Detailed List of Civil Engineering IS Codes
CED 2 CEMENT AND CONCERTE SECTIONAL COMMITTEE
STANDARDS PUBLISHED
1 IS 269:2013 Specification for ordinary Portland cement, 33 grade (fifth revision)
2 IS 383:1970 Specification for coarse and fine aggregates from natural sources for concrete (second revision)
3 IS 455:1989 Specification for Portland slag cement (fourth revision)
4 IS 456:2000 Code of practice for plain and reinforced concrete (fourth revision)
5 IS 457:1957 Code of practice for general construction of plain and reinforced concrete for dams and other massive structures
6 IS 516:1959 Method of test for strength of concrete
7 IS 650:1991 Specification for standard sand for testing of cement (second revision)
8 IS 1199:1959 Methods of sampling and analysis of concrete
9 IS 1343:2012 Code of practice for prestressed concrete (second revision)
10 IS 1344:1981 Specification for calcined clay pozzolana (second revision)
11 IS 1489(Part 1):1991 Specification for Portland pozzolana cement: Part 1 Flyash based (third revision)
12 IS 1489(Part 2):1991 Specification for Portland-pozzolana cement: Part 2 Calcined clay based (third revision)
13 IS 1727:1967 Methods of test for pozzolanic materials (first revision)
14 IS 2386(Part 1):1963 Methods of test for aggregates for concrete: Part 1 Particle size and shape
15 IS 2386(Part 2):1963 Methods of test for aggregates for concrete: Part 2 Estimation of deleterious materials and organic
16 IS 2386(Part 3):1963 Methods of test for aggregates for concrete: Part 3 Specific gravity, density, voids, absorption and bulking
17 IS 2386(Part 4):1963 Methods of test for aggregates for concrete: Part 4 Mechanical properties
18 IS 2386(Part 5):1963 Methods of test for aggregates for concrete : Part 5 Soundness
19 IS 2386(Part 6):1963 Methods of test for aggregates for concrete : Part 6 Measuring mortar making properties of fine aggregates
20 IS 2386(Part 7):1963 Methods of test for aggregates for concrete : Part 7 Alkali aggregate reactivity
21 IS 2386(Part 8):1963 Methods of test for aggregates for concrete: Part 8 Petrographic examination
22 IS 2430:1986 Methods for sampling of aggregates for concrete (first revision)
23 IS 2502:1963 Code of practice for bending and fixing of bars for concrete reinforcement
24 IS 2645:2003 Specification for integral waterproofing compounds for cement mortar and concrete - (second revision)
25 IS 2770(Part 1):1967 Methods of testing bond in reinforced concrete: Part 1 Pull-out test
26 IS 3085:1965 Method of test for permeability of cement mortar and concrete
27 IS 3370(Part 1):2009 Code of practice for concrete structures for storage of liquids: Part 1 General requirements (first revision)
28 IS 3370(Part 2):2009 Code of practice for concrete structures for storage of liquids: Part 2 Reinforced concrete structures (first revision)
29 IS 3370(Part 3):1967 Code of practice for concrete structures for the storage of liquids: Part 3 Prestressed concrete structures
30 IS 3370(Part 4):1967 Code of practice for concrete structures for the storage of liquids: Part 4 Design tables
31 IS 3466:1988 Specification for masonry cement (second revision)
32 IS 3535:1986 Methods of sampling hydraulic cement (first revision)
33 IS 3558:1983 Code of practice for use of immersion vibrators for consolidating concrete (first revision)
34 IS 3812(Part 1):2013 Specification for pulverized fuel ash: Part 1 For use as pozzolana in cement, cement mortar and concrete (third revision)
35 IS 3812(Part 2):2013 Specification for pulverized fuel ash: Part 2 For use as admixture in cement mortar and concrete (third revision)
36 IS 4031(Part 1):1996 Methods of physical tests for hydraulic cement: Part 1 Determination of fineness by dry sieving (second revision)
37 IS 4031(Part 2):1999 Methods of physical tests for hydraulic cement: Part 2 Determination of fineness by specific surface by Blaine air permeability method (second revision)
38 IS 4031(Part 3):1988 Methods of physical tests for hydraulic cement: Part 3 Determination of soundness (first revision)
39 IS 4031(Part 4):1988 Methods of physical tests for hydraulic cement: Part 4 Determination of consistency of standard cement paste (first revision)
40 IS 4031(Part 5):1988 Methods of physical tests for hydraulic cement: Part 5 Determination of initial and final setting times (first revision)
41 IS 4031(Part 6):1988 Methods of physical tests for hydraulic cement: Part 6 Determination of compressive strength of hydraulic cement (other than masonry cement) (first revision)
42 IS 4031(Part 7):1988 Methods of physical tests for hydraulic cement: Part 7 Determination of compressive strength of masonry cement (first revision)
43 IS 4031(Part 8):1988 Methods of physical tests for hydraulic cement: Part 8 Determination of transverse and compressive strength of plastic mortar using prism (first revision)
44 IS 4031(Part 9):1988 Methods of physical tests for hydraulic cement: Part 9 Determination of heat of hydration (first revision)
45 IS 4031(Part 10):1988 Methods of physical tests for hydraulic cement: Part 10 Determination of drying shrinkage (first revision)
46 IS 4031(Part 11):1988 Methods of physical tests for hydraulic cement: Part 11 Determination of density (first revision)
47 IS 4031(Part 12):1988 Methods of physical tests for hydraulic cement: Part 12 Determination of air content of hydraulic cement mortar (first revision)
48 IS 4031(Part 13):1988 Methods of physical tests for hydraulic cement: Part 13 Measurement of water retentivity of masonry cement (first revision)
49 IS 4031(Part 14):1989 Methods of physical tests for hydraulic cement: Part 14 Determination of false set
50 IS 4031(Part 15):1991 Methods of physical test for hydraulic cement: Part 15 Determination of fineness by wet sieving
51 IS 4032:1985 Method of chemical analysis of hydraulic cement (first revision)
52 IS 4305:1967 Glossary of terms relating to pozzolana
53 IS 4634:1991 Methods for testing performance of batch-type concrete mixers (first revision)
54 IS 4845:1968 Definitions and terminology relating to hydraulic cement
55 IS 4926:2003 Code of practice for ready mixed concrete (second revision)
56 IS 5512:1983 Specification for flow table for use in tests of hydraulic cements and pozzolanic materials (first revision)
57 IS 5513:1996 Specification for vicat apparatus (second revision)
58 IS 5514:1996 Specification for apparatus used in Le-Chatelier Test (first revision)
59 IS 5515:1983 Specification for compaction factor apparatus (first revision)
60 IS 5516:1996 Specification for variable flow type air-permeability apparatus (Blaine type) (first revision)
61 IS 5525:1969 Recommendations for detailing of reinforcement in reinforced concrete works
62 IS 5536:1969 Specification for constant flow type air-permeability apparatus (Lea and Nurse type)
63 IS 5816:1999 Method of test for splitting tensile strength of concrete (first revision)
64 IS 6452:1989 Specification for high alumina cement for structural use (first revision)
65 IS 6461(Part 1):1972 Glossary of terms relating to cement concrete: Part 1 Concrete aggregates
66 IS 6461(Part 2):1972 Glossary of terms relating to cement concrete: Part 2 Materials (other than cement and aggregate)
67 IS 6461(Part 3):1972 Glossary of terms relating to cement concrete: Part 3 Concrete reinforcement
68 IS 6461(Part 4):1972 Glossary of terms relating to cement concrete: Part 4 Types of concrete
69 IS 6461(Part 5):1972 Glossary of terms relating to cement concrete: Part 5 Formwork for concrete
70 IS 6461(Part 6):1972 Glossary of terms relating to cement concrete: Part 6 Equipment, tools and plant
71 IS 6461(Part 7):1973 Glossary of terms relating to cement concrete: Part 7 Mixing, laying, compaction, curing and other construction aspects
72 IS 6461(Part 8):1973 Glossary of terms relating to cement concrete: Part 8 Properties of concrete
73 IS 6461(Part 9):1972 Glossary of terms relating of cement concrete: Part 9 Structural aspects
74 IS 6461(Part 10):1973 Glossary of terms relating to cement concrete: Part 10 Tests and testing apparatus
75 IS 6461(Part 11):1973 Glossary of terms relating to cement concrete: Part 11 Prestressed concrete
76 IS 6461(Part 12):1973 Glossary of terms relating to cement concrete: Part 12 Miscellaneous
77 IS 6491:1972 Method of sampling fly ash
78 IS 6909:1990 Specification for supersulphated cement
79 IS 6925:1973 Methods of test for determination of water soluble chlorides in concrete admixtures
80 IS 7246:1974 Recommendations for use of table vibrators for consolidating concrete
81 IS 7320:1974 Specification for concrete slump test apparatus
82 IS 7325:1974 Specification for apparatus for determining constituents of fresh concrete
83 IS 7861(Part 1):1975 Code of practice for extreme weather concreting: Part 1 Recommended practice for hot weather concreting
84 IS 7861(Part 2):1981 Code of practice for extreme weather concreting: Part 2 Recommended practice for cold weather concreting
85 IS 8041:1990 Specification for rapid hardening Portland cement (second revision)
86 IS 8042:1989 Specification for white Portland cement (second revision)
87 IS 8043:1991 Specification for hydrophobic Portland cement (second revision)
88 IS 8112:2013 Specification for ordinary Portland cement, 43 grade (second revision) 1
89 IS 8125:1976 Dimensions and materials of cement rotary kilns, components and auxiliaries (dry process with suspension preheater)
90 IS 8142:1976 Method of test for determining setting time of concrete by penetration resistance
91 IS 8229:1986 Specification for oil-well cement (first revision)
92 IS 8425:1977 Code of practice for determination of specific surface area of powders by air permeability methods
93 IS 9012:1978 Recommended practice for shotcreting
94 IS 9013:1978 Method of making, curing and determining compressive strength of accelerated cured concrete test specimens
95 IS 9103:1999 Specification for admixtures for concrete (first revision)
96 IS 9142:1979 Specification for artificial light weight aggregates for concrete masonry units
97 IS 9284:1979 Method of test for abrasion resistance of concrete
98 IS 9376:1979 Specification for apparatus for measuring aggregate crushing value and ten percent fines value
99 IS 9377:1979 Specification for apparatus for aggregate impact value
100 IS 9399:1979 Specification for apparatus for flexural testing of concrete
101 IS 9459:1980 Specification for apparatus for use in measurement of length change of hardened cement paste, mortar and concrete
102 IS 9799:1981 Specification for pressure meter for determination of air content of freshly mixed concrete
103 IS 10070:1982 Specification for machine for abrasion testing of coarse aggregates
104 IS 10078:1982 Specification for jolting apparatus for testing cement
105 IS 10079:1982 Specification for cylindrical metal measures for use in tests of aggregates and concrete
106 IS 10080:1982 Specification for vibration machine for casting standard cement mortar cubes
107 IS 10086:1982 Specification for moulds for use in tests of cement and concrete
108 IS 10262:2009 Guidelines for concrete mix proportioning (first revision)
109 IS 10510:1983 Specification for vee-bee consistometer
110 IS 10850:1984 Specification for apparatus for measurement of water retentivity of masonry cement
111 IS 10890:1984 Specification for planetary mixer used in tests of cement and pozzolana
112 IS 11262:1985 Specification for calorimeter for determination of heat of hydration of hydraulic cement
113 IS 11263:1985 Specification for cylinder measures for determination of air content of hydraulic cement mortar
114 IS 11578:1986 Method for determination of specific surface area of powder and porous particle using low temperature gas absorption
115 IS 11993:1987 Code of practice for use of screed board concrete vibrators
116 IS 12089:1987 Specification for granulated slag for manufacture of Portland slag cement
117 IS 12119:1987 General requirements for pan mixers for concrete
118 IS 12269:2013 Specification for ordinary Portland cement, 53 grade (first revision) 1
119 IS 12303:1987 Criteria for design of RCC hinges
120 IS 12330:1988 Specification for sulphate resisting Portland cement
121 IS 12423:1988 Method for colorimetric analysis of hydraulic cement
122 IS 12600:1989 Specification for low heat Portland cement
123 IS 12803:1989 Methods of analysis of hydraulic cement by X-ray fluorescence spectrometer
124 IS 12813:1989 Method of analysis of hydraulic cement by atomic absorption spectrophotometer
125 IS 12870:1989 Methods of sampling calcined clay pozzolana
126 IS 13311(Part 1):1992 Methods of non-destructive testing of concrete: Part 1 Ultrasonic pulse velocity
127 IS 13311(Part 2):1992 Methods of non-destructive testing of concrete: Part 2 Rebound hammer
128 IS 14345:1996 Specification for autoclave apparatus
129 IS 14687:1999 Guidelines for falsework for concrete structures
130 IS 14858:2000 Requirements for compression testing machine used for testing of concrete and mortar
131 IS 14959(Part 1):2001 Method of test for determination of water soluble and acid soluble chlorides in mortar and concrete: Part 1 Fresh mortar
132 IS 14959(Part 2):2001 Method of test for determination of water soluble and acid soluble chlorides in mortar and concrete: Part 2 Hardened mortar and concrete
133 IS 15388:2003 Specification for silica fume
134 SP 23(S&T): 1982 Handbook on concrete mixes (Based on Indian Standards)
135 SP 34(S&T): 1987 Handbook on concrete reinforcement and detailing
CED 3 SANITARY APPLIANCES AND WATER FITTINGS
STANDARDS PUBLISHED
1 IS 651:2007 Glazed stoneware pipe and fittings - Specification(sixth revision)
2 IS 771(Part 1):1979 Specification for glazed fire-clay sanitary appliances: Part 1 General requirements (second revision)
3 IS 771(Part 2):1985 Specification for glazed fire-clay sanitary appliances: Part 2 Specific requirements of kitchen and laboratory sinks (third revision)
4 IS 771(Part 3/Sec Specification for glazed fire clay sanitary appliances : Part 3 1):1979 Specific requirements of urinals, Section 1 Slab urinals (second revision)
5 IS 771(Part 3/Sec Specification for glazed fire-clay sanitary appliances: Part 3 2):1985 Specific requirements of urinals: Section 2 Stall urinals (third revision)
6 IS 771(Part 4):1979 Specification for glazed fire-clay sanitary appliances: Part 4 Specific requirements of postmortem slabs (second revision)
7 IS 771(Part 5):1979 Specification for glazed fire clay sanitary appliances: Part 5 Specific requirements of shower trays (second revision)
8 IS 771(Part 6):1979 Specification for glazed fire-clay sanitary appliances: Part 6 Specific requirements of bed-pan sinks (second revision)
9 IS 771(Part 7):1981 Specification for glazed fire-clay sanitary appliances: Part 7 Specific requirements of slop sinks (second revision)
10 IS 772:1973 Specification for general requirements for enamelled cast iron sanitary appliances (second revision)
11 IS 774:2004 Specification for flushing cistern for water closets and urinals (other than plastic cistern) (fifth revision)
12 IS 778:1984 Specification for copper alloy gate, globe and check valves for water works purposes (fourth revision)
13 IS 779:1994 Specification for water meters (domestic type) (sixth revision)
14 IS 781:1984 Specification for cast copper alloy screw down bib taps and stop valves for water services (third revision)
15 IS 782:1978 Specification for caulking lead (third revision)
16 IS 1701:1960 Specification for mixing valves for ablutionary and domestic purposes
17 IS 1703:2000 Water fittings - copper alloy float valves (horizontal plunger type) - Specification (fourth revision)
18 IS 1711:1984 Specification for self-closing taps for water supply purposes (second revision)
19 IS 1726:1991 Specification for cast iron manhole covers and frames (third revision)
20 IS 1795:1982 Specification for pillar taps for water supply purposes (second revision)
21 IS 2326:1987 Specification for automatic flushing cisterns for urinals (other Oct 2013 than plastic cisterns) (second revision)
22 IS 2373:1981 Specification for water meters (bulk type) (third revision)
23 IS 2548(Part 1):1996 Specification for plastic seats and covers for water-closets: Part 1 Thermoset seats and covers (fifth revision)
24 IS 2548(Part 2):1996 Specification for plastic seats and covers for water-closets: Part 2 Thermo plastic seats and covers (fifth revision)
25 IS 2556(Part 1):1994 Specification for vitreous sanitary appliances (vitreous china): Part 1 General requirements (third revision)
26 IS 2556(Part 2):2004 Specification for vitreous sanitary appliances (vitreous china): Part 2 Specific requirements of wash-down water-closets (fifth revision)
27 IS 2556(Part 3):2004 Specification for vitreous sanitary appliances (vitreous china): Part 3 Specific requirements of squatting pans (fifth revision)
28 IS 2556(Part 4):2004 Specification for vitreous sanitary appliances (vitreous china): Part 4 Specific requirements of wash basins (fourth revision)
29 IS 2556(Part 5):1994 Specification for vitreous sanitary appliances (vitreous china): Part 5 Specific requirements of laboratory sinks (third revision)
30 IS 2556(Part 6):1995 Specification for vitreous sanitary appliances (vitreous china): Part 6 Specific requirements of urinals and partition plates (fourth revision)
31 IS 2556(Part 7):1995 Specification for vitreous sanitary appliances (vitreous china): Part 7 Specific requirements of accessories for sanitary appliances (third revision)
32 IS 2556(Part 8):2004 Specification for vitreous sanitary appliances (vitreous china): Part 8 Specific requirements of pedestal close coupled wash-down and syphonic water closets (fifth rivision)
33 IS 2556(Part 9):2004 Specification for vitreous sanitary appliances (vitreous china): Part 9 Specific requirements of pedestal type bidets (fifth revision)
34 IS 2556(Part 14):1995 Specification for vitreous sanitary appliances (vitreous china): Part 14 Specific requirements of integrated squatting pans (first revision)
35 IS 2556(Part 15):2004 Specification for vitreous sanitary appliances (vitreous china): Part 15 Specific requirements of universal water closets (second revision)
36 IS 2556(Part 16):2002 Specification for vitreous sanitary appliances (vitreous china): Part 16 Specific requirements for wash down wall mounted
water closets
37 IS 2556(Part 17):2001 Specification for vitreous sanitary appliances (vitreous china): Part 17 Specific requirements for wall mounted bidets
38 IS 2685:1971 Code of practice for selection, installation and maintenance of sluice valves (first revision)
39 IS 2692:1989 Specification for ferrules for water services (second Revision)
40 IS 2963:2013 Copper alloy waste fittings and waste plug for wash basin and sinks- Specification (second revision) (amalgamating IS 3311)
41 IS 3004:1979 Specification for plug cocks for water supply purposes (first revision)
