Concrete mix Design for M40 Grade concrete with fly ash for Pile Foundation is as follows;
OPC Cement 53 Grade – 430 Kg
Fly ash – 80 Kg
Water Cement ratio (w/c) – 0.32
Free Water – 163 liters
20mm Metal / Aggregates – 453 Kg
10mm Metal / Aggregates – 507 Kg
Crush Sand – 616 Kg
River Sand – 301 Kg
Admixture Dosage – 1.2 %
Admixture – 6.018 Kg
Density of Concrete – 2557 Kg/cum
Fly ash – 80 Kg
Crush Sand – 616 Kg
River Sand – 301 Kg
