Concrete mix Design for M55 Grade concrete, a Triple Blend with GGBS and Microsilica is as follows;
OPC Cement 53 Grade – 330 Kg
GGBS – 200 Kg
Micro silica – 30 Kg
Water Cement ratio (w/c) – 0.25
Free Water – 140 liters
20mm Metal / Aggregates – 611 Kg
10mm Metal / Aggregates – 475 Kg
Crush Sand – 813 Kg
Admixture Dosage – 1.1 %
Admixture – 6.16 Kg
Density of Concrete – 2605 Kg/cum
GGBS – 200 Kg
Crush Sand – 813 Kg
Admixture – 6.16 Kg