42 IS 3006:1979 Specification for chemically resistant glazed stoneware pipes and fittings (first revision)
43 IS 3042:1965 Specification for single faced sluice gates (200 to 1200 mm)
44 IS 3950:1979 Specification for surface boxes for sluice valves (first revision)
45 IS 4038:1986 Specification for foot valves for water works purposes (second revision)
46 IS 4346:1982 Specification for washers for use with fittings for water services (first revision)
47 IS 5219:2013 Cast copper alloys traps - Specification (first revision)
48 IS 5312(Part 1):2004 Specification for swing check type reflux (non-return) valves: Part 1 Single door pattern (second revision)
49 IS 5312(Part 2):2013 Swing check type reflux (non-return) valves for water works purposes-Specification: Part 2 Multi door pattern (first revision)
50 IS 5455:1969 Specification for cast-iron steps for manholes
51 IS 5961:1970 Specification for cast iron gratings for drainage purposes
52 IS 6411:1985 Specification for gel-coated glass fibre reinforced polyester resin bath tubs (first revision)
53 IS 6784:1996 Method for performance testing of water meters (domestic type) (second revision)
54 IS 7231:1994 Specification for plastic flushing cisterns for water closets and urinals (second revision)
55 IS 8931:1993 Specification for copper alloy fancy single taps, combination tap assembly and stop valves for water services (first revision)
56 IS 9140:1996 Method of sampling of vitreous and fire clay sanitary appliances (second revision)
57 IS 9338:2013 Cast iron/S.G. Iron/Cast Steel screw-down stop valves for water works purposes - Specification (second revision)
58 IS 9739:1981 Specification for pressure reducing valves for domestic water supply systems
59 IS 9758:1981 Specification for flush valves and fittings for water closets and urinals Oct 2012 2
60 IS 9762:1994 Specification for polyethylene floats (spherical) for float valves (first revision)
61 IS 9763:2000 Plastic bib taps, pillar taps, angle valves and stop valves for hot and cold water services - Specification (second revision)
62 IS 11246:1992 Specification for glass fibre reinforced polyester resins (GRP) squatting pans (first revision)
63 IS 12234:1988 Specification for plastic equilibrium float valve for cold water services Oct 2013
64 IS 12701:1996 Specification for rotational moulded polyethylene water storage tanks (first revision)
65 IS 13049:1991 Specification for diaphragm type (plastic body) float operated valves for cold water services
66 IS 13114:1991 Specification for forged brass gate, globe and check valves for water works purposes
67 IS 13349:1992 Specification for single faced cast iron thimble mounted sluice gates Oct 2012 1
68 IS 13983:1994 Specification for stainless steel sinks for domestic purposes
69 IS 14399(Part 1):1996 Hot press moulded thermosetting glass fibre reinforced polyester resin (GRP) sectional water storage tanks: Part 1 Specification for panels
70 IS 14399(Part 2):1996 Hot press moulded thermosetting glass fibre reinforced (GRP) sectional water storage tanks: Part 2 Guidelines for assembly, installation and testing
71 IS 14845:2000 Resilient seated cast iron air relief valves for water works purposes - Specification
72 IS 14846:2000 Sluice valves for water works purposes (50-1200 mm) - Specification
CED 4 BUILDING LIME AND GYPSUM PRODUCTS
STANDARDS PUBLISHED
1 IS 712:1984 Specification for building limes (third revision)
2 IS 1624:1986 Method of field testing of building lime (second revision)
3 IS 1635:1992 Code of practice for field slaking of building lime and preparation of putty (second revision)
4 IS 1849(Part 1/Sec Guide for design and installation of vertical mixed-feed lime):1990 kiln: Part 1 Limestone Section 1 Masonry type shaft (second revision)
5 IS 1849(Part 1/Sec Guide for design and installation of vertical mixed feed type 2):1991 lime kiln: Part 1 For limestone Section 2 RCC type shaft
6 IS 1861(Part 1):1990 Guide for manufacture of lime in vertical mixed-feed type kiln: Part 1 From lime-stone (second revision)
7 IS 2095(Part 1):2011 Specification for gypsum plaster boards: Part 1 Plain gypsum plaster boards (third revision)
8 IS 2095(Part 2):2001 Specification for gypsum plaster boards: Part 2 Coated/ laminated gypsum plaster boards (second revision)
9 IS 2095(Part 3):1996 Specification for gypsum plaster boards Part 3 Reinforced gypsum plaster boards (second revision)
10 IS 2469:1976 Glossary of terms relating to gypsum (first revision)
11 IS 2541:1991 Code of practice for preparation and use of lime concrete (second revision)
12 IS 2542(Part 1/Sec Methods of test for gypsum plaster, concrete and products: Part 1):1978 Plaster and Concrete: Sec 1 Normal consistency of gypsum plaster (first revision)
13 IS 2542(Part 1/Sec Methods of test for gypsum plaster, concrete and products: Part 2):1978 Plaster and Concrete: Sec 2 Normal consistency of gypsum concrete (first revision)
14 IS 2542(Part 1/Sec Methods of test for gypsum plaster, concrete and products: Part 3):1978 Plaster and Concrete: Sec 3 Setting time of plaster and concrete (first revision)
15 IS 2542(Part 1/Sec Methods of test for gypsum plaster, concrete and products: Part 4):1978 Plaster and Concrete: Sec 4 Transverse strength of gypsum plaster (first revision)
16 IS 2542(Part 1/Sec Methods of test for gypsum plaster, concrete and products: Part 5):1978 Plaster and Concrete: Sec 5 Compressive strength and dry set density of gypsum plaster (first revision)
17 IS 2542(Part 1/Sec Methods of test for gypsum plaster, concrete and products: Part 6):1978 Plaster and Concrete: Sec 6 Soundness of gypsum plaster (first revision)
18 IS 2542(Part 1/Sec Methods of test for gypsum plaster, concrete and products: Part 7):1978 Plaster and Concrete: Sec 7 Mechanical resistance of gypsum plaster by dropping ball test (first revision)
19 IS 2542(Part 1/Sec Methods of test for gypsum plaster, concrete and products: Part 8):1978 Plaster and Concrete: Sec 8 Freedom from coarse particles (first revision)
20 IS 2542(Part 1/Sec Methods of test for gypsum plaster, concrete and products: Part 9):1978 Plaster and Concrete: Sec 9 Expansion of plaster (first revision)
21 IS 2542(Part 1/Sec Methods of test for gypsum plaster, concrete and products: Part 10):1978 Plaster and Concrete: Sec 10 Sand in set plaster (first revision)
22 IS 2542(Part 1/Sec Methods of test for gypsum plaster, concrete and products: Part 11):1978 Plaster and Concrete: Sec 11 Wood fibre content in wood fibre gypsum plaster (first revision)
23 IS 2542(Part 1/Sec Methods of test for gypsum plaster, concrete and products: Part 12):1978 Plaster and Concrete: Sec 12 Dry bulk density (first revision)
24 IS 2542(Part 2/Sec Methods of test for gypsum plaster, concrete and products : Part 2 Gypsum products : Sec 1 Measurement of dimensions (first revision)
25 IS 2542(Part 2/Sec Methods of test for gypsum plaster, concrete and products : Part 2 Gypsum products : Sec 2 Determination of mass (first revision)
26 IS 2542(Part 2/Sec Methods of test for gypsum plaster, concrete and products : 3):1981 Part 2 Gypsum products : Sec 3 Determination of mass and thickness of paper surfacing (first revision)
27 IS 2542(Part 2/Sec Methods of test for gypsum plaster, concrete and products : 4):1981 Part 2 Gypsum products : Sec 4 Transverse strength (first revision)
28 IS 2542(Part 2/Sec Methods of test for gypsum plaster, concrete and products : 5):1981 Part 2 Gypsum products : Sec 5 Compressive strength (first revision)
29 IS 2542(Part 2/Sec Methods of test for gypsum plaster, concrete and products : 6):1981 Part 2 Gypsum products : Sec 6 Water absorption (first revision)
30 IS 2542(Part 2/Sec Methods of test for gypsum plaster, concrete and products : 7):1981 Part 2 Gypsum products : Sec 7 Moisture content (first revision)
31 IS 2542(Part 2/Sec Methods of test for gypsum plaster, concrete and products : 8):1981 Part 2 Gypsum products : Sec 8 Nail retention of precast reinforced gypsum slabs (first revision)
32 IS 2547(Part 1):1976 Specification for gypsum building plaster: Part 1 Excluding premixed lightweight plaster (first revision)
33 IS 2547(Part 2):1976 Specification for gypsum building plaster: Part 2 Premixed lightweight plaster (first revision)
34 IS 2686:1977 Specification for cinder as fine aggregates for use in lime concrete (first revision)
35 IS 2849:1983 Specification for non-load bearing gypsum partition blocks (solid and hollow types) (first revision)
36 IS 3068:1986 Specification for broken brick (burnt clay) coarse aggregates for use in lime concrete (second revision)
37 IS 3115:1992 Specification for lime based blocks (second revision)
38 IS 3182:1986 Specification for broken brick (burnt clay) fine aggregates for use in lime mortar (second revision)
39 IS 4098:1983 Specification for lime-pozzolana mixture (first revision)
40 IS 4139:1989 Specification for calcium silicate bricks (second revision)
41 IS 5817:1992 Code of practice for preparation and use of lime-pozzolana mixture concrete in buildings and roads (first revision)
42 IS 6508:1988 Glossary of terms relating to building lime (first revision)
43 IS 6932(Part 1):1973 Method of test for building limes Part 1 Determination of insoluble residue, loss on ignition, insoluble matter, silicone dioxide, ferric and aluminium oxide, calcium oxide and magnesium
44 IS 6932(Part 2):1973 Method of test for building limes: Part 2 Determination of carbon dioxide content
45 IS 6932(Part 3):1973 Method of test for building limes: Part 3 Determination of residue on slaking of quicklime
46 IS 6932(Part 4):1973 Method of test for building limes: Part 4 Determination of fineness of hydrated lime
47 IS 6932(Part 5):1973 Method of test for building limes: Part 5 Determination of unhydrated oxide
48 IS 6932(Part 6):1973 Method of test for building limes: Part 6 Determination of volume yield of quicklime
49 IS 6932(Part 7):1973 Method of test for building limes: Part 7 Determination of compressive and transverse strength
50 IS 6932(Part 8):1973 Method of test for building limes: Part 8 Determination of workability
51 IS 6932(Part 9):1973 Method of test for building limes: Part 9 Determination of soundness
52 IS 6932(Part 10):1973 Method of test for building limes: Part 10 Determination of popping and pitting of hydrated lime
53 IS 6932(Part 11):1984 Method of test for building limes: Part 11 Determination of setting time of hydrated lime
54 IS 8272:1984 Specification for gypsum plaster for use in the manufacture of fibrous plaster boards (first revision)
55 IS 9498:1980 Specification for inorganic aggregates for use in gypsum plaster
56 IS 10049:1981 Code of practice for manufacture of lime based blocks
57 IS 10359:1982 Code of practice for manufacture and use of lime-pozzolana concrete blocks for paving
58 IS 10360:1982 Specification for lime-pozzolana concrete blocks for paving
59 IS 10772:1983 Specification for quick setting lime pozzolana mixture
60 IS 12654:1989 Code of practice for use of low grade gypsum in building industry
61 IS 12679:1989 Specification for By-product gypsum for use in plaster, blocks and boards
62 IS 12894:2002 Specification for pulverized fuel ash lime bricks (first revision)
63 IS 13001:1991 Guidelines for manufacture of gypsum plaster in mechanized pan system
64 IS 14401:1996 Guidelines for handling and storage of building limes
65 IS 14860:2000 Guidelines on fuel saving in vertical mixed-feed lime shaft kilns
66 IS 15648:2006 Specification for pulverized fuel ash for lime pozzolana mixture applications
CED 5 FLOORING, WALL FINISHING AND ROOFING
STANDARDS PUBLISHED
1 IS 653:1992 Specification for linoleum sheets and tiles (third revision)
2 IS 657:1982 Specification for materials for use in the manufacture of magnesium oxychloride flooring compositions (second revision)
3 IS 658:1982 Code of practice for magnesium oxychloride composition floors (second revision)
4 IS 809:1992 Specification for rubber flooring materials for general purposes (first revision)
5 IS 1195:2002 Bitumen-mastic for flooring - Specification (third revision)
6 IS 1196:1978 Code of practice for laying bitumen mastic flooring (second revision)
7 IS 1197:1970 Code of practice for laying of rubber floors (first revision)
8 IS 1198:1982 Code of practice for laying, fixing and maintenance of linoleum floors (first revision)
9 IS 1237:2012 Specification for cement concrete flooring tiles (second revision)
10 IS 1443:1972 Code of practice for laying and finishing of cement concrete flooring tiles (first revision)
11 IS 1542:1992 Specification for sand for plaster (second revision)
12 IS 1630:1984 Specification for mason's tools for plaster work and pointing work (first revision)
13 IS 1661:1972 Code of practice for application of cement and cement-lime plaster finishes (first revision)
14 IS 2114:1984 Code of practice for laying in-situ terrazzo floor finish (first revision)
15 IS 2394:1984 Code of practice for application of lime plaster finish (first revision)
16 IS 2402:1963 Code of practice for external rendered finishes
17 IS 2571:1970 Code of practice for laying in-situ cement concrete flooring (first revision)
18 IS 3461:1980 Specification for PVC asbestos floor tiles (first revision)
19 IS 3462:1986 Specification for unbacked flexible PVC flooring (second revision)
20 IS 3464:1986 Methods of test for plastic flooring and wall tiles (second revision)
21 IS 4441:1980 Code of practice for use of silicate type chemical resistant mortars (first revision)
22 IS 4442:1980 Code of practice for use of sulphur type chemical resistant mortars (first revision)
23 IS 4443:1980 Code of practice for use of resin type chemical resistant mortars (first revision)
24 IS 4456(Part 1I):1967 Methods of test for chemical resistant mortars: Part 1 Silicate type and resin type
25 IS 4456(Part 2):1967 Methods of test for chemical resistant mortars: Part 2 Sulphur type
26 IS 4457:2007 Ceramic unglazed vitreous acid resisting tile - Specification (second revision)
27 IS 4631:1986 Code of practice for laying of epoxy resin floor toppings (first revision)
28 IS 4832(Part 1):1969 Specification for chemical resistant mortars: Part 1 Silicate type
29 IS 4832(Part 2):1969 Specification for chemical resistant mortars: Part 2 Resin type
30 IS 4832(Part 3):1968 Specification for chemical resistant mortars: Part 3 Sulphur type
31 IS 4860:1968 Specification for acid-resistant bricks
32 IS 4971:2007 Recommendations for selection of industrial floor finishes (first revision)
33 IS 5317:2002 Specification for pitch-mastic for bridge decking and roads (second revision)
34 IS 5318:1969 Code of practice for laying of flexible PVC sheet and tile
35 IS 5491:1969 Code of practice for laying of in-situ granolithic concrete floor topping
36 IS 5766:1970 Code of practice for laying burnt clay brick flooring
37 IS 6278:1971 Code of practice for white-washing and colour washing
38 IS 7956:1975 Recommendations for selection of dairy floor finishes
39 IS 8374:1977 Specification for bitumen mastic, anti-static and electrically conducting grade
40 IS 9162:1979 Methods of tests for epoxy resins, hardeners and epoxy resin compositions for floor topping
41 IS 9197:1979 Specification for epoxy resin, hardners and epoxy resin compositions for floor topping
42 IS 9510:1980 Specification for bitumen mastic, acid-resisting grade
43 IS 9704:1980 Methods of tests for linoleum sheets and tiles
44 IS 10132:1982 Method of test for materials for use in the preparation of magnesium oxychloride flooring compositions
45 IS 10403:1983 Glossary of terms relating to building finishes
46 IS 12583:1988 Specification for corrugated bitumen roofing sheets
47 IS 12866:1989 Specification for plastic translucent sheets made from thermo- setting polyester resin (glass fibre reinforced)
48 IS 13026:1991 Specification for bitumen mastic for flooring for industries handling LPG and other light hydrocarbon products
49 IS 13074:1991 Code of practice for laying of bitumen mastic flooring for industries handling LPG and other light hydrocarbon products
50 IS 13630(Part 1):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 1 Determination of dimensions and surface quality (first revision)
51 IS 13630(Part 2):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 2 Determination of water absorption and bulk density (first revision)
52 IS 13630(Part 3):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 3 Determination of moisture expansion using boiling water (first revision)
53 IS 13630(Part 4):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 4 Determination of linear thermal expansion (first revision)
54 IS 13630(Part 5):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 5 Determination of resistance to thermal shock (first revision)
55 IS 13630(Part 6):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 6 Determination of modulus of rupture and breaking strength (first revision)
56 IS 13630(Part 7):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 7 Determination of chemical resistance unglazed tiles (first revision)
57 IS 13630(Part 8):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 8 Determination of chemical resistance glazed tiles (first revision)
58 IS 13630(Part 9):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 9 Determination of crazomg resistance - glazed tiles (first revision)
59 IS 13630(Part 10):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 10 Determination of frost resistance (first revision)
60 IS 13630(Part 11):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 11 Determination of resistance of surface abrasion - Glazed tiles (first revision)
61 IS 13630(Part 12):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 12 Determination of resistance to deep abrasion - Unglazed tiles (first revision)
62 IS 13630(Part 13):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 13 Determination of scratch hardness of surface according to MOHS (first revision)
63 IS 13630(Part 14):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 14 Determination of impact resistance by measurement of coefficient of restitution
64 IS 13630(Part 15):2006 Ceramic Tiles - Methods of Test, Sampling and Basis for Acceptance Part 15 Ceramic tiles sampling and basis for acceptance {Superseding IS 13711:1993)
65 IS 13712:2006 Ceramic tiles - Definitions, classifications, characteristics and marking (first revision)
66 IS 13801:2013 Chequered cement concrete tiles - Specification (first revision)
67 IS 15193:2002 Code of practice for laying of pitch-mastic flooring for industries handling heavy hydrocarbon product like kerosene, diesel and furnace oil
68 IS 15194:2002 Pitch-mastic flooring and industries handling heavy hydrocarbon products like kerosene, diesel and furnace oil -
69 IS 15224:2002 Laying of plastic translucent sheets made from thermosetting polyester resin (glass fibre reinforced) alone or in conjunction with asbestos cement sheets/steel sheets/aluminium sheets - Code of practice
