Concrete Mix Design for M45 grade
Concrete mix Design for M45 Grade concrete with GGBS is as follows;
OPC Cement 53 Grade – 300 Kg
GGBS – 200 Kg
Water Cement ratio (w/c) – 0.28
Free Water – 140 liters
20mm Metal / Aggregates – 620 Kg
10mm Metal / Aggregates – 450 Kg
Crush Sand – 894 Kg
Admixture Dosage – 1.1 %
Admixture – 5.5 Kg
Density of Concrete – 2609 Kg/cum
  • M45 with GGBS.xlsx
Reactions: Sumit Civil
