – 346 Kg
Crush Sand – 939 Kg
Admixture – 3.4 Kg
  • M25 With Pure Cement and crush sand.xlsx
Concrete Mix Design for M25 Grade concrete with GGBS is as follows;
OPC Cement 53 Grade – 260 Kg
GGBS – 80 Kg
20mm Metal / Aggregates – 784 Kg
10mm Metal / Aggregates – 347 Kg
Crush Sand – 959 Kg
Admixture Dosage – 1.2 %
Admixture – 4.08 Kg
Density of Concrete – 2584 Kg/cum
  • M25 With GGBS.xlsx
Reactions: Mehboob
MAR
Founder Member
Crush Sand – 433 Kg
River Sand – 550 Kg
Admixture – 3.2 Kg
Excellent
Reactions: Raju Padya