70 IS 15401:2003 Wall coverings in roll forms - Vocabulary and symbols
71 IS 15418:2003 Wall coverings in roll form for finished wall papers, wall vinyls and plastic wall coverings - Specification
72 IS 15477:2004 Adhesives for use with ceramic tiles and mosaics-Specification
73 IS 15622:2006 Pressed ceramic tiles - Specification (Superseding IS 13753, IS 13754, IS 13755 and IS 13756)
74 IS 15658:2006 Precast concrete blocks for paving - Specification
CED 6 STONES
STANDARDS PUBLISHED
1 IS 1121(Part 1):2013 Methods of test for determination of strength properties of natural building stones: Part 1 Compressive strength (second revision)
2 IS 1121(Part 2):2013 Methods of test for determination of strength properties of natural building stones: Part 2 Transverse strength (second revision)
3 IS 1121(Part 3):2012 Methods of test for determination of strength properties of natural building stones: Part 3 Tensile strength (second revision)
4 IS 1121(Part 4):2013 Methods of test for determination of strength properties of natural building stones: Part 4 Shear strength (second revision)
5 IS 1122:1974 Method of test for determination of true specific gravity of natural building stones (first revision)
6 IS 1123:1975 Method of identification of natural building stones (first revision)
7 IS 1124:1974 Method of test for determination of water absorption, apparent specific gravity and porosity of natural building stones (first revision)
8 IS 1125:2013 Method of test for determination of weathering of natural building stones (second revision)
9 IS 1126:2013 Method of test for determination of durability of natural building stones (second revision)
10 IS 1127:1970 Recommendations for dimensions and workmanship of natural building stones for masonry work (first revision)
11 IS 1128:1974 Specification for limestone (slab and tiles) (first revision)
12 IS 1129:1972 Recommendation for dressing of natural building stones (first revision)
13 IS 1130:1969 Specification for marble (blocks, slabs and tiles)
14 IS 1706:1972 Method for determination of resistance to wear by abrasion of natural building stones (first revision)
15 IS 1805:1973 Glossary of terms relating to stones: quarrying and dressing (first revision)
16 IS 3316:1974 Specification for structural granite (first revision)
17 IS 3620:1979 Specification for laterite stone block for masonry (first revision)
18 IS 3622:1977 Specification for sandstone (slabs and tiles)(first revision)
19 IS 4121:1967 Method of test for determination of water transmission rate by capillary action through natural building stones
20 IS 4122:1967 Method of test for surface softening of natural building stones by exposure to acidic atmospheres
21 IS 4348:1973 Methods of test for determination of permeability of natural building stones (first revision)
22 IS 5218:1969 Method of test for toughness of natural building stones
23 IS 5640:1970 Method of test for determining aggregate impact value of soft coarse aggregates
24 IS 6241:1971 Method of test for determination of stripping value of road aggregates
25 IS 6250:1981 Specification for roofing slate tiles (first revision)
26 IS 6579:1981 Specification for coarse aggregate for water bound macadam (first revision)
27 IS 7779(Part 1/Sec Schedule for properties and availability of stones for 1):1975 construction purpose: Part 1 Gujarat state Section 1 Availability of Stones
28 IS 7779(Part 1/Sec Schedule for properties and availability of stones for 2):1975 construction purposes: Part 1 Gujarat state: Section 2 Engineering properties of building stones
29 IS 7779(Part 1/Sec Schedule for properties and availability of stones for 3):1975 construction purposes: Part 1 Gujarat state: Section 3 Engineering properties of stone aggregates
30 IS 7779(Part 2/Sec Schedule for properties and availability of stones for 1):1979 construction purposes: Part 2 Maharashtra state Section 1 Availability of Stones
31 IS 7779(Part 2/Sec Schedule for properties and availability of stones for 2):1979 construction purposes: Part 2 Maharashtra state Section 2 Engineering properties of building stones
32 IS 7779(Part 2/Sec Schedule for properties and availability of stones for 3):1979 construction purposes: Part 2 Maharashtra state: Section 3 Engineering properties of stone aggregates
33 IS 7779(Part 3/Sec Schedule for properties and availability of stones for 2):1980 construction purposes Part 3 Tamilnadu state Section 2 Engineering properties of building stone
34 IS 7779(Part 3/Sec Schedule for properties and availability of stones for 3):1980 construction purposes: Part 3 Tamilnadu State section 3 Engineering properties of stone aggregates
35 IS 7779(Part 4/Sec Schedule of properties and availability of stones for 1):1996 construction purposes Part 4 Karnataka states Sections (1 to 3)
36 IS 7779(Part 5/Sec Schedule of properties and availability of stones for 1):1997 construction purposes Part 5 Andhra Pradesh Section 1 Availability of Stones
37 IS 7779(Part 5/Sec Schedule of properties and availability of stones for 2):1997 construction purposes Part 5 Andhra Pradesh Section 2 Engineering properties of building stones
38 IS 7779(Part 5/Sec Schedule of properties and availability of stones for 3):1997 construction purposes Part 5 Andhra Pradesh Section 3 Engineering properties of stone aggregates
39 IS 8348:1977 Code of practice for stacking and packing of stone slabs for transportation
40 IS 8381:1977 Recommended practice for quarrying stones for construction purposes
41 IS 8759:1977 Code of practice for maintenance and preservation of stones in building
42 IS 9394:1979 Specification for stone lintels
43 IS 14223(Part 1):1995 Specification for polished building stones: Part 1 Granite
CED 7 STRUCTURAL ENGINEERING AND STRUCTURAL SECTIONS
STANDARDS PUBLISHED
1 IS 800:2007 Code of practice for general construction in steel (third revision)
2 IS 801:1975 Code of practice for use of cold formed light gauge steel structural members in general building construction (first revision)
3 IS 802(Part 1/Sec Code of practice for use of structural steel in overhead 1):1995 transmission line towers, Part 1 Materials, Loads and permissible stresses Section 1 Materials and Loads (third revision)
4 IS 802(Part 1/Sec Code of practice for use of structural steel in overhead 2):1992 transmission line towers Part 1 : Material, loads and permissible stress Section 2 Permissible stress (third revision)
5 IS 802(Part 2):1978 Code of practice for use of structural steel in overhead transmission line towers: Part 2 Fabrication, galvanizing, inspection and packing
6 IS 802(Part 3):1978 Code of practice for use of structural steel in overhead transmission line towers: Part 3 Testing
7 IS 803:1976 Code of practice for design, fabrication and erection of vertical mild steel cylindrical welded oil storage tanks (first revision)
8 IS 804:1967 Specification for rectangular pressed steel tanks (first revision)
9 IS 805:1968 Code of practice for use of steel in gravity water tanks
10 IS 806:1968 Code of practice for use of steel tubes in general building construction (first revision)
11 IS 808:1989 Dimensions for hot rolled steel beam, column, channel and angle sections (third Revision)
12 IS 811:1987 Specification for cold formed light gauge structural steel sections (second revision)
13 IS 1173:1978 Specification for hot rolled slit steel tee bars (second revision)
14 IS 1252:1991 Dimensions of hot rolled steel bulb angles (first revision)
15 IS 1730:1989 Dimensions for steel plates, sheets, strips and flats for general engineering purposes (second revision)
16 IS 1732:1989 Dimensions for round and square steel bars for structural and general engineering purposes (second revision)
17 IS 1852:1985 Rolling and cutting tolerances for hot rolled steel products (fourth revision)
18 IS 1863:1979 Specification for hot rolled steel bulb flats (first revision)
19 IS 1864:1979 Specification for hot-rolled steel L-sections for ship building
20 IS 2314:1986 Specification for steel sheet piling sections (first revision)
21 IS 2713(Part 1-3):1980 Specification for tubular steel poles for overhead power lines
22 IS 2750:1964 Specification for steel scaffoldings
23 IS 3443:1980 Specification for crane rail sections (first revision)
24 IS 3908:1986 Specification for aluminium equal leg angles (first revision)
25 IS 3909:1986 Specification for aluminium unequal leg angles (first revision)
26 IS 3921:1985 Specification for aluminium channels (first revision)
27 IS 3954:1991 Hot-rolled steel channel sections for general engineering purposes - Dimensions (first revision)
28 IS 3964:1980 Specification for light rails (first revision)
29 IS 4000:1992 Code of practice for high strength bolts in steel structures
30 IS 4014(Part 1):1967 Code of practice for steel tubular scaffolding Part 1 Definitions and materials
31 IS 5384:1985 Specification for aluminium I-beam (first revision)
32 IS 5488:1987 Dimensions and dimensional tolerances for hot rolled steel plates for ship's hull structure(first revision)
33 IS 6445:1985 Specification for aluminium tee-sections (first revision)
34 IS 6449:1987 Specification for aluminium bulb angles for marine application (first revision)
35 IS 6475:1987 Specification for aluminium tee bars for marine application (first revision)
36 IS 6476:1987 Specification for aluminium bulb plates for marine application (first revision)
37 IS 6533(Part 1):1989 Code of practice for design and construction of steel chimneys Part 1 Mechanical aspects (first revision)
38 IS 6533(Part 2):1989 Code of practice for design and construction of steel chimneys Part 2 Structural aspects (first revision)
39 IS 7205:1974 Safety code for erection of structural steel work
40 IS 7215:1974 Tolerances for fabrication of steel structures
41 IS 7452:1990 Specification for hot-rolled steel sections for doors, windows and ventilators(second revision)
42 IS 8081:1976 Specification for slotted sections
43 IS 8147:1976 Code of practice for use of aluminium alloys in structures
44 IS 8640:1977 Recommendations for dimensional parameters for industrial building
45 IS 9178(Part 1):1979 Criteria for design of steel bins for storage of bulk materials Part 1 General requirements and assessment of loads
46 IS 9178(Part 2):1979 Criteria for design of steel bins for storage of bulk material Part 2 Design criteria
47 IS 9178(Part 3):1980 Criteria for design of steel bins for storage of bulk materials Part 3 Bins designed for mass flow and funnel flow
48 IS 9964(Part 1):1981 Recommendations for maintenance and operation of petroleum storage tanks Part 1 Preparation of tanks for safe
49 IS 9964(Part 2):1981 Recommendations for maintenance and operation of petroleum storage tanks Part 2 Inspection
50 IS 10182(Part 1):1982 Dimensions and tolerances for hot-rolled track shoe sections Part 1 Section TS-L1
51 IS 10182(Part 2):1985 Dimensions and tolerances for hot-rolled track shoe sections Part 2 Section TS-H1
52 IS 10987:1992 Code of practice for design, fabrication, testing and installation of underground/above ground horizontal cylindrical storage tanks for petroleum products (first revision)
53 IS 12778:2004 Hot rolled parallel flange steel sections for beam, columns and bearing pile - Dimensions and section properties (first revision)
54 IS 12779:1989 Rolling and cutting tolerances for hot rolled parallel flange beam and column sections
55 IS 12843:1989 Tolerances for erection of steel structures
56 IS 15663(Part 1):2006 Code of practice for design and installation of natural gas pipelines: Part 1 Laying of pipelines
57 IS 15663(Part 2):2006 Code of practice for design and installation of natural gas pipelines: Part 2 Laying of pipelines in crossings
58 IS 15663(Part 3):2006 Code of practice for design and installation of natural gas pipelines: Part 3 Pre-commissioning and commissioning of pipelines
59 SP 6(Part 4): 1969 Handbook for structural engineers use of high strength friction grip bolts
60 SP 6(Part 5): 1980 Handbook for structural engineers - Cold-formed, light gauge steel structures (first revision)
61 SP 6(Part 6): 1972 Handbook for structural engineers - Application of plastic theory in design of steel structures
CED 9 TIMBER AND TIMBER STORES
STANDARDS PUBLISHED
1 IS 10(Part 1):1990 Specification for plywood tea-chests: Part 1 General (fifth revision)
2 IS 10(Part 2):2013 Specification for plywood tea-chests: Part 2 Plywood (sixth revision)
3 IS 10(Part 3):1974 Specification for plywood tea-chests: Part 3 Battens (fourth revision)
4 IS 10(Part 4):1989 Specification for plywood tea-chests: Part 4 Metal fittings (fifth revision)
5 IS 10(Part 5):1976 Specification for plywood tea-chests; Part 5 Assembly and packing (fourth revision)
6 IS 190:1991 Coniferous sawn timber (Baulks and scantlings) - Specification (fourth revision)
7 IS 287:1993 Permissible moisture content for timber used for different purposes - Recommendations (third revision)
8 IS 399:1963 Classification of commercial timbers and their zonal distribution (first revision )
9 IS 401:2001 Preservation of timber - Code of practice (fourth revision)
10 IS 620:1985 Specification for wooden tool handles general requirements (fourth revision)
11 IS 656:1988 Specification for logs for plywood (third revision)
12 IS 707:2011 Glossary of terms applicable to timber technology and utilization( third revision)
13 IS 876:1992 Wood poles for overhead power and telecommunication lines - Specification (third revision)
14 IS 1140:1988 Specification for logs for matches (second revision)
15 IS 1141:1993 Seasoning of timber - Code of practice (second revision)
16 IS 1150:2000 Trade names and abbreviated symbols for timber species (third revision)
17 IS 1326:1992 Non-coniferous sawn timber (Baulks and scantlings) - Specification (second revision)
18 IS 1331:1971 Specification for cut sizes of timber (second revision) (Superseding IS 1629:1960)
19 IS 1503:1988 Specification for wooden packing cases (third revision)
20 IS 1707:1979 Specification for wood wool for general packaging purposes
21 IS 1708(Part 1):1986 Methods of testing of small specimens of timber: Part 1 Determination of moisture content (second revision)
22 IS 1708(Part 2):1986 Methods of testing of small specimens of timber: Part 2 Determination of specific gravity (second revision)
23 IS 1708(Part 3):1986 Methods of testing of small specimens of timber: Part 3 Determination of volumetric shrinkage (second revision)
24 IS 1708(Part 4):1986 Methods of testing of small specimens of timber: Part 4 Determination of radial and tangential shrinkage and fibre saturation point (second revision)
25 IS 1708(Part 5):1986 Methods of testing of small specimens of timber: Part 5 Determination of static bending strength (second revision)
26 IS 1708(Part 6):1986 Methods of testing of small specimens of timber: Part 6 Determination of static bending strength under two point loading (second revision)
27 IS 1708(Part 7):1986 Methods of testing of small specimens of timber: Part 7 Determination of impact bending strength (second revision)
28 IS 1708(Part 8):1986 Methods of testing of small specimens of timber: Part 8 Determination of compressive strength parallel to grain
29 IS 1708(Part 9):1986 Methods of testing of small specimens of timber: Part 9 Determination of compressive strength perpendicular to grain
30 IS 1708(Part 10):1986 Methods of testing of small specimens of timber: Part 10 Determination of hardness under static indentation
31 IS 1708(Part 11):1986 Methods of testing of small specimens of timber: Part 11 Determination of shear strength parallel to grain
32 IS 1708(Part 12):1986 Methods of testing of small specimens of timber: Part 12 Determination of tensile strength parallel to grain (second revision)
33 IS 1708(Part 13):1986 Methods of testing of small specimens of timber: Part 13 Determination of tensile strength perpendicular to grain
34 IS 1708(Part 14):1986 Methods of testing of small specimens of timber: Part 14 Determination of cleavage strength parallel to grain
35 IS 1708(Part 15):1986 Methods of testing of small specimens of timber: Part 15 Determination of nail and screw holding power
36 IS 1708(Part 16):1986 Methods of testing of small specimens of timber: Part 16 Determination of brittleness by Izod impact (second revision)
37 IS 1708(Part 17):1986 Methods of testing of small specimens of timber: Part 17 Determination of brittleness by Charpy impact (second revision)
38 IS 1708(Part 18):1986 Methods of testing of small specimens of timber: Part 18 Determination of torsional strength (second revision)
39 IS 1898:1990 Timber for aircraft construction in converted form (finished form) - Specification (second revision)
40 IS 1900:1974 Methods of tests for wood poles (first revision)
41 IS 1902:2006 Preservation of bamboo and cane for non-structural purposes - Code of practice (second revision)
42 IS 2133:1983 Specification for wooden tent pins (second revision)
43 IS 2179:1979 Specification for converted timber for lorry bodies (first revision)
44 IS 2203:1993 Wooden cross arms - Specification (second revision)
45 IS 2372:2004 Timber for cooling towers - Specification (second revision)
46 IS 2377:1967 Tables for volumes of cut sizes of timber (first revision)
47 IS 2408:1963 Methods of static tests of timber in structural sizes
48 IS 2455:1990 Method of sampling of model trees and logs and their conversion for timber testing (second revision)
49 IS 2674:1988 Specification for battened plywood cases (second revision)
50 IS 2683:1980 Guide for installation of impregnation plants for timber
51 IS 2753(Part 1):1991 Methods for estimation of preservatives in treated timber and in treating solutions: Part 1 Determination of copper, arsenic, chromium, zinc, boron, creosote and fuel oil (first revision)
52 IS 2753(Part 2):2014 Methods for estimation of preservatives in treated timber and in treating solutions : Part 2 Determination of copper in copper organic preservative salt (second revision)
53 IS 2891:1975 Specification for wooden handles for felling axes and hand axes (first revision)
54 IS 2892:1993 Wooden handles for picks and beaters - Specification
55 IS 2893:1992 Wooden handles for adzes - Specification (second revision)
56 IS 2894:1987 Specification for wooden handles for wood working chisels and gouges (first revision)
57 IS 2895:1990 Wooden handles for rasps, engineers' file and engineers' scrapers - Specification (second revision)
58 IS 2896:1978 Specification for wooden handles for carpenters' augers
59 IS 2897:1983 Specification for wooden handles for shovels (first revision)
60 IS 2922:1975 Specification for wooden tent mallets (first revision)
61 IS 3053:1977 Specification for cane baskets for general purposes
62 IS 3071:1981 Specification for wooden crates (first revision)
