Concrete Mix Design for M5 grade of concrete
M5 is very lean mix concrete and can be used in any nonstructural work.
Concrete mix Design for M5 Grade concrete is as follows;
Cement – 150 Kg
Fly ash – 50 Kg
Water Cement ratio (w/c) – 0.8
Free Water – 160 liters
10mm Metal / Aggregates – 1000 Kg
Crush Sand – 1169 Kg
Admixture Dosage – 0.6%
Admixture – 1.02 Kg
Density of Concrete – 2530 Kg/cum
Cement – 150 Kg
Fly ash – 50 Kg
Admixture – 1.02 Kg
