Concrete Mix Design for M30 grade for Self Compacting Concrete
Concrete mix Design for M30 Grade concrete with GGBS for self compacting application is as follows;
OPC Cement 53 Grade – 290 Kg
GGBS – 260 Kg
Water Cement ratio (w/c) – 0.31
Free Water – 170 liters
20mm Metal / Aggregates – 534 Kg
10mm Metal / Aggregates – 354 Kg
Crush Sand – 926 Kg
Admixture Dosage – 1.1 %
Admixture – 5.775 Kg
Density of Concrete – 2541 Kg/cum
  • M30 with GGBS Self Compacting Concrete.xlsx
MAR
Founder Member
GGBS – 260 Kg
Crush Sand – 926 Kg
Excellent
Reactions: bhupeshmulik