63 IS 3084:1989 Pencil slats - Specification (second revision)
64 IS 3337:1978 Specification for ballies for general purposes (first revision)
65 IS 3364(Part 1):1976 Methods of measurement and evaluation of defects in timber: Part 1 Logs (first revision)
66 IS 3364(Part 2):1976 Methods of measurement and evaluation of defects in timber: Part 2 Converted timber (first revision)
67 IS 3386:1979 Specification for wooden fence posts (first revision)
68 IS 3728:1985 Specification for wooden boxes for packaging of apples
69 IS 3731:1985 Specification for teak squares (first revision)
70 IS 3806:1966 Specification for wooden beaters
71 IS 4422:1985 Specification for willow clefts for cricket bats (first revision)
72 IS 4423:1999 Hand-sawing of timber - Guide (first revision)
73 IS 4424:1967 Specification for timber for use in coal mines
74 IS 4650:1968 Specification for wooden anvil blocks
75 IS 4833:1993 Methods for field testing of preservatives in wood (first revision)
76 IS 4873(Part 1):2008 Method of laboratory testing of wood preservatives against fungi and borers (powder post beetles) : Part 1 Determination of threshold values of wood preservatives against fungi
77 IS 4873(Part 2):2008 Method of laboratory testing of wood preservatives against fungi and borers (powder post beetles): Part 2 Determination of threshold values of wood preservatives against borers (powder post beetles) (second revision)
78 IS 4895:1985 Specification for teak logs (first revision)
79 IS 4907:2004 Method of testing timber connector joints (first revision)
80 IS 4953:1989 Wooden handles for hand hammers - Specification
81 IS 4970:1973 Key for identification of commercial timbers (first revision)
82 IS 5246:2000 Coniferous logs - Specification (first revision)
83 IS 5247(Part 1):1982 Specification for converted timber (coniferous) : Part 1 Light furniture (first revision)
84 IS 5247(Part 2):1982 Specification for converted timber (coniferous) : Part 2 Packing cases and crates (first revision)
85 IS 5806:1970 Specification for non-coniferous timber in converted form for ammunition/explosives boxes
86 IS 5942:1989 Wooden handles for POWRAHS - Specification (first revision)
87 IS 5966:1993 Non-coniferous timber in converted form for general purposes - Specification (first revision)
88 IS 5978:1970 Code of practice for design of wood poles for overhead power and telecommunication lines
89 IS 6056:1970 Specification for jointed wood poles for overhead power and telecommunication lines
90 IS 6341:1971 Method for laboratory test for efficacy of wood preservatives against soft rot
91 IS 6346:1971 Method of tests for timber props for mines
92 IS 6497:1990 Method of test for the efficacy of preservatives and evaluating the natural durability of timbers used in cooling towers
93 IS 6534:1971 Guiding principles for grading and inspection of timber
94 IS 6641:1985 Specification for wooden disc for tents (first revision)
95 IS 6642:1986 Specification for mason's mallets (first revision)
96 IS 6643:1987 Specification for wooden pins for bivouac tents (first revision)
97 IS 6644:1986 Specification for tinman's mallets (first revision)
98 IS 6656:1986 Specification for caulking mallets (first revision)
99 IS 6662:1993 Timber species suitable for wooden packaging - Specification
100 IS 6676:1986 Specification for bossing (plumbers), mallets (first revision)
101 IS 6703:1972 Glossary of wooden packaging terms
102 IS 6707:1972 Specification for willow logs for artificial limbs
103 IS 6711:1972 Code of practice for maintenance of wood poles for overhead power and telecommunication lines
104 IS 6729:1972 Specification for wooden paddles
105 IS 6791:1973 Method of testing natural durability of timber and efficacy of the wood preservatives against marine borers
106 IS 6874:2008 Method of test for bamboos (first revision)
107 IS 7308:1999 Non-coniferous logs - Specification (first revision)
108 IS 7315:1974 Guidelines for design, installation and testing of timber seasoning kilns (Compartment type with cross-forced air)
109 IS 7344:1974 Specification for bamboo tent poles
110 IS 7548:1992 Vase for store tent - Specification (first revision)
111 IS 7549:1975 Specification for timber half wrought for sporting rifles
112 IS 7698:1983 Specification for returnable wooden crates for vegetables
113 IS 7850:1975 Specification for wooden box for microscope slides
114 IS 7992:1983 Specification for plywood cases for packing tobacco for export
115 IS 8001:1976 Specification for packaging of plywood, blockboards and flush doors for export
116 IS 8242:1976 Methods of tests for split bamboos
117 IS 8292:1992 Evaluation of working quality of timber under different wood working operations - Method of test (first revision)
118 IS 8295(Part 1):1976 Specification for bamboo chicks: Part 1 Fine
119 IS 8295(Part 2):1976 Specification for bamboo chicks: Part 2 Coarse
120 IS 8720:1978 Methods of sampling of timber scantlings from depots and their conversion for testing
121 IS 8725:1978 Specification for wirebound wooden boxes
122 IS 8726:1978 Specification for wirebound wooden crates
123 IS 8745:1994 Methods of presentation of data of physical and mechanical properties of timber (first revision)
124 IS 9096:2006 Preservation of bamboo for structural purposes - Code of practice (first revision)
125 IS 9104:1979 Guide for storage and protection of logs and sawn timber
126 IS 9561:1985 Code of practice for felling and conversion of trees into logs
127 IS 9576:1980 Guide for mill sawing of timber
128 IS 9590:1980 Specification for non-returnable wooden boxes for horticulture produce
129 IS 10013(Part 1):1981 Specification for water soluble type wood preservatives: Part 1 Acid-copper-chrome (ACC) preservative
130 IS 10013(Part 2):1981 Specification for water soluble type wood preservatives: Part 2 Copper-chrome-arsenic (CCA) wood preservative
131 IS 10013(Part 3):1981 Specification for water soluble type wood preservatives: Part 3 Copper-chrome-boron (CCB) wood preservative
132 IS 10145:1982 Specification for bamboo supports for camouflaging equipment
133 IS 10394:1982 Specification for wooden sleepers for railway track
134 IS 10402:1982 Specification for pin-needle hardboard boxes for packaging of apples
135 IS 10420:1982 Method of determination of sound absorption coefficient of timber by standing wave method
136 IS 10499:1983 Specification for wooden toggles
137 IS 10687:1983 Guidelines for nailing of large framed wooden containers
138 IS 10753:1983 Code of practice for preservation of wooden sleepers for railway track by pressure treatment
139 IS 10754:1983 Method of determination of thermal conductivity of timber
140 IS 11100:1984 Specification for sweeping brooms
141 IS 11106:1984 Specification for carpenter's mallets
142 IS 11131:1984 Specification for wooden casks and barrels
143 IS 11215:1991 Moisture content of timber and timber products - Methods for determination (first revision)
144 IS 11288:1985 Recommendations for off road transportation of timber
145 IS 12896:1990 Indian timbers for door and window shutters and frames - Classification
146 IS 13621:1993 Determination of dielectric constant of wood under microwave frequencies - Method of test
147 IS 13622:1993 Indian timbers for furnitures and cabinets - Classification
148 IS 14960:2001 Preservative treated and seasoned sawn timber from rubber wood (Hevea Brasiliensis) - Specification
149 IS 15455:2004 Grading rules for split canes
150 IS 15456:2004 Grading rules for unsplit canes
151 IS 15457:2004 Logs for production of sliced veneers - Specification (Superseding IS 5248:1988, IS 6342:1987, & IS 13240:1991)
152 IS 15458:2004 Classification of Indian canes and their zonal distribution
153 IS 15890:2010 Design, installation and testing of solar timber seasoning kiln- Guidelines
154 SP 33(S&T): 1986 Handbook on timber engineering
CED 11 DOORS, WINDOWS AND SHUTTERS
STANDARDS PUBLISHED
1 IS 1003(Part 1):2003 Timber panelled and glazed shutters: Part 1 Door Shutters - Specification (fourth revision)
2 IS 1003(Part 2):1994 Specification for timber panelled and glazed shutters: Part 2 Window and ventilator shutters (third revision)
3 IS 1038:1983 Specification for steel doors, windows and ventilators (third revision)
4 IS 1081:1960 Code of practice for fixing and glazing of metal (steel and aluminium) doors, windows and ventilators
5 IS 1361:1978 Specification for steel windows for industrial buildings (first revision)
6 IS 1948:1961 Specification for aluminium doors, windows and ventilators
7 IS 1949:1961 Specification for aluminium windows for industrial buildings
8 IS 2191(Part 1):1983 Specification for wooden flush door shutters (cellular and hollow core type): Part 1 Plywood face panels (fourth revision)
9 IS 2191(Part 2):1983 Specification for wooden flush door shutters (cellular and hollow core type): Part 2 Particle board and hardboard face panels (third revision)
10 IS 2202(Part 1):1999 Specification for wooden flush door shutters (solid core type): Part 1 Plywood face panels (sixth revision)
11 IS 2202(Part 2):1983 Specification for wooden flush door shutters (solid core type): Part 2 Particle board and hardboard face panels (third revision)
12 IS 4020(Part 1):1998 Door shutters - Methods of tests: Part 1 General (third revision)
13 IS 4020(Part 2):1998 Part 2 Measurement of dimensions and squareness (third revision)
14 IS 4020(Part 3):1998 Part 3 Measurement of general flatness (third revision)
15 IS 4020(Part 4):1998 Part 4 Local planeness test (third revision)
16 IS 4020(Part 5):1998 Part 5 Impact indentation test (third revision)
17 IS 4020(Part 6):1998 Part 6 Flexure test (third revision)
18 IS 4020(Part 7):1998 Part 7 Edge loading test (third revision)
19 IS 4020(Part 8):1998 Part 8 Shock resistance test (third revision)
20 IS 4020(Part 9):1998 Part 9 Buckling resistance test (third revision)
21 IS 4020(Part 10):1998 Part 10 Slamming test (third revision)
22 IS 4020(Part 11):1998 Part 11 Misuse test (third revision)
23 IS 4020(Part 12):1998 Part 12 Varying humidity test (third revision)
24 IS 4020(Part 13):1998 Part 13 End immersion test (third revision)
25 IS 4020(Part 14):1998 Part 14 Knife test (third revision)
26 IS 4020(Part 15):1998 Part 15 Glue adhesion test (third revision)
27 IS 4020(Part 16):1998 Part 16 Screw withdrawal resistance test (third revision)
28 IS 4021:1995 Timber door, window and ventilator frames - Specification
29 IS 4043:1969 Recommendations for symbolic designations of direction of closing and faces of doors, windows and shutters
30 IS 4351:2003 Steel door frames - Specification (second revision)
31 IS 4913:1968 Code of practice for selection, installation and maintenance of timber doors and windows
32 IS 6198:1992 Specification for ledged, braced and battened timber door shutters (second revision)
33 IS 6248:1979 Specification for metal rolling shutters and rolling grills (first revision)
34 IS 10428:1983 Glossary of terms relating to doors
35 IS 10451:1983 Specification for steel sliding shutters (top hung type)
36 IS 10521:1983 Specification for collapsible gates
37 IS 14856:2000 Glass fibre reinforced plastic (GRP) panel type door shutters for internal use - Specification
38 IS 15380:2003 Moulded raised high density fibre (HDF) panel doors - Specification
39 IS 15931:2012 Solid Panel Foam UPVC Door Shutters - Specification
40 IS 16073:2013 Bamboo - Jute Composite Panel Door Shutter - Specification
41 IS 16074:2013 Steel Flush Door Shutters - Specification
42 IS 16096:2013 Phenol Bonded Bamboo - Jute Composite Hollow Door Shutter - Specification
CED 12 FUNCTIONAL REQUIREMENTS IN BUILDINGS
STANDARDS PUBLISHED
1 IS 1950:1962 Code of practice for sound insulation of non-industrial buildings
2 IS 2440:1975 Guide for day lighting of buildings (second revision)
3 IS 2526:1963 Code of practice for acoustical design of auditoriums and conference halls
4 IS 3103:1975 Code of practice for industrial ventilation (first revision)
5 IS 3362:1977 Code of practice for natural ventilation of residential buildings
6 IS 3483:1965 Code of practice for noise reduction in industrial buildings
7 IS 3792:1978 Guide for heat insulation of non industrial buildings (first revision)
8 IS 4954:1968 Recommendations for noise abatement in town planning
9 IS 4963:1987 Recommendations for buildings and facilities for the physically handicapped (first revision)
10 IS 5499:1969 Code of practice for construction of underground air-raid shelters in natural soil
11 IS 6060:1971 Code of practice for day lighting of factory buildings
12 IS 6074:1971 Code of practice for functional requirements of hotels, restaurants and other food service establishments
13 IS 7662(Part 1):1974 Recommendations for orientation of buildings: Part 1 Non- industrial buildings
14 IS 7942:1976 Code of practice for day lighting of educational buildings
15 IS 8827:1978 Recommendations for basic requirements of school buildings
16 IS 9736:1981 Glossary of terms applicable to acoustics in buildings
17 IS 11050(Part 1):1984 Rating of sound insulation in buildings and of building elements: Part 1 Airborne sound insulation in buildings and of interior building elements
18 IS 11050(Part 2):1984 Rating of sound insulation in buildings and of building elements: Part 2 Impact sound insulation
19 IS 11050(Part 3):1984 Rating of sound insulation in buildings and of building elements: Part 3 Airborne sound insulation of facade elements
20 IS 11907:1986 Recommendations for calculation of solar radiation on buildings
21 IS 12332:1988 Code of practice for ventilation in petro-chemical plants and refineries
22 IS 13735:1993 Specification for audible emergency evacuation signal
23 SP 32(S&T): 1986 Handbook on functional requirements of industrial buildings (lighting and ventilation)
24 SP 41(S&T): 1987 Handbook on functional requirements of buildings (other than industrial buildings)
CED 13 BUILDING CONSTRUCTION PRACTICES
STANDARDS PUBLISHED
1 IS 883:1994 Code of practice for design of structural timber in building
2 IS 965:1963 Equivalent metric units for scales, dimensions and quantities in general construction work
3 IS 1414:1989 Code of practice for fixing of wall coverings (first revision)
4 IS 1477(Part 1):1971 Code of practice for painting of ferrous metals in buildings: Part 1 Pretreatment (first revision)
5 IS 1477(Part 2):1971 Code of practice for painting of ferrous metals in buildings: Part 2 Painting (first revision)
6 IS 1597(Part 1):1992 Code of practice for construction of stone masonry: Part 1 Rubble stone masonry (first revision)
7 IS 1597(Part 2):1992 Code of practice for construction of stone masonry: Part 2 Ashlar masonry (first revision)
8 IS 1634:1992 Code of practice for design and construction of wood stairs for houses (second revision)
9 IS 1649:1962 Code of practice for design and construction of flues and chimneys for domestic heating appliances
10 IS 1834:1984 Specification for hot applied sealing compound for joints in concrete (first revision)
11 IS 1838(Part 1):1983 Specification for preformed fillers for expansion joint in concrete pavement and structures (non extruding and resilient type): Part 1 Bitumen impregnated fibre (first revision)
12 IS 1838(Part 2):1984 Specification for preformed fillers for expansion joint in concrete pavement and structures (non extruding and resilient type) Part 2 CNSL Aldehyde resin and coconut pith
13 IS 1838(Part 3):2011 Preformed Fillers for Expansion Joints in Concrete Pavements and Structures (Non-Extruding and Resilient Type) - Specification: Part 3 Polymer Based
14 IS 1905:1987 Code of practice for structural use of unreinforced masonry
15 IS 1946:1961 Code of practice for use of fixing devices in walls, ceilings and floors of solid construction
16 IS 2110:1980 Code of practice for in-situ construction of walls in building with soil-cement (first revision)
17 IS 2115:1980 Code of practice for flat roof finish: Mud phuska (second revision)
18 IS 2116:1980 Specification for sand for masonry mortars (first revision)
19 IS 2118:1980 Code of practice for construction of jack-arch type of built-up floor or roof (first revision)
20 IS 2119:1980 Code of practice for construction of brick-cum-concrete composite (Madras terrace) floor and roof (first revision)
21 IS 2204:1962 Code of practice for construction of reinforced concrete shell
22 IS 2212:1991 Code of practice for brick works (first revision)
23 IS 2250:1981 Code of practice for preparation and use of masonry mortars
24 IS 2338(Part 1):1967 Code of practice for finishing of wood and wood-based materials: Part 1 Operations and workmanship
25 IS 2338(Part 2):1967 Code of practice for finishing of wood and wood-based materials: Part 2 Schedules
26 IS 2366:1983 Code of practice for nail-jointed timber construction (first revision)
27 IS 2395(Part 1):1994 Code of practice for painting of concrete, masonry and plaster surfaces: Part 1 Operations and workmanship (first revision)
28 IS 2395(Part 2):1994 Code of practice for painting of concrete, masonry and plaster surfaces: Part 2 Schedules (first revision)
29 IS 2441:1984 Code of practice for fixing ceiling coverings (first revision)
30 IS 2524(Part 1):1968 Code of practice for painting of non-ferrous metals in buildings: Part 1 Pretreatment
31 IS 2524(Part 2):1968 Code of practice for painting of non-ferrous metals in buildings: Part 2 Painting
32 IS 2527:1984 Code of practice for fixing rainwater gutters and downpipes for roof drainage (first revision)
33 IS 2700:1987 Code of practice for roofing with wooden shingles (first revision)
34 IS 2792:1964 Code of practice for design and construction of stone slab over joist floor
35 IS 2858:1984 Code of practice for roofing with mangalore tiles (first revision)
36 IS 3140:1965 Code of practice for painting asbestos cement building products
37 IS 3414:1968 Code of practice for design and installation of joints in buildings
38 IS 3548:1988 Code of practice for glazing in buildings (first revision)
39 IS 3629:1986 Specification for structural timber in building (first revision)
40 IS 3630:1992 Code of practice for construction of non-load bearing gypsum block partitions (first revision)
41 IS 3670:1989 Code of practice for construction of timber floors (first revision)
42 IS 4101(Part 1):1967 Code of practice for external facings and veneers: Part 1 Stone facing
43 IS 4101(Part 2):1967 Code of practice for external facings and veneers: Part 2 Cement concrete facing
44 IS 4101(Part 3):1985 Code of practice for external cladding: Part 3 Wall tiling and mosaics (first revision)
45 IS 4407:1967 Code of practice for reed walling
46 IS 4597:1968 Code of practice for finishing of wood and wood based products with nitrocellulose and cold catalysed materials
47 IS 4891:1988 Specification for preferred cut sizes of structural timber
48 IS 4920:1968 Glossary of terms applicable to roof coverings
