  • LOUNGE
  • MCQ Questions
  • Reinforced Concrete - MCQ
Design of R.C.C. simply supported beams carrying U.D.L. is based on the resultant B.M. at
  • Thread starter Thread starter Srinivasan
  • Start date Start date Feb 8, 2018
Srinivasan
Srinivasan
Prime CE
mumbai
  • Feb 8, 2018
(A) Supports
(B) Mid span
(C) Every section
(D) Quarter span
The correct Answer Is
(B) Mid span
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Jun 6, 2019
Ayuba
Ayuba
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 8, 2018
Feb 8, 2018
Srinivasan
Srinivasan
