Concrete Mix Design for M40 grade
Concrete mix Design for M40 Grade concrete with fly ash is as follows;
OPC Cement 53 Grade – 400 Kg
Fly ash – 80 Kg
Water Cement ratio (w/c) – 0.32
Free Water – 153 liters
20mm Metal / Aggregates – 524 Kg
10mm Metal / Aggregates – 483 Kg
Crush Sand – 980 Kg
Admixture Dosage – 0.9 %
Admixture – 4.32 Kg
Density of Concrete – 2625 Kg/cum
  • M40 with Fly ash.xlsx
Concrete mix Design for M40 Grade concrete with PPC Cement is as follows;
PPC Cement 53 Grade – 480 Kg
Water Cement ratio (w/c) – 0.33
Free Water – 158 liters
20mm Metal / Aggregates – 492 Kg
10mm Metal / Aggregates – 449 Kg
Crush Sand – 981 Kg
Admixture Dosage – 1 %
Admixture – 4.8 Kg
Density of Concrete – 2566 Kg/cum
  • M40 PPC.xlsx