49 IS 4924(Part 1):1968 Method of test for nail jointed timber trusses: Part 1 Destructive test
50 IS 4924(Part 2):1968 Method of test for nail jointed timber trusses: Part 2 Proof test
51 IS 4983:1968 Code of practice for design and construction of nailed laminated timber beams
52 IS 5119(Part 1):1968 Code of practice for laying and fixing of sloped roof covering: Part 1 Slating
53 IS 5389:1969 Code of practice for laying of hardwood parquet and wood block floors
54 IS 5390:1984 Code of practice for construction of timber ceilings (first revision)
55 IS 6061(Part 1):1971 Code of practice for construction of floor and roof with joists and filler blocks: Part 1 With hollow concrete filler blocks
56 IS 6061(Part 2):1981 Code of practice for construction of floor and roof with joists and filler blocks: Part 2 With hollow clay filler blocks (first revision)
57 IS 6061(Part 3):1981 Code of practice for construction of floor and roof with joists and filler blocks: Part 3 With precast hollow clay block joists and hollow clay filler blocks
58 IS 6061(Part 4):1981 Code of practice for construction of floor and roof with joists and filler blocks: Part 4 With precast hollow clay block slab
59 IS 6313(Part 1):1981 Code of practice for anti-termite measures in buildings: Part 1 Constructional measures (first revision)
60 IS 6313(Part 2):2013 Code of practice for anti-termite measures in buildings: Part 2 Pre-constructional chemical treatment measures (third revision)
61 IS 6313(Part 3):2013 Code of practice for anti-termite measures in buildings: Part 3 Treatment for existing buildings (third revision)
62 IS 6332:1984 Code of practice for construction of floors and roofs using precast doubly-curved shell units (first revision)
63 IS 6509:1985 Code of practice for installation of joints in concrete pavements (first revision)
64 IS 7683:1975 Code of practice for design, fabrication and maintenance of nail-jointed timber posts from small dimensional timber for overhead electric distribution lines for low voltages
65 IS 9472:1980 Code of practice for laying mosaic parquet flooring
66 IS 9954:1981 Pictorial surface preparation standards for painting of steel surfaces
67 IS 10388:1982 Specification for corrugated coir, wood, wool, cement roofing
68 IS 10439:1983 Code of practice for patent glazing
69 IS 10440:1983 Code of practice for construction of RB and RBC floors and roofs
70 IS 10566:1983 Methods of tests for preformed fillers for expansion joints in concrete paving and structural construction
71 IS 10957:1999 Joints in buildings - Vocabulary (first revision)
72 IS 10958:1984 General check list of functions of joints in building
73 IS 10959:1984 Glossary of terms for sealants for building purposes
74 IS 11096:1984 Code of practice for design and construction of bolt jointed timber construction
75 IS 11134:1984 Code of practice for setting out of buildings
76 IS 11433(Part 1):1985 Specification for one-part gun-grade polysulphide-based joints sealants: Part 1 General requirements
77 IS 11433(Part 2):1986 Specification for one-part gun-grade polysulphide-based joint sealants: Part 2 Methods of tests
78 IS 11817:1986 Classification of joints in buildings for accommodation of dimensional deviations during construction
79 IS 11818:1986 Method of test for laboratory determination of air permeability of joints in buildings
80 IS 12093:1987 Code of practice for laying and fixing of sloped roof covering using plain and corrugated galvanized steel sheets
81 IS 12118(Part 1):1987 Specification for two-parts polysulphide-based sealants: Part 1 General requirements
82 IS 12118(Part 2):1987 Specification for two-parts polysulphide-based sealants: Part 2 Methods of tests
83 IS 12506:1988 Code of practice for improved thatching of roof with rot and fire retardant treatment
84 IS 12727:1989 Code of practice for no-fines cast in situ cement concrete
85 IS 13077:1991 Guide for preparation and use of mud mortar in masonry
86 IS 14428:1997 Painting of structures in aggressive chemical environment - Guidelines
87 IS 15183(Part 1):2002 Guidelines for maintenance management of buildings: Part 1 General
88 IS 15183(Part 2):2002 Guidelines for maintenance management of buildings: Part 2 Finance
89 IS 15183(Part 3):2002 Guidelines for maintenance management of buildings: Part 3 Labour
90 IS 15345:2003 Installation of frameless door and window shutters - Code of practice
91 IS 15912:2012 Structural design using bamboo - Code of Practice
92 SP 1650: 1973 Standard colours for building and decorative finishes (with supplement) (first revision)
93 SP 20(S&T): 1991 Handbook on masonry design and construction (first revision)
94 SP 21: 2005 Summaries of Indian Standards for Building Materials (first revision)
95 SP 25(S&T): 1984 Handbook on causes and prevention of cracks in building
96 SP 62(S&T): 1997 Handbook on building construction practices (excluding electrical work)
CED 15 BUILDER'S HARDWARE
STANDARDS PUBLISHED
1 IS 204(Part 1):1991 Specification for tower bolts : Part 1 Ferous metals (fifth revision)
2 IS 204(Part 2):1992 Specification for tower bolts: Part 2 Non-ferrous metals (fifth revision)
3 IS 205:1992 Specification for non-ferrous metal butt hinges (fourth revision)
4 IS 206:2010 Specification for tee and strap hinges (fifth revision)
5 IS 208:1996 Specification for door handles (fifth revision)
6 IS 281:2009 Specification for mild steel sliding door bolts for use with padlocks (fourth revision)
7 IS 362:1991 Specification for parliament hinges (fifth revision)
8 IS 363:1993 Specification for hasps and staples (fourth revision)
9 IS 364:1993 Specification for fanlight catch (third revision)
10 IS 452:1973 Specification for door springs, rat-tail type (second revision)
11 IS 453:1993 Specification for double acting spring hinges (third revision)
12 IS 1019:1974 Specification for rim latches (second revision)
13 IS 1341:1992 Specification for steel butt hinges (fifth revision)
14 IS 1823:1980 Specification for floor door stoppers (third revision)
15 IS 1837:1966 Specification for fanlight pivots (first revision)
16 IS 2681:1993 Specification for non-ferrous metal sliding door bolts (aldrops) with padlocks (third revision)
17 IS 3564:1995 Specification for (hydraulically regulated) door closers (fourth revision)
18 IS 3818:1992 Specification for continuous (Piano) hinges (third revision)
19 IS 3828:1966 Specification for ventilator chains
20 IS 3843:1995 Specification for steel back flap hinges (second revision)
21 IS 4621:1975 Specification for indicating bolts for use in public baths and lavatories (first revision)
22 IS 4992:1975 Specification for door handles for mortice lock(vertical type)
23 IS 5187:1972 Specification for flush bolts (first revision)
24 IS 5899:1970 Specification for bathroom latches
25 IS 6315:1992 Specification for floor springs (hydraulically regulated) for heavy doors (second revision)
26 IS 6318:1971 Specification for plastic window stays and fasteners
27 IS 6343:1982 Specification for door closers (pneumatically regulated) for light doors weighing up to 40 kg (first revision)
28 IS 7196:1974 Specification for hold fast
29 IS 7197:1974 Specification for double action floor springs (without oil check) for heavy door
30 IS 7534:1985 Specification for sliding locking bolts for use with padlocks (first revision)
31 IS 8756:1978 Specification for mortice ball catches for use in wooden almirah
32 IS 9106:1979 Specification for rising butt hinges
33 IS 9460:1980 Specification for flush drop handles for drawer
34 IS 9899:1981 Specification for hat, coat and wardrobe hooks
35 IS 10019:1981 Specification for mild steel stays and fasteners
36 IS 10090:1982 Specification for numericals
37 IS 10342:1982 Specification for curtain rail system
38 IS 12817:2013 Specification for stainless steel butt hinges (second revision)
39 IS 12867:1989 Specification for PVC hand rails covers
40 IS 14912:2001 Specification for door closers concealed type (hydraulically regulated)
41 IS 15833:2009 Stainless steel tower bolts - Specification
42 IS 15834:2008 Stainless steel sliding door bolts for use with padlocks - Specification
CED 20 WOOD AND OTHER LIGNOCELLULOSIC PRODUCTS
STANDARDS PUBLISHED
1 IS 303:1989 Specification for plywood for general purposes (third revision)
2 IS 652:1960 Specification for wooden separators for lead-acid storage batteries
3 IS 709:1974 Specification for medium strength aircraft plywood (first revision)
4 IS 710:2010 Specification for marine plywood (second revision)
5 IS 848:2006 Specification for synthetic resin adhesives for plywood (pnenolic and aminoplastic) (second revision)
6 IS 851:1978 Specification for synthetic resin adhesives for construction work (non-structural) in wood (first revision)
7 IS 852:1994 Specification for animal glue for general wood-working purposes (second revision)
8 IS 1328:1996 Specification for veneered decorative plywood (third revision)
9 IS 1508:1972 Specification for extenders for use in synthetic resin adhesives(urea-formaldehyde) for plywood (first revision)
10 IS 1658:2006 Specification for fibre hardboards (third revision)
11 IS 1659:2004 Specification for block boards (fourth revision)
12 IS 1734(Part 1):1983 Methods of test for plywood: Part 1 Determination of density and moisture content (second revision)
13 IS 1734(Part 2):1983 Methods of test for plywood : Part 2 Determination of resistance to dry heat (second revision)
14 IS 1734(Part 3):1983 Methods of test for plywood: Part 3 Determination of fire resistance (second revision)
15 IS 1734(Part 4):1983 Methods of test for plywood: Part 4 Determination of glue shear strength (second revision)
16 IS 1734(Part 5):1983 Methods of test for plywood: Part 5 Test for adhesion of plies
17 IS 1734(Part 6):1983 Methods of test for plywood: Part 6 Determination of water resistance (second revision)
18 IS 1734(Part 7):1983 Methods of test for plywood: Part 7 Mycological test (second revision)
19 IS 1734(Part 8):1983 Methods of test for plywood: Part 8 Determination of pH value
20 IS 1734(Part 9):1983 Methods of test for plywood: Part 9 Determination of tensile strength (second revision)
21 IS 1734(Part 10):1983 Methods of test for plywood: Part 10 Determination of compressive strength (second revision)
22 IS 1734(Part 11):1983 Methods of test for plywood: Part 11 Determination of static bending strength (second revision)
23 IS 1734(Part 12):1983 Methods of test for plywood: Part 12 Determination of scarf joint strength (second revision)
24 IS 1734(Part 13):1983 Methods of test for plywood: Part 13 Determination of panel shear strength (second revision)
25 IS 1734(Part 14):1983 Methods of test for plywood: Part 14 Determination of plate shear strength (second revision)
26 IS 1734(Part 15):1983 Methods of test for plywood: Part 15 Central loading of plate test (second revision)
27 IS 1734(Part 16):1983 Methods of test for plywood: Part 16 Vibration of plywood plate test (second revision)
28 IS 1734(Part 17):1983 Methods of test for plywood: Part 17 Long time loading test of plywood strips (second revision)
29 IS 1734(Part 18):1983 Methods of test for plywood: Part 18 Impact resistance test on the surface of plywood (second revision)
30 IS 1734(Part 19):1983 Methods of test for plywood: Part 19 Determination of nail and screw holding power (second revision)
31 IS 1734(Part 20):1983 Methods of test for plywood: Part 20 Acidity and alkalinity resistance test (second revision)
32 IS 2380(Part 1):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 1 Preparation and conditioning of test specimens (first revision)
33 IS 2380(Part 2):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 2 Accuracy of dimensions of boards (first revision)
34 IS 2380(Part 3):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 3 Determination of moisture content and density (first revision)
35 IS 2380(Part 4):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 4 Determination of static bending strength (first revision)
36 IS 2380(Part 5):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 5 Determination of tensile strength perpendicular to surface (first revision)
37 IS 2380(Part 6):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 6 Determination of tensile strength parallel to surface (first revision)
38 IS 2380(Part 7):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 7 Determination of compression- perpendicular to plane of the board (first revision)
39 IS 2380(Part 8):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 8 Compression parallel to surface test (first revision)
40 IS 2380(Part 9):1977 Methods of test for wood particle boards and boards from other lignocellolosic materials: Part 9 Determination of resistance to shear in plane of the board (first revision)
41 IS 2380(Part 10):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 10 Falling hammer impact test
42 IS 2380(Part 11):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 11 Surface hardness (first revision)
43 IS 2380(Part 12):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 12 Central loading of plate test
44 IS 2380(Part 13):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 13 Long time loading bending test (first revision)
45 IS 2380(Part 14):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 14 Screw and nail withdrawal test (first revision)
46 IS 2380(Part 15):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 15 Lateral nail resistance (first revision)
47 IS 2380(Part 16):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 16 Determination of water absorption (first revision)
48 IS 2380(Part 17):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 17 Determination of swelling in water (first revision)
49 IS 2380(Part 18):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 18 Determination of mass and dimensional changes caused by moisture changes (first revision)
50 IS 2380(Part 19):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 19 Durability cyclic test for interior use (first revision)
51 IS 2380(Part 20):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 20 Accelerated weathering cyclic test for exterior use (first revision)
52 IS 2380(Part 21):1977 Methods of test for wood particle boards and boards from other lignocellulosic materials: Part 21 Planeness test under uniform moisture content (first revision)
53 IS 2380(Part 22):1981 Method of test for wood particle boards and boards from other lignocellulosic materials: Part 22 Determination of surface glueability test
54 IS 2380(Part 23):1981 Method of test for wood particle boards and boards from other lignocellulosic materials: Part 23 Vibration tests for particle boards
55 IS 3087:2005 Specification for particle boards of wood and other lignocellulosic materials (medium density) for general purposes
56 IS 3097:2006 Specification for veneered particle boards (second revision)
57 IS 3129:1985 Specification for low density particle boards (first revision)
58 IS 3308:1981 Specification for wood wool building slabs (first revision)
59 IS 3348:1965 Specification for fibre insulation boards
60 IS 3478:1966 Specification for high density wood particle boards
61 IS 3513(Part 1):1989 Specification for resin treated compressed wood laminates (compregs) Part 1 For electrical purposes (first revision)
62 IS 3513(Part 2):1989 Specification for resin treated compressed wood laminates (compregs) Part 2 For chemical purposes (first revision)
63 IS 3513(Part 3):1989 Specification for resin treated compressed wood laminates (compregs): Part 3 For general purposes (first revision)
64 IS 3513(Part 4):1966 Specification for resin treated compressed wood laminates (compreg): Part 4 Sampling and tests
65 IS 4834:1968 Specification for veneered wood boards for packing cases
66 IS 4835:1979 Specification for polyvinyl acetate dispersion based adhesives for wood (First revision)
67 IS 4859:1968 Specification for high strength aircraft plywood
68 IS 4990:2011 Plywood for concrete shuttering work - Specification (third revision)
69 IS 5509:2000 Specification for fire retardant plywood (second revision)
70 IS 5539:1969 Specification for preservative treated plywood
71 IS 7316:1974 Specification for decorative plywood using plurality of veneers for decorative faces
72 IS 7638:1999 Wood/lignocellulosic based panel products - Methods of sampling (second revision)
73 IS 9188:1979 Performance requirements for adhesive for structural laminated wood products for use under exterior exposure condition
74 IS 9307(Part 1):1979 Methods of test for wood based structural sandwich construction: Part 1 Flexure test
75 IS 9307(Part 2):1979 Methods of test for wood based structural sandwich construction : Part 2 Edgewise compression test
76 IS 9307(Part 3):1979 Methods of test for wood based structural sandwich construction: Part 3 Flat wise compression test
77 IS 9307(Part 4):1979 Methods of test for wood based structural sandwich construction: Part 4 Shear test
78 IS 9307(Part 5):1979 Methods of test for wood based structural sandwich construction: Part 5 Flatwise tension test
79 IS 9307(Part 6):1979 Methods of test for wood based structural sandwich construction: Part 6 Flexure creep test
80 IS 9307(Part 7):1979 Methods of test for wood based structural sandwich construction: Part 7 Cantilever vibration test
81 IS 9307(Part 8):1979 Methods of test for wood based structural sandwich construction: Part 8 Weathering test
82 IS 10701:2012 Structural plywood - Specification (first revision)
83 IS 12053:1987 Code of practice for the preparation and application of putty for repairing plywood and other wood based panels
84 IS 12077:1987 Code of practice for testing of timbers for plywood manufacture
85 IS 12120:1987 Code of practice for preservation of plywood and other panel products
86 IS 12406:2003 Specification for medium density fibre boards for general purposes
87् IS 12823:2013 Wood products - Prelaminated particle boards - Specification
88 IS 13745:1993 Method for determination of formaldehyde content in particle board by extraction method called perforator method
89 IS 13957:1994 Specification for metal faced plywood
90 IS 13958:1994 Specification for bamboo mat board for general purposes
91 IS 14276:1995 Specification for cement bonded particle boards
92 IS 14315:1995 Specification for commercial veneers
93 IS 14587:1998 Specification for prelaminated medium density fibre board
94 IS 14588:1999 Specification for bamboo mat veneer composite for general purposes
95 IS 14616:1999 Specification for laminated veneer lumber
96 IS 14842:2000 Specification for coir veneer board for general purposes
97 IS 15476:2004 Bamboo mat corrugated sheets - Specification
98 IS 15491:2004 Specification for medium density, coir boards for general purposes May 2009 1
99 IS 15512:2004 Code of practice for selection and use of various types for medium density fibre boards
100 IS 15684:2006 Code of practice for use of extenders for use in synthetic resin adhesive (urea formaldehyde) for plywood
