Concrete Mix Design for M35 Grade concrete with fly ash ans Surat Sand is as follows;
OPC Cement 53 Grade – 380 Kg
Fly ash – 130 Kg
Water Cement ratio (w/c) – 0.34
Free Water – 173 liters
20mm Metal / Aggregates – 585 Kg
10mm Metal / Aggregates – 388 Kg
Crush Sand – 301 Kg
Surat Sand – 559 Kg
Admixture Dosage – 1 %
Admixture – 5.1 Kg
Density of Concrete – 2522 Kg/cum
Fly ash – 130 Kg
Crush Sand – 301 Kg
Surat Sand – 559 Kg
Admixture – 5.1 Kg
