Concrete Mix Design for M70 grade - A triple blend mix
Concrete mix Design for M70 Grade concrete, a Triple Blend with Fly ash and Micro silica is as follows;
OPC Cement 53 Grade – 500 Kg
Fly ash – 100 Kg
Micro silica – 50 Kg
Water Cement ratio (w/c) – 0.24
Free Water – 153 liters
20mm Metal / Aggregates – 511 Kg
10mm Metal / Aggregates – 455 Kg
Crush Sand – 784 Kg
Admixture Dosage – 0.8 %
Admixture – 5.12 Kg
Density of Concrete – 2560 Kg/cum
  • M70 with Fly ash micro silica.xlsx
Reactions: Mark1975