101 IS 15786:2008 Prelaminated cement bonded particle boards - Specification
102 IS 15791:2007 Musuem plywood - Specification
103 IS 15877:2010 Coir faced block boards - Specification
104 IS 15878:2010 Coir hardboard for general purposes - Specification
105 IS 15932(Part 1):2012 Selection and use of various types of Lignocellulosic panel products: Part 1 Medium Density Particle Boards - Code of practice
106 IS 15972:2012 Bamboo-Jute corrugated & Semi-corrugated sheets - Specification
107 IS 15973:2013 Selection and use of various types of Lignocellulosic panel products: Part 2 Hardboard्-्Code of practice
108 IS 16171:2014 Veneer laminated lumber - Specification
CED 22 FIRE FIGHTING
STANDARDS PUBLISHED
1 IS 884:1985 Specification for first-aid hose reel for fire fighting (first revision)
2 IS 901:1988 Specification for couplings, double male and double female, instantaneous pattern for fire fighting (third revision)
3 IS 902:1992 Specification for suction hose couplings for fire fighting purposes (third revision)
4 IS 903:1993 Specification for fire hose delivery couplings, branch pipe, nozzles and nozzlespanner (fourth revision)
5 IS 904:1983 Specification for 2-way and 3-way suction collecting heads for fire fighting purposes (second revision)
6 IS 905:1980 Specification for delivery breechings, dividing and collecting instantaneous pattern for fire fighting purposes (second revision)
7 IS 906:1988 Specification for revolving branch pipe for fire fighting
8 IS 907:1984 Specification for suction strainers, cylindrical type for fire fighting purposes (second revision)
9 IS 908:1975 Specification for fire hydrant, stand post type (second revision)
10 IS 909:1992 Specification for underground fire hydrant, sluice valve type
11 IS 910:1980 Specification for combined key for hydrant, hydrant cover and lower valve (second revision)
12 IS 926:1985 Specification for fireman's axe (second revision)
13 IS 927:1981 Specification for fire hooks (second revision)
14 IS 928:1984 Specification for fire bells (second revision)
15 IS 937:1981 Specification for washers for water fittings for fire fighting purposes (second revision)
16 IS 939:1977 Specification for snatch block for use with fibre rope for fire brigade use (first revision)
17 IS 941:1985 Specification for blower and exhauster for fire fighting
18 IS 942:1982 Functional requirements for 275 l/min portable pump set for fire fighting (second revision)
19 IS 943:1979 Functional requirements for 680-l/min trailer pump for fire brigade use (second revision)
20 IS 944:1979 Functional requirements for 1800-l/min trailer pump for fire brigade use (second revision)
21 IS 947:1985 Functional requirements for towing tender for trailer fire pump for fire brigade use (first revision)
22 IS 948:1983 Functional requirements for water tender type `A' for fire brigade use (second revision)
23 IS 949:2012 Functional requirements for emergency (rescue) tender for fire brigade use (second revision)
24 IS 950:2012 Functional requirements for water tender, Type B for fire brigade use (third revision)
25 IS 951:2003 Functional requirements for crash tender for air fields (fourth revision)
26 IS 952:2012 Specification for fognozzle for fire brigade use (second revision)
27 IS 955:1980 Functional requirements for dry powder tender for fire brigade use (150 kg capacity) (first revision)
28 IS 956:2004 Functional requirements for rescue tender for air fields
29 IS 957:1967 Specification for control van for fire brigade use
30 IS 1941(Part 1):1976 Functional requirements for electric motor sirens: Part 1 AC, 3 Phase 50 hz, 415 volts type (second revision)
31 IS 2097:2012 Specification for foam making branch pipe (second revision)
32 IS 2175:1988 Specification for heat sensitive fire detectors for use in automatic fire alarm system (second revision)
33 IS 2189:2008 Code of practice for selection, installation and maintenance of automatic fire detection and alarm system (fourth revision)
34 IS 2190:2010 Selection, installation and maintenance of first-aid fire extinguishers - Code of practice (fourth revision)
35 IS 2546:1974 Specification for galvanized mild steel fire bucket (first revision)
36 IS 2696:1974 Functional requirements for 1125-l/min light fire engine (first revision) (Superseding IS 938)
37 IS 2745:1983 Specification for non-metal helmet for firemen and civil defence personnel (second revision)
38 IS 2871:2012 Specification for branch pipe, universal for fire fighting purposes (second revision)
39 IS 2878:2004 Specification for fire extinguisher, carbon dioxide type(portable and trolley mounted ) (third revision)
40 IS 2925:1984 Specification for industrial safety helmets (second revision)
41 IS 2930:1980 Functional requirements for hose laying tender for fire brigade use (first revision)
42 IS 3582:1984 Specification for basket strainers for fire fighting purposes (cylindrical type) (first revision)
43 IS 3744:1985 Specification for hose binding machine (first revision)
44 IS 3844:1989 Code of practice for installation and maintenance of internal fire hydrants and hose reels on premises (first revision)
45 IS 4151:1993 Specification for protective helmets for motorcycle riders (third revision)
46 IS 4308:2003 Specification for dry chemical powder for fighting B and C Class fires (second revision)
47 IS 4571:1977 Specification for aluminium extension ladders for fire brigade use (first revision)
48 IS 4643:1984 Specification for suction wrenches for fire brigade use
49 IS 4861:1984 Specification for dry powder for fighting fires in burning metals
50 IS 4862(Part 1):1986 Specification for portable fire extinguishers for aircraft : Part 1 Halon 1211 Type (first revision)
51 IS 4927:1992 Specification for unlined flax canvas hose for fire fighting
52 IS 4928:1986 Specification for delivery valve for centrifugal fire pump outlets(first revision)
53 IS 4947:2006 Specification for gas cartridges for use in fire extinguishers
54 IS 4989:2006 Foam concentrate for producing mechanical foam for fire fighting - Specification (third revision) [Amalgamating IS 4989(Part 1):1985, IS 4989(Part 2):1984 and IS 4989(Part 3):1987]
55 IS 4989(Part 4):2003 Specification for multipurpose aqueous film forming foam liquid concentrate for extinguishing hydrocarbon and polar solvent fires
56 IS 5131:2002 Specification for dividing breeching with control for fire brigade use (second revision)
57 IS 5290:1993 Specification for landing valves (third revision)
58 IS 5486:1985 Specification for quick release knife (first revision)
59 IS 5505:1985 Specification for multi-edged rescue axe (non-wedging)
60 IS 5612(Part 1):1977 Specification for hose-clamps and hose-bandages for fire brigade use: Part 1 Hose-clamps (first revision)
61 IS 5612(Part 2):1977 Specification for hose-clamps and hose bandages for fire brigade use: Part 2 Hose bandages (first revision)
62 IS 5714:1981 Specification for hydrant, stand-pipe for fire fighting
63 IS 5888:1970 Code of practice for design and construction of fire service drill- tower
64 IS 5896(Part 1):1970 Code of practice for selection, operation and maintenance of special fire fighting appliances: Part 1 Combined foam and CO2 crash tender
65 IS 5896(Part 3):1975 Code of practice for selection, operation and maintenance of fire fighting appliances: Part 3 Turntable ladders
66 IS 6026:1985 Specification for hand-operated sirens (first revision)
67 IS 6067:1983 Functional requirements for water tender type `X' for fire brigade use(first revision)
68 IS 6070:1983 Code of practice for selection, operation and maintenance of trailer fire pumps, portable pumps, water tenders and motor fire engines (first revision)
69 IS 7673:2004 Glossary of terms for fire fighting equipment (first revision)
70 IS 7692:1993 Specification for head forms for testing of helmets (first revision)
71 IS 8090:1976 Specification for couplings, branch pipe, nozzle, used in hose reel tubing for fire fighting
72 IS 8096:1992 Specification for fire beaters (first revision)
73 IS 8149:1994 Functional requirements for twin CO2 fire extinguishers (trolley mounted)(first revision)
74 IS 8423:1994 Specification for controlled percolating hose for fire fighting
75 IS 8442:2008 Functional requirements for stand post type water monitor for fire fighting (first revision)
76 IS 9562:1980 Specification for non-metal helmet for police force
77 IS 9668:1990 Code of practice for provision and maintenance of water supplies and fire fighting (first revision)
78 IS 9695:1980 Methods of sampling of helmets
79 IS 9972:2002 Specification for automatic sprinkler heads for fire protection service (first revision)
80 IS 9973:1981 Specification for visor for scooter helmets
81 IS 9995:1981 Specification for visor for non-metal police and firemen's
82 IS 10460:1983 Functional requirements for small foam tender for fire brigade
83 IS 10658:1999 Specification for higher capacity dry powder fire extinguisher (trolley mounted) (first revision)
84 IS 10993:1984 Functional requirements for 2000-kg dry powder tender for fire brigade use
85 IS 11101:1984 Specification for extended branch pipe for fire brigade use
86 IS 11108:1984 Specification for portable fire extinguisher halons-1211 type
87 IS 11360:1985 Specification for smoke detectors for use in automatic electrical fire alarm system
88 IS 11833:1986 Specification for dry powder fire extinguisher for metal fires
89 IS 12717:1989 Functional requirements of fire fighting equipment - High capacity portable pumpset (1100-1600 L/min)
90 IS 12796:1989 Specification for fire rake
91 IS 12805:1989 Tool Mcleod for fighting forest fires
92 IS 12835(Part 1):1989 Code of practice for design and installation of fixed foam fire extinguishing system: Part 1 Low expansion foam
93 IS 12853:1989 Specification for pulaski tool for forest fires
94 IS 12859:1989 Specification for brush hook for forest fires
95 IS 12861:1989 Specification for double bit axe for forest fires
96 IS 12862:1989 Specification for fire fighting shovel for forest fires
97 IS 13039:1991 Code of practice for external hydrant systems provision and maintenance
98 IS 13385:1992 Specification for fire extinguisher- 50 litre capacity wheel mounted water type (Gas Cartridge)
99 IS 13386:1992 Specification for fire extinguisher 50 litre capacity mechanical foam type
100 IS 14609:1999 Specification for dry chemical powder for fighting ABC Class
101 IS 14851:2000 Code of practice for maintenance of fire hose
102 IS 14933:2001 Specification for high pressure fire fighting hose
103 IS 14951:2001 Specification for fire extinguisher, 135 litre capacity mechanical foam type
104 IS 15051:2001 High pressure fire hose delivery couplings - Specification
105 IS 15105:2002 Design and installation of fixed automatic sprinkler fire extinguishing systems – Code of Practice
106 IS 15220:2002 Specification for halon 1211 and halon 1301 - halogented hydrocarbon - fire extinguishing media for fire protection
107 IS 15221:2002 Code of practice for safe handling and transfer procedure of halon 1121 and halon 1301- (halogonated hydrocarbon) - fire extinguishing media
108 IS 15222:2002 Specification for carbon-dioxide as fire extinguishing media for fire protection
109 IS 15301:2003 Code of practice for installation and maintenance of fire fighting pump
110 IS 15325:2003 Code of practice for design and installation of fixed automatic high and medium velocity water spray system
111 IS 15493:2004 Gaseous fire extinguishing systems - General requirements
112 IS 15496:2004 Inspection and maintenance of gaseous fire extinguishing systems - Code of practice
113 IS 15497:2004 Gaseous fire extinguishing systems IG 01 extinguishing systems
114 IS 15501:2004 Gaseous fire extinguishing systems IG 541 extinguishing
115 IS 15505:2004 Gaseous fire extinguishing systems - HCFC Blend A extinguishing systems
116 IS 15506:2004 Gaseous fire extinguishing systems - IG 55 - extinguishing systems
117 IS 15517:2004 Gaseous fire extinguishing systems - HFC 227ea (Hepta Fluoro Propane) extinguishing systems
118 IS 15519:2004 Water mist fire protection systems - System design, installation and commissioning - Code of practice
119 IS 15525:2004 Gaseous fire extinguishing systems - IG 100 extinguishing
120 IS 15528:2004 Gaseous fire extinguishing systems - Carbon dioxide total flooding and local application (Sub-floor and in-cabinet), high and low pressure (refrigerated) systems
121 IS 15682:2006 Fire fighting vehicle and equipment - Symbols for operator controls and other display
122 IS 15683:2006 Portable fire extinguishers - Performance and construction - Specification
123 IS 15811:2008 Long-range water-cum-foam monitor with self-inducting, aspirating and non-aspirating jet and spray/fog nozzle for fire fighting - Specification
124 IS 15821:2008 Gaseous fire extinguishing system - Physical properties and system design - CF3I Extinguishant
125 IS 15835:2009 Gaseous Fire Extinguishing Systems HCFC - 125 Extinguishing Systems
126 IS 15908:2011 Selection, installation and maintenance of control and indicating equipments for fire detection and alarm system - Code of Practice
127 IS 16018:2012 Wheeled fire extinguisher - Performance and construction - Specification
128 IS 16088:2012 Chlorinated polyvinyl chloride (CPVC) pipes for automatic sprinkler fire extinguishing system - Specification
129 IS 16095:2013 Hazmat vehicle - Specification
130 IS 16109:2013 Turntable Ladder - Specification
131 IS / ISO 6182-7 :2004 Fire Protection - Automatic Sprinkler Systems Part 7 Requirements and Test Method for Early Suppression Fast Response (ESFR) Sprinklers
132 IS/ ISO 7240-5 :2003 Fire Detection and Alarm Systems Part 5 Point-Type Heat Detectors
133 IS/ ISO 7240-7 :2011 Fire Detection and Alarm Systems Part 7 Point-Type Smoke Detectors using Scattered Light, Transmitted light or Ionization
134 IS/ ISO 7240-11 :2011 Fire Detection and Alarm Systems Part 11 Manual Call Points
135 IS/ ISO 7240-15 :2004 Fire Detection and Alarm Systems Part 15 Point-Type Fire Detectors using Scattered Light, Transmitted light or Ionization Sensor in Combination with a Heat Sensor
CED 24 PUBLIC HEALTH ENGINEERING
STANDARDS PUBLISHED
1 IS 1172:1993 Code of basic requirements for water supply, drainage and sanitation (fourth revision)
2 IS 1742:1983 Code of practice for building drainage (second Revision)
3 IS 2064:1993 Code of practice for selection, installation and maintenance of sanitary appliances (second Revision)
4 IS 2065:1983 Code of practice for water supply in buildings
5 IS 2470(Part 1):1985 Code of practice for installation of septic tanks: Part I design, criteria and construction (second revision)
6 IS 2470(Part 2):1985 Code of practice for installation of septic tanks: Part 2 Secondary treatment and disposal of septic tank effluent
7 IS 3114:1994 Code of practice for laying of cast iron pipes (second revision)
8 IS 4111(Part 1):1986 Code of practice for ancillary structures in sewerage system: Part I Manholes (first revision)
9 IS 4111(Part 2):1985 Code of practice for ancillary structures in sewerage system: Part II Flusing tanks (first revision)
10 IS 4111(Part 3):1985 Code of practice for ancillary structures in sewerage system: Part III Inverted syphon (first revision)
11 IS 4111(Part 4):1968 Code of practice for ancillary structures in sewerage system: Part 4 Pumping stations and pumping mains (rising mains)
12 IS 4111(Part 5):1993 Code of practice for ancillary structures in sewerage system: Part 5 Tidal outfalls
13 IS 4127:1983 Code of practice for laying of glazed stoneware pipes (first revision)
14 IS 5329:1983 Code of practice for sanitary pipe work above ground for buildings (first revision)
15 IS 5611:1987 Code of practice for construction of waste stabilization ponds (faculative type) (first revision)
16 IS 5822:1994 Code of practice for laying of electrically welded steel pipes for water supply (second revision)
17 IS 6279:1971 Specification for equipment for grit removal devices
18 IS 6280:1971 Specification for sewage screens
19 IS 6295:1986 Code of practice for water supply and drainage in high altitudes and/or sub-zero temperature regions (first revision)
20 IS 6924:1973 Code of practice for the construction of refuse chutes in multistoreyed buildings
21 IS 7090:1985 Guidelines for rapid mixing devices (first revision)
22 IS 7208:1992 Guidelines for flocculator devices (first revision)
23 IS 7232:1974 Method for imhoff cone test
24 IS 7558:1974 Code of practice for domestic hot water installations
25 IS 7740:1985 Code of practice for construction and maintenance of road gullies (first revision)
26 IS 8413(Part 1):1977 Requirements for biological treatment equipment: Part 1 Trickling filters
27 IS 8413(Part 2):1982 Requirements for biological treatment and equipment: Part 2 Activated sludge process and its modifications
28 IS 8419(Part 1):1977 Requirements for filtration equipment : Part 1 Filtration media - sand and gravel
29 IS 8419(Part 2):1984 Requirements for rapid sand gravity filtration equipment: Part 2 Under drainage system
30 IS 9110:1979 Specification for hand operated augers for cleaning water- closets pipes and sewers
31 IS 9222(Part 1):1990 Recommendations for handling and dosing devices for chemicals for water treatment: Part I Coagulants (first revision)
32 IS 10037(Part 1):1981 Requirements for sludge dewatering equipment: Part I Sludge drying beds-sand, gravel and under drains
33 IS 10037(Part 2):1983 Requirements for sludge de-watering equipment: Part 2 Vacuum filtration equipment
34 IS 10037(Part 3):1983 Requirements for sludge de-watering equipment: Part 3 Centrifugal equipment (Solid bowl type)
35 IS 10053:1981 Requirements for equipment for jackson candle turbidimeter and determination of turbidity
36 IS 10261:1982 Requirements for settling tank (clarifier equipment) for waste water treatment
37 IS 10313:1982 Requirements for settling tank (clarifier equipment) for water treatment plant
38 IS 10446:1983 Glossary of terms relating to water supply and sanitation
39 IS 10552:1983 Specification for buckets to be used in power driven bucket type sewer cleaning machine
40 IS 10553(Part 1):1983 Requirements for chlorination equipment: Part I General guidelines for chlorination plants including handling, storage and safety of chlorine cylinders and drums
41 IS 10553(Part 2):1983 Requirements for chlorination equipment: Part 2 Vacuum feed type chlorinators
42 IS 10553(Part 4):1983 Requirements for chlorination equipment: Part 4 Gravity feed type gaseous chlorinators
43 IS 10553(Part 5):1987 Requirements of chlorination equipment: Part 5 Bleaching powder solution feeder displacement type chlorinator
44 IS 10595:1983 Requirements for power driven bucket-type sewer cleaning machine
45 IS 11117:1984 Requirements for power driven rodding machine for sewers
46 IS 11208:1985 Guidelines for registration of plumbers
