Concrete Mix Design for M30 grade for Road Works PQC
Concrete mix Design for M30 Grade concrete with pure OPC cement is as follows;
OPC Cement 53 Grade – 350 Kg
Water Cement ratio (w/c) – 0.43
Free Water – 150 liters
20mm Metal / Aggregates – 766 Kg
10mm Metal / Aggregates – 341 Kg
Crush Sand – 962 Kg
Admixture Dosage – 1.2 %
Admixture – 4.2 Kg
Density of Concrete – 2574 Kg/cum
  • M30 for concrete pavement.xlsx
