Concrete Mix Design for M30 grade
Concrete mix Design for M30 Grade concrete with fly ash is as follows;
OPC Cement 53 Grade – 320 Kg
Fly ash – 80 Kg
Water Cement ratio (w/c) – 0.38
Free Water – 152 liters
20mm Metal / Aggregates – 464 Kg
10mm Metal / Aggregates – 442 Kg
Crush Sand – 739 Kg
River Sand – 362 Kg
Admixture Dosage – 0.8 %
Admixture – 3.2 Kg
Density of Concrete – 2562 Kg/cum
Fly ash – 80 Kg
Crush Sand – 739 Kg
River Sand – 362 Kg
Admixture – 3.2 Kg