47 IS 11387:1985 Requirements for high pressure jetting machine for sewer
48 IS 11397:1985 Specification for attachment tools for power driven rodding machine for sewers
49 IS 11401(Part 1):1985 Requirements for slow sand filters: Part 1 General guidelines
50 IS 11401(Part 2):1990 General requirements for slow sand filters Part 2 Design, construction, operation and maintenance
51 IS 11906:1986 Recommendations for cement mortar lining for cast iron mild steel and ductile-iron pipes and fittings for transportation of
52 IS 11925:1986 Specification for pitch-impregnated fibre pipes and fittings for drainage purposes
53 IS 11931:1987 Specification for sewer cleaning metal rods
54 IS 11972:1987 Code of practice for safety precautions to be taken when entering a sewerage system
55 IS 12183(Part 1):1987 Code of practice for plumbing in multi-storeyed buildings: Part 1 Water supply
56 IS 12251:1987 Code of practice for drainage of building basements
57 IS 12288:1987 Code of practice for use and laying of ductile iron pipes
58 IS 12314:1987 Code of practice for sanitation with leaching pits for rural community
59 IS 13166:1992 Guidelines for evaluation and testing of mechanical surface aerators
60 IS 13496:1992 General requirements of suction machine for cleaning sewers, manholes and ancillary structures provided on sewer line and closed storm water drains
61 SP 35(S&T): 1987 Handbook on water supply and drainage with special emphasis on plumbing
CED 29 CONSTRUCTION MANAGEMENT(INCLUDING SAFETY IN
STANDARDS PUBLISHED
1 IS 3696(Part 1):1987 Safety code of scaffolds and ladders: Part 1 Scaffolds
2 IS 3696(Part 2):1991 Safety code of scaffolds and ladders: Part 2 Ladders
3 IS 3764:1992 Code of safety for excavation work (first revision)
4 IS 4014(Part 2):2013 Code of practice for steel tubular scaffolding: Part 2 Safety regulations for scaffolding (first revision)
5 IS 4081:2013 Code of safety for blasting and related drilling operations
6 IS 4082:1996 Recommendations on stacking and storage of construction materials and components at site (second revision)
7 IS 4130:1991 Safety code for demolition of buildings (second revision)
8 IS 4138:1977 Safety code for working in compressed air (first revision)
9 IS 4756:1978 Safety code for tunneling work (first revision)
10 IS 4912:1978 Safety requirements for floor and wall openings, railings and toe boards (first revision)
11 IS 5121:2013 Code of safety for piling and other deep foundations (first revision)
12 IS 5916:2013 Safety code for construction involving use of hot bituminous materials (first revision)
13 IS 7272(Part 1):1974 Recommendations for labour output constants for building work: Part 1 North zone
14 IS 7293:1974 Safety code for working with construction machinery
15 IS 7969:1975 Safety code for handling and storage of building materials
16 IS 8989:1978 Safety code for erection of concrete framed structures
17 IS 10067:1982 Material constants in building works
18 IS 10291:1982 Safety code for dress divers in civil engineering works
19 IS 10302:1982 Unified nomenclature of workmen for civil engineering
20 IS 13415:1992 Code of safety for protective barriers in and around buildings
21 IS 13416(Part 1):1992 Recommendations for preventive measures against hazards at workplaces: Part 1 Falling material hazards prevention
22 IS 13416(Part 2):1992 Recommendations for preventive measures against hazards at workplaces: Part 2 Fall prevention
23 IS 13416(Part 3):1994 Recommendations for preventive measures against hazards at workplaces: Part 3 Disposal of debris
24 IS 13416(Part 4):1994 Recommendations for preventive measures against hazards at workplaces: Part 4 Timber structure
25 IS 13416(Part 5):1994 Recommendations for preventive measures against hazards at workplaces: Part 5 Fire protection
26 IS 13430:1992 Code of practice for safety during additional construction and alteration to existing buildings
27 IS 15883(Part 1):2009 Guidelines for construction project management: Part 1 General
28 IS 15883(Part 2):2013 Guidelines for construction project management: Part 2 Time management
29 IS 15883(Part 5):2013 Guidelines for construction project management: Part 5 Health and safety management
30 SP 70: 2001 Handbook on construction safety practices
CED 30 CLAY AND STABILIZED SOIL PRODUCTS FOR CONSTRUCTION
STANDARDS PUBLISHED
1 IS 654:1992 Clay roofing tiles, mangalore pattern - Specification (third revision)
2 IS 1077:1992 Common burnt clay building bricks - Specification (fifth revision)
3 IS 1464:1992 Clay ridge and ceiling tiles - Specification (second revision)
4 IS 1478:1992 Clay flooring tile - Specification (second revision)
5 IS 1725:2013 Stabilized soil blocks used in general building construction - Specification (second revision)
6 IS 2117:1991 Guide for manufacture of hand-made common burnt clay building bricks (third revision)
7 IS 2180:1988 Specification for heavy duty burnt clay building bricks
8 IS 2222:1991 Specification for burnt clay perforated building bricks
9 IS 2248:1992 Glossary of terms relating to clay products for buildings
10 IS 2690(Part 1):1993 Burnt clay flat terracing tiles- Specification : Part 1 Machine made (second revision)
11 IS 2690(Part 2):1992 Burnt clay flat terracing tiles - Specification : Part 2 Hand made (second revision)
12 IS 2691:1988 Specification for burnt clay facing bricks (second revision)
13 IS 3367:1993 Burnt clay tiles for use in lining irrigation and drainage works - Specification (second revision)
14 IS 3495(Part 1-4):1992 Methods of tests of burnt clay building bricks:
Part 1 Determination of compressive strength
Part 2 Determination of water absorption
Part 3 Determination of efflorescence
Part 4 Determination of warpage
15 IS 3583:1988 Specification for burnt clay paving bricks (second revision)
16 IS 3951(Part 1):2009 Specification for hollow clay tiles for floors and roofs Part 1 Filler type (second revision)
17 IS 3951(Part 2):2009 Hollow clay tiles for floors and roofs-Specification: Part 2 Structural type (second revision)
18 IS 3952:2013 Specification for burnt clay hollow bricks and blocks for walls and partitions (third revision)
19 IS 3978:1993 Manufacture of burnt clay Mangalore pattern roofing tiles - Code of practice (first revision)
20 IS 4885:1988 Specification for sewer bricks (first revision)
21 IS 5454:1978 Methods of sampling of clay building bricks (first revision)
22 IS 5779:1986 Specification for burnt clay soling bricks (first revision)
23 IS 6165:1992 Dimensions for special shapes of clay bricks (first revision)
24 IS 7556:1988 Specification for burnt clay jallies (first revision)
25 IS 8920:1978 Methods for sampling of burnt clay tiles
26 IS 11650:1991 Guide for manufacture of common burnt clay building bricks by semi-mechanized process (first revision)
27 IS 13317:1992 Clay roofing country tiles, half round and flat tiles - Specification
28 IS 13757:1993 Burnt clay fly ash building bricks - Specification
CED 35 FURNITURE
STANDARDS PUBLISHED
1 IS 1829(Part 1):1978 Specification for library furniture and fittings: Part 1 Timber
2 IS 1829(Part 2):1993 Library furniture and fittings : Part 2 Steel - Specification
3 IS 1883:1983 Specification for metal shelving racks adjustable type
4 IS 2695:1993 Specification for drawing filing equipment (second revision)
5 IS 3312:1984 Specification for steel shelving cabinets (adjustable type)
6 IS 3313:1983 Specification for steel filing cabinets for general office purposes (second revision)
7 IS 3314:1984 Specification for steel clothes lockers (second revision)
8 IS 3497:1992 Steel wardrobes (adjustable type) - Specification (second revision)
9 IS 3498:1993 Metal table (office type) - Specification (third revision)
10 IS 3499(Part 1):1985 Specification for metal chairs for office purposes: Part 1 Non- revolving and non-tilting (second revision)
11 IS 3499(Part 2):1985 Specification for metal chairs for office purposes: Part 2 Revolving and tilting (Second Revision)
12 IS 3663:1991 Dimensions of tables and chairs for office purposes
13 IS 3761:1983 Specification for metal side racks (adjustable type) (first revision)
14 IS 3762:1979 Specification for metal waste paper bins (first revision)
15 IS 3763:1983 Specification for metal folding chairs (first revision)
16 IS 3791:1983 Specification for metal paper trays (first revision)
17 IS 3845:1966 Code of practice for joints used in wooden furniture
18 IS 4103:1977 Specification for metal nesting chairs (first revision)
19 IS 4116:1988 Specification for wooden shelving cabinets (adjustable type)
20 IS 4126:1986 Specification for wooden wardrobes (adjustable and non- adjustable type) (first revision)
21 IS 4204:1974 Functional requirements for drafting chairs (first revision)
22 IS 4205:1989 Drafting stools - Specification (second revision)
23 IS 4414:1990 Wooden table tops - Specification (second revision)
24 IS 4415:1974 Glossary of terms relating to wooden furniture and fixtures
25 IS 4837:1990 School furniture, classroom chairs and tables - Recommendations (second revision)
26 IS 5391:1992 Adjustable metal chairs for use of typists and operators in telephone exchanges - Specification (second revision)
27 IS 5416(Part 1):1988 Methods of test for strength and stability of chairs and stools: Part 1 Strength (first revision)
28 IS 5416(Part 2):1988 Method of test for strength and stability of chairs and stools: Part 2 Determination of stability of chairs and stools
29 IS 5807(Part 1):1975 Methods of test for clear finishes for wooden furniture: Part 1 Resistance to dry heat (first revision)
30 IS 5807(Part 2):1975 Methods of test for clear finishes for wooden furniture: Part 2 Resistance to wet heat (first revision)
31 IS 5807(Part 3):1971 Methods of test for clear finishes for wooden furniture: Part 3 Resistance to marking by oils and fats
32 IS 5807(Part 4):1975 Methods of test for clear finishes for wooden furniture: Part 4 Resistance to marking by liquids
33 IS 5807(Part 5):1975 Methods of test for clear finishes for wooden furniture: Part 5 Test for low angle glare
34 IS 5807(Part 6):1978 Methods of test for clear finishes for wooden furniture: Part 6 Resistance to mechanical damage
35 IS 5823:1986 Specification for dining tables (first revision)
36 IS 5923:1986 Specification for wooden clothes lockers (first revision)
37 IS 5967(Part 1):1988 Methods of test for strength and stability of tables and trolleys: Part 1 Strength (first revision)
38 IS 5967(Part 2):1988 Methods of test for strength and stability of tables and trolleys : Part 2 Stability (first revision)
39 IS 5974:1986 Specification for divans and easy chairs (first revision)
40 IS 6179:1971 Specification and safety requirements for rigid sided playpens
41 IS 6184:1971 Dimensions for furniture mirrors
42 IS 6185:1971 Specification and safety requirements for high chairs
43 IS 6188:1988 Specification for wooden bedside table (first revision)
44 IS 6189:1985 Specification for metal stationary cupboards (first revision)
45 IS 6632:1988 Specification for wooden folding chairs (first revision)
46 IS 7070:1988 Wooden shelving racks, adjustable and non-adjustable type - Specification (first revision)
47 IS 7076:1983 Specification for metal book ends (first revision)
48 IS 7259(Part 1):1988 Specification for wooden beds: Part 1 For use with mattresses
49 IS 7760:1985 Specification for steel glass-front cabinets (first revision)
50 IS 7761:1983 Specification for steel book cases (first revision)
51 IS 8126:1993 Specification for composite office tables (first revision)
52 IS 8467:1977 Specification for steel card-index cabinets
53 IS 8761:1978 Specification for steel folding cots
54 IS 9236:1993 Specification for metal letter-rests (first revision)
55 IS 9715:1981 Specification for steel visible indexing system cabinets
56 IS 11525:1986 Specification for wooden chairs for office purposes
57 IS 11679:1986 Specification for wooden tables for office use
58 IS 12674(Part 1):1989 Methods of test for strength and stability of settees and benches: Part 1 Strength
59 IS 12674(Part 2):1989 Methods of test for strength and stability of settees and benches; Part 2 Stability
60 IS 12680:1989 Wooden sofa-cum-bed - Specification
61 IS 13089:1991 Furniture - Storage units - Determination of stability
62 IS 13713:1993 Plastic chairs for general office purposes - Specification
63 IS 13896:1994 Machine operators table and visual display unit (VDU) table - Specification
CED 36 FIRE SAFETY
STANDARDS PUBLISHED
1 IS 1641:2013 Code of practice for fire safety of buildings (general): General principles of fire grading and classification (second revision)
2 IS 1642:2013 Code of practice for fire safety of buildings (general): Details of construction (second revision) (Superseding IS 1645)
3 IS 1643:2013 Code of practice for fire safety of buildings (general): Exposure hazard (second revision)
4 IS 1644:2013 Code of practice for fire safety of buildings (general): Exit requirements and personal hazard (second revision)
5 IS 1646:1997 Code of practice for fire safety of buildings (general): Electrical installations (second revision)
6 IS 2726:1988 Code of practice for fire safety of industrial buildings: Cotton ginning and pressing (including cotton seed delintering) factories (first revision)
7 IS 3034:1993 Code of practice for fire safety of industrial buildings: Electrical generating and distributing stations (second revision)
8 IS 3058:1990 Code of practice for fire safety of industrial buildings: Viscose rayon yarn and/or staple fibre plants (first revision)
9 IS 3079:1990 Code of practice for fire safety of industrial buildings: Cotton textile mills(first revision)
10 IS 3594:1991 Code of practice for fire safety of industrial buildings: General storage and warehousing including cold storages (first revision)
11 IS 3595:2002 Code of practice for fire safety of industrial buildings: Coal pulverizers and associated equipments (second revision)
12 IS 3614(Part 1):1966 Specification for fire-check doors: Part 1 Plate metal covered and rolling type
13 IS 3614(Part 2):1992 Specification for metallic and non-metallic fire-check doors - Resistance test and performance criteria
14 IS 3808:1979 Method of test for non-combustibility of building materials
15 IS 3809:1979 Fire resistance test for structures (first revision)
16 IS 3836:2000 Code of practice for fire safety of industrial buildings - Jute mills (second revision)
17 IS 4226:1988 Code of practice for fire safety of industrial buildings: Aluminium/Magnesium powder factories (first revision)
18 IS 4886:1991 Code of practice for fire safety of industrial buildings: Tea factories (first revision)
19 IS 6329:2000 Code of practice for fire safety of industrial buildings - Saw mills and wood works (first revision)
20 IS 8757:1999 Glossary of terms associated with fire safety (first revision)
21 IS 8758:2013 Recommendations for fire precautionary measures in the construction of temporary structures and pandals
22 IS 9109:2000 Code of practice for fire safety of industrial buildings - Paint and varnish factories (first revision)
23 IS 11457(Part 1):1985 Code of practice for fire safety of chemical industries: Part 1 Rubber and plastic
24 IS 11460:1985 Code of practice for fire safety of libraries and archives
25 IS 12349:1988 Fire protection-safety signs
26 IS 12407:1988 Graphic symbols for fire protection plans
27 IS 12456:2004 Code of practice for fire protection of electronic data processing installation (first revision)
28 IS 12458:1988 Method for fire resistance test of fire stops
29 IS 12459:1988 Code of practice for fire safety in cable runs
30 IS 12777:1989 Method for classification of flame spread of products
31 IS 13045:1991 Code of practice for fire safety of industrial buildings - Flour mills
32 IS 13694:1993 Code of practice for fire safety in iron and steel industries
33 IS 13716:1993 Code of practice for fire safety of hotels
34 IS 14435:2013 Fire safety in educational institutions्- Code of practice (first्revision)
35 IS 14689:1999 Code of practice for fire safety in industrial buildings (printing and publishing industry)
36 IS 14850:2000 Code of practice for fire safety of museums
37 IS 15381:2003 Specification for fire blanket
38 IS 15394:2003 Code of practice for fire safety in petroleum refineries and fertilizer plants
CED 37 STRUCTURAL SAFETY
STANDARDS PUBLISHED
1 IS 875(Part 1):1987 Code of practice for design loads (other than earthquake)for buildings and structures Part 1 Dead loads - Unit weights of building material and stored materials (second revision) (Incorporating IS:1911-1967)
2 IS 875(Part 2):1987 Code of practice for design loads (other than earthquake) for buildings and structures: Part 2 Imposed loads (second revision)
3 IS 875(Part 3):1987 Code of practice for design loads (other than earthquake) for buildings and structures: Part 3 Wind loads (second revision)
4 IS 875(Part 4):1987 Code of practice for design loads (other than earthquake) for buildings and structures Part 4 Snow loads (second revision)
5 IS 875(Part 5):1987 Code of practice for design loads (other than earthquake) for buildings and structures Part 5 Special loads and load combinations (second revision)
6 SP 64(S&T): 2001 Explanatory Handbook on Indian Standard Code of practice for Design Loads (Other than Earthquake) for Buildings and Structures: Part 3 Wind Loads [IS 875(Part 3):1987]
CED 38 SPECIAL STRUCTURES
STANDARDS PUBLISHED
1 IS 2210:1988 Criteria for design of reinforced concrete shell structures and folded plates (first revision)
2 IS 3935:1966 Code of practice for composite construction
3 IS 4090:1967 Criteria for design of reinforced concrete arches
4 IS 4995(Part 1):1974 Criteria for design of reinforced concrete bins for storage of granular and powdery materials: Part 1 General requirements and assessment of bin loads (first revision)
5 IS 4995(Part 2):1974 Criteria for design of reinforced concrete bins for storage of granular and powdery materials: Part 2 Design criteria
6 IS 4998(Part 1):1992 Criteria for design of reinforced concrete chimneys: Part 1 Assessment of loads (second revision)
7 IS 11384:1985 Code of practice for composite construction in structural steel and concrete
8 IS 11504:1985 Criteria for structural design of reinforced concrete natural draught cooling towers
9 IS 11682:1985 Criteria for design of RCC staging for overhead water tanks
10 SP 43(S&T): 1987 Handbook on structures with reinforced concrete portal frames (without cranes)
CED 39 EARTHQUAKE ENGINEERING
STANDARDS PUBLISHED
1 IS 1893:1984 Criteria for earthquake resistant design of structures
2 IS 1893(Part 1):2002 Criteria for earthquake resistant design of structures: Part 1 General Provisions and buildings (fifth revision)
3 IS 1893(Part 4):2005 Criteria for earthquake resistant design of structures: Part 4 Industrial structures including stack-like structure
