Cost Estimation for all Construction actives at Residential Project
Are you working in estimation department and want to do estimation for all construction activities involved in execution of Residential Project.
this cost estimation excel sheet will serve you as ready reference for doing your works at faster speed, as i added cost estimation for all construction activities.
This will also help you to not to skip or forgot any activity estimate.
Excel sheet have the cost estimates for following items;
Cost Estimate for PCC 1:4:8 (1 cement : 4 couarse sand : 8 graded stone aggregate)
Cost Estimate for PCC 1:3:6 (1 cement : 3 couarse sand : 6 graded stone aggregate)
Cost Estimate for PCC 1:2:4 (1 cement : 2 coarse sand : 4 graded stone aggregate)
Cost Estimate for M15 grade concrete with minimum cementitious content of 325 kg/cum.
Cost Estimate for RCC Footing (Concrete with Green seal 100 or equivalent admixture as per manufacturers specification)
Cost Estimate for RCC Plinth Beams (Concrete with Green seal 100 or equivalent admixture as per manufacturers specification)
Cost Estimate for RCC Beam at Upper Podium level (with height of scaffolding, shuttering & staging as show in in the drawing)
Cost Estimate for RCC Slab and Upper Podium level (with height of scaffolding, shuttering & staging as show in in the drawing)
Cost Estimate for Stilt Floor Slab
Cost Estimate for First Floor Beams
Cost Estimate for First Floor Slab
Cost Estimate for RCC Beam at all levels
Cost Estimate for Staircase
Cost Estimate for RCC Columns
Cost Estimate for Lift pardi
Cost Estimate for TMT bars (high yield strength deformed bars - Fe 500 conforming to IS 1786)
Cost Estimate for TMT bars (high yield strength deformed bars - Fe 415 conforming to IS 1786)
Cost Estimate for Mild steel
Cost Estimate for Providing and constructing 230 mm or more thick masonry
Cost Estimate for Providing and constructing 230 mm or more thick masonry WORK 150 mm thick with Band
Cost Estimate for Providing and constructing 230 mm or more thick masonry WORK 150 mm thick without Band
Cost Estimate for Masonry work 150 mm thick (BOXING) with Band
Cost Estimate for Masonry work 100 mm thick
Providing and applying 12 mm thick plaster
Cost Estimate for Ceiling Plaster
Cost Estimate for Duct Plaster
Cost Estimate for Entrance Flooring
Cost Estimate for Entrance Lobby Skirting
Cost Estimate for Dado Work
Cost Estimate for Deck flooring
Cost Estimate for Vitrified Tile Flooring
Cost Estimate for Skirting
Cost Estimate for Staircase Trade
Cost Estimate for Staircase Riser
Cost Estimate for Marble flooring stair, lift lobby
Cost Estimate for Sloping Skirting
Cost Estimate for KOTHA flooring stair, lift lobby
Cost Estimate for Cladding Work
Cost Estimate for Basin Counter
Cost Estimate for Kitchen Platform
Cost Estimate for Window Sill
Cost Estimate for Toilet Door frame
Cost Estimate for Main Door Frame : Section 6" x 3" Rebate of 55 mm African Teak wood
Cost Estimate for Main Door Frame : Section 6" x 3" Rebate of 55 mm Red Miranti Wood
Cost Estimate for Internal Door Frame
Cost Estimate for Main door shutter
Cost Estimate for Staircase Door
Cost Estimate for Bedroom Door
Cost Estimate for Duct Door
Cost Estimate for Kitchen Door Shutter
Cost Estimate for POP Covering for Flooring
Cost Estimate for Providing and doing 230 mm thick Dry rubble soiling
and Many More
I have attached cost estimation excel sheet below, you can modify it and use it in your project by changing specs, standards and rates as per your Area and company norms.
  • Cost Estimation for Construction Activities.xlsx
