Concrete Mix Design for M3.5 grade of concrete
M3.5 is very lean mix concrete and can be used in any nonstructural work.
Concrete mix Design for M3.5 Grade concrete is as follows;
OPC Cement 53 Grade – 140 Kg
Fly ash – 40 Kg
Water Cement ratio (w/c) – 0.9
Free Water – 162 liters
10mm Metal / Aggregates – 1008 Kg
Crush Sand – 1177 Kg
Admixture Dosage – 0.6%
Admixture – 1.08 Kg
Density of Concrete – 2528 Kg/cum
Fly ash – 40 Kg
Admixture – 1.08 Kg
