Concrete Mix Design for M80 grade - A triple blend mix
Concrete mix Design for M80 Grade concrete, a Triple Blend with Fly ash and Micro silica is as follows;
OPC Cement 53 Grade – 540 Kg
Fly ash – 80 Kg
Micro silica – 60 Kg
Water Cement ratio (w/c) – 0.2
Free Water – 136 liters
20mm Metal / Aggregates – 520 Kg
10mm Metal / Aggregates – 461 Kg
Crush Sand – 0 Kg
River Sand – 802 Kg
Admixture Dosage – 0.8 %
Admixture – 5.44 Kg
Density of Concrete – 2604 Kg/cum
  • M80 with Fly ash micro silica.xlsx
Which admixture is good?
Almost all admixtures are good, for selecting right admixture for your mix you need to state atleast below requirement to manufacturer.
Workability of concrete you are looking for,
Required retention time for performance as per you site condition,
Water reduction capacity if any, you are looking for and,
Type of cement along with brand and other cementitious content you are using in your mix.
Once you provide the details to manufacturer, they will suggest you best suitable admixture accordingly.
Get the sample of admixture from them and do trials with it.
Then select one which provide you best results.
price of admixture should never be a criteria for selection of admixture, it may ruin you if your first requirement is price of admixture per kg.
