Excellent job. I think the front page should give instructions on how to utilize the design sheets. Explanation is necessary to identify slab panels rather than directly going to S1 S2 etc.
You only field the nominal data which in yellow and blue colors
also i write list which you enter data
Grade of concrete ƒck =
Grade of Steel ƒy =
Concrete cover =
Clear Short Span Lx=
Clear Long Span Ly =
Width of Supporting Beam =
Assume Thickness of Slab =
Dia. of Reinforcement Bar=
Super Imposed Load =
Floor Finish Load =
then carefully
Area of Steel along Short Span = ( which you want to provide )
Minimum Area of Steel = ( which you want to provide )
Provide Area of Steel =
( after see the result Area of Steel along Short Span & Minimum Area of Steel carefully select the Provide area of steel which we follow for design )
Width of Middle Strip =