4 IS 4326:2013 Code of practice for earthquake resistant design and construction of buildings (third revision)
5 IS 4967:1968 Recommendations for seismic instrumentation for river valley projects
6 IS 4991:1968 Criteria for blast resistant design of structures for explosions above ground
7 IS 6922:1973 Criteria for safety and design of structures subject to underground blasts
8 IS 13827:1993 Improving earthquake resistance of earthen buildings -
9 IS 13828:1993 Improving earthquake resistance of low strength masonry buildings - Guidelines
10 IS 13920:1993 Ductile detailing of reinforced concrete structures subjected to seismic forces- Code of practice
11 IS 13935:2009 Guidelines for evaluation, repair and seismic strengthening of masonry buildings (first revision)
12 IS 15988:2013 Seismic Evaluation and Strengthening of Existing Reinforced Concrete Buildings - Guidelines.
CED 41 WATERPROOFING AND DAMP-PROOFING
STANDARDS PUBLISHED
1 IS 1322:1993 Specification for bitumen felts for water proofing and damp- proofing (fourth revision)
2 IS 1346:1991 Code of practice for waterproofing of roofs with bitumen felts
3 IS 1580:1991 Specification for bituminous compounds for water-proofing and caulking purposes (second revision)
4 IS 1609:1991 Code of practice for damp-proofing treatment using bitumen felts (third revision)
5 IS 3036:1992 Code of practice for laying lime concrete for a waterproofed roof finish (second revision)
6 IS 3037:1986 Specification for bitumen mastic for use in water-proofing of roofs (first revision)
7 IS 3067:1988 Code of practice for general design details and preparatory work for damp-proofing and water-proofing of buildings (first revision)
8 IS 3384:1986 Specification for bitumen primer for use in waterproofing and damp-proofing (first revision)
9 IS 4365:1967 Code of practice for application of bitumen mastic for waterproofing of roofs
10 IS 4911:1986 Glossary of terms relating to bituminous waterproofing and damp-proofing of buildings (first revision)
11 IS 5871:1987 Specification for bitumen mastic for tanking and damp- proofing (first revision)
12 IS 6494:1988 Code of practice for water-proofing of underground water reservoirs and swimming pools (first revision)
13 IS 7193:1994 Glass fibre base bitumen felts - Specification (first revision)
14 IS 7198:1974 Code of practice for damp-proofing using bitumen mastic
15 IS 7290:1979 Recommendations for use of polyethylene film for water- proofing of roofs (first revision)
16 IS 9918:1981 Code of practice for in-situ waterproofing and damp-proofing treatment with glass fibre tissue reinforced bitumen
17 IS 12027:1987 Specification for silicone-based water repellents
18 IS 12054:1987 Code of practice for application of silicone based water repellents
19 IS 13182:1991 Waterproofing and damp-proofing of wet areas in building - Recommendations
20 IS 13435(Part 1):1992 Acrylic based polymer waterproofinng materials - Methods of test: Part 1 Determination of solid content
21 IS 13435(Part 2):1992 Acrylic based polymer waterproofing materials - Methods of test: Part 2 Determination of coarse particles
22 IS 13435(Part 3):1992 Acrylic based polymer waterproofing material - Methods of test Part 3 Determination of capillary water take-up
23 IS 13435(Part 4):1992 Acrylic based polymer waterproofing material - Methods of test Part 4 Determination of pH value
24 IS 13826(Part 1):1993 Bitumen based felt - Methods of test: Part 1 Breaking strength
25 IS 13826(Part 2):1993 Bitumen based felt - Methods of test Part 2 Pliability test
26 IS 13826(Part 3):1993 Bitumen based felt - Methods of test; Part 3 Storage sticking
27 IS 13826(Part 4):1994 Bitumen based felt - Methods of test: Part 4 Pressure head test
28 IS 13826(Part 5):1994 Bitumen based felt - Methods of test; Part 5 Heat resistance
29 IS 13826(Part 6):1993 Bitumen based felt - Methods of test; Part 6 Water absorption
30 IS 13826(Part 7):1993 Bitumen based felt - Methods of test: Part 7 Determination of binder content
31 IS 14695:1999 Glass fibre base coal tar pitch outer wrap - Specification
CED 43 SOIL AND FOUNDATION ENGINEERING
STANDARDS PUBLISHED
1 IS 1080:1985 Code of practice for design and construction of shallow foundations in soils (other than raft, ring and shell)
2 IS 1498:1970 Classification and identification of soils for general engineering purposes (first revision)
3 IS 1888:1982 Method of load test on soils (second revision)
4 IS 1892:1979 Code of practice for subsurface investigation for foundations
5 IS 1904:1986 Code of practice for design and construction of foundations in soils: General requirements (third revision)
6 IS 2131:1981 Method of standard penetration test for soils (first revision)
7 IS 2132:1986 Code of practice for thin walled tube sampling of soils
8 IS 2720(Part 1):1983 Methods of test for soils: Part 1 Preparation of dry soil samples for various tests (second revision)
9 IS 2720(Part 2):1973 Methods of test for soils: Part 2 Determination of water content
10 IS 2720(Part 3/Sec Methods of test for soils: Part 3 Determination of specific 1):1980 gravity, Section 1 Fine grained soils (first revision)
11 IS 2720(Part 3/Sec Methods of test for soils: Part 3 Determination of specific 2):1980 gravity, Section 2 Fine, medium and coarse grained soils
12 IS 2720(Part 4):1985 Methods of test for soils: Part 4 Grain size analysis
13 IS 2720(Part 5):1985 Methods of test for soils: Part 5 Determination of liquid and plastic limit (second revision)
14 IS 2720(Part 6):1972 Methods of test for soils: Part 6 Determination of shrinkage factors (first revision)
15 IS 2720(Part 7):1980 Methods of test for soils: Part 7 Determination of water content- dry density relation using light compaction (second revision)
16 IS 2720(Part 8):1983 Methods of test for soils: Part 8 Determination of water content- dry density relation using heavy compaction (second revision)
17 IS 2720(Part 9):1992 Methods of test for soils: Part 9 Determination of dry density- moisture content relation by constant mass of soil method
18 IS 2720(Part 10):1991 Methods of test for soils: Part 10 Determination of unconfined compressive strength (second revision)
19 IS 2720(Part 11):1993 Methods of test for soils: Part 11 Determination of the shear strength parameters of a specimen tested in unconsolidated undrained triaxial compression without the measurement of pore water pressure (first revision)
20 IS 2720(Part 12):1981 Methods of test for soils: Part 12 Determination of shear strength parameters of soil from consolidated undrained triaxial compression test with measurement of pore water pressure (first revision)
21 IS 2720(Part 13):1986 Methods of test for soils: Part 13 Direct shear test
22 IS 2720(Part 14):1983 Methods of test for soils: Part 14 Determination of density index (relative density) of cohesionless soils (first revision)
23 IS 2720(Part 15):1986 Methods of test for soils: Part 15 Determination of consolidation properties (first revision)
24 IS 2720(Part 16):1987 Methods of test for soils: Part 16 Laboratory determination of CBR (second revision)
25 IS 2720(Part 17):1986 Methods of test for soils: Part 17 Laboratory determination of permeability (first revision)
26 IS 2720(Part 18):1992 Methods of test for soils: Part 18 Determination of field moisture equivalent (first revision)
27 IS 2720(Part 19):1992 Methods of test for soils: Part 19 Determination of centrifuge moisture equivalent (first revision)
28 IS 2720(Part 20):1992 Methods of test for soils: Part 20 Determination of linear shrinkage (first revision)
29 IS 2720(Part 21):1977 Methods of test for soils: Part 21 Determination of total soluble solids (first revision)
30 IS 2720(Part 22):1972 Methods of test for soils: Part 22 Determination of organic matter (first revision)
31 IS 2720(Part 23):1976 Methods of test for soils: Part 23 Determination of calcium carbonate (first revision)
32 IS 2720(Part 24):1976 Methods of test for soils: Part 24 Determination of cation exchange capacity (first revision)
33 IS 2720(Part 25):1982 Methods of test for soils: Part 25 Determination of silica sesquioxide ratio (first revision)
34 IS 2720(Part 26):1987 Methods of test for soils: Part 26 Determination of pH value
35 IS 2720(Part 27):1977 Methods of test for soils: Part 27 Determination of total soluble sulphates (first revision)
36 IS 2720(Part 28):1974 Methods of test for soils: Part 28 Determination of dry density of soils, in-place, by the sand replacement method (first revision)
37 IS 2720(Part 29):1975 Methods of test for soils: Part 29 Determination of dry density of soils in-place, by the core-cutter method (first revision)
38 IS 2720(Part 30):1980 Methods of test for soils: Part 30 Laboratory vane shear test
39 IS 2720(Part 31):1990 Methods of test for soils: Part 31 Field determination of California bearing ratio (first revision)
40 IS 2720(Part 33):1971 Methods of test for soils: Part 33 Determination of the density in place by the ring and water replacement method
41 IS 2720(Part 34):1972 Methods of test for soils: Part 34 Determination of density of soil in place by rubber balloon method
42 IS 2720(Part 35):1974 Methods of test for soils: Part 35 Measurement of negative pore water pressure
43 IS 2720(Part 36):1987 Methods of test for soils: Part 36 Laboratory determination of permeability of granular soils (constant head) (first revision)
44 IS 2720(Part 37):1976 Methods of test for soils: Part 37 Determination of sand equivalent value of soils and fine aggregates
45 IS 2720(Part 38):1976 Methods of test for soils: Part 38 Compaction control test (Hilf method)
46 IS 2720(Part 39/Sec Methods of test for soils: Part 39 Direct shear test for soils 1):1977 containing gravel, Section 1 Laboratory test
47 IS 2720(Part 39/Sec Methods of test for soils: Part 39 Direct shear test for soils 2):1979 containing gravel, Section 2 In-situ shear test
48 IS 2720(Part 40):1977 Methods of test for soils: Part 40 Determination of free swell index of soils
49 IS 2720(Part 41):1977 Methods of test for soils: Part 41 Measurement of swelling pressure of soils
50 IS 2809:1972 Glossary of terms and symbols relating to soil engineering
51 IS 2810:1979 Glossary of terms relating to soil dynamics (first revision)
52 IS 2911(Part 1/Sec Design and construction of pile foundations- Code of practice:1):2010 Part 1 Concrete piles, Section 1 Driven cast in-situ concrete piles (second revision)
53 IS 2911(Part 1/Sec Design and construction of pile foundations- Code of practice: 2):2010 Part 1 Concrete piles, Section 2 Bored cast-in-situ concrete piles (second revision)
54 IS 2911(Part 1/Sec Design and construction of pile foundations- Code of practice:3):2010 Part 1 Concrete piles, Section 3 Driven precast concrete piles (second revision)
55 IS 2911(Part 1/Sec Design and construction of pile foundations- Code of practice:4):2010 Part 1 Concrete piles, Section 4 Precast concrete piles in prebored holes (first revision)
56 IS 2911(Part 2):1980 Code of practice for design and construction of pile foundations: Part 2 Timber piles (first revision)
57 IS 2911(Part 3):1980 Code of practice for design and construction of pile foundations: Part 3 Under reamed piles (first revision)
58 IS 2911(Part 4):2013 Design and construction of pile foundations - Code of practice: Part 4 Load test on piles (second revision)
59 IS 2950(Part 1):1981 Code of practice for design and construction of raft foundations: Part 1 Design (second revision)
60 IS 2974(Part 1):1982 Code of practice for design and construction of machine foundations: Part 1 Foundations for reciprocating type machines (second revision)
61 IS 2974(Part 2):1980 Code of practice for design and construction of machine foundations: Part 2 Foundations for impact type machines (hammer foundations) (first revision)
62 IS 2974(Part 3):1992 Code of practice for design and construction of machine foundations: Part 3 Foundations for rotary type machines (medium and high frequency) (second revision)
63 IS 2974(Part 4):1979 Code of practice for design and construction of machine foundations: Part 4 Foundations for rotary type machines of low frequency (first revision)
64 IS 2974(Part 5):1987 Code of practice for design and construction of machine foundations: Part 5 Foundations for impact machines other than hammer (forging and stamping press, pig breaker, drop crusher and jolter) (first revision)
65 IS 4091:1979 Code of practice for design and construction of foundations for transmission line towers and poles (first revision)
66 IS 4332(Part 1):1967 Methods of test for stabilized soils: Part 1 Method of sampling and preparation of stabilized soils for testing
67 IS 4332(Part 2):1967 Methods of test for stabilized soils: Part 2 Determination of moisture content of stabilized soil mixtures
68 IS 4332(Part 3):1967 Methods of test for stabilized soils: Part 3 Test for determination of moisture content-dry density relation for stablized soil mixtures
69 IS 4332(Part 4):1968 Methods of test for stabilized soils: Part 4 Wetting and drying and freezing and thawing tests for compacted soil-cement mixtures
70 IS 4332(Part 5):1970 Methods of test for stabilized soils: Part 5 Determination of unconfined compressive strength of stabilized soils
71 IS 4332(Part 6):1972 Methods of test for stabilized soils: Part 6 Flexural strength of soil - cement using simple beam with third-point loading
72 IS 4332(Part 7):1973 Methods of test for stabilized soils: Part 7 Determination of cement content of cement stabilized soils
73 IS 4332(Part 8):1969 Methods of test for stabilized soils: Part 8 Determination of lime content of lime stabilized soils
74 IS 4332(Part 9):1970 Methods of test for stabilized soils: Part 9 Determination of the bituminous stabilizer content of bitumen and tar stabilized
75 IS 4332(Part 10):1969 Methods of test for stabilized soils: Part 10 Test for soil/bituminous mixtures
76 IS 4434:1978 Code of practice for in-situ vane shear test for soils (first revision)
77 IS 4968(Part 1):1976 Method for subsurface sounding for soils: Part 1 Dynamic method using 50 mm cone without bentonite slurry (first revision)
78 IS 4968(Part 2):1976 Method for subsurface sounding for soils: Part 2 Dynamic method using cone and bentonite slurry (first revision)
79 IS 4968(Part 3):1976 Method for subsurface sounding for soils: Part 3 Static cone penetration test (first revision)
80 IS 5249:1992 Determination of dynamic properties of soil - Method of test (second revision)
81 IS 6403:1981 Code of practice for determination of bearing capacity of shallow foundations (first revision)
82 IS 8009(Part 1):1976 Code of practice for calculation of settlements of foundations: Part 1 Shallow foundations subjected to symmetrical static vertical loads
83 IS 8009(Part 2):1980 Code of practice for calculation of settlement of foundations: Part 2 Deep foundations subjected to symmetrical static
84 IS 8763:1978 Guide for undisturbed sampling of sands
85 IS 9198:1979 Specification for compaction rammer for soil testing
86 IS 9214:1979 Method for determination of modulus of sub-grade reaction (k-value) of soils in field
87 IS 9259:1979 Specification for liquid limit apparatus for soils
88 IS 9456:1980 Code of practice for design and construction of conical and hyperbolic paraboloidal types of shell foundations
89 IS 9556:1980 Code of practice for design and construction of diaphragm walls
90 IS 9640:1980 Specification for split spoon sampler
91 IS 9669:1980 Specification for CBR moulds and its accessories
92 IS 9716:1981 Guide for lateral dynamic load test on piles
93 IS 9759:1981 Guidelines for dewatering during construction
94 IS 10042:1981 Code of practice for site investigations for foundation in gravel boulder deposit
95 IS 10074:1982 Specification for compaction mould assembly for light and heavy compaction test for soils
96 IS 10077:1982 Specification for equipment for determination of shrinkage
97 IS 10108:1982 Code of practice for sampling of soils by thin wall sampler with stationary piston
98 IS 10270:1982 Guidelines for design and construction of prestressed rock anchors
99 IS 10379:1982 Code of practice for field control of moisture and compaction of soils of embankment and subgrade
100 IS 10442:1983 Specification for earth augers (spiral type)
101 IS 10589:1983 Specification for equipment for subsurface sounding of soils
102 IS 10837:1984 Specification for moulds and accessories for determination of density index (relative density) of cohesionless soils
103 IS 11089:1984 Code of practice for design and construction of ring foundation
104 IS 11196:1985 Specification for equipment for determination of liquid limit of soils cone penetration method
105 IS 11209:1985 Specification for mould assembly for determination of permeability of soils
106 IS 11229:1985 Specification for shear box for testing of soils
107 IS 11233:1985 Code of practice for design and construction of radar antenna, microwave and TV tower foundations
108 IS 11550:1985 Code of practice for field instrumentation of swelling pressure in expansive soils
109 IS 11593:1986 Specification for shear box (large) for testing of soils
110 IS 11594:1985 Specification for mild steel thin walled sampling tubes and sampler heads
111 IS 11629:1986 Code of practice for installation and operation of single point hydraulic over-flow setting gauge
112 IS 12023:1987 Code of practice for field monitoring of movement of structures using tape extensometer
113 IS 12070:1987 Code of practice for design and construction of shallow foundations on rock
114 IS 12175:1987 Specification for rapid moisture meter for rapid determination of water content for soil
115 IS 12208:1987 Method for measurement of earth pressure by hydraulic pressure cell
116 IS 12287:1988 Specification for consolidometer for determination of consolidation properties
117 IS 12979:1990 Mould for determination of linear shrinkage - Specification
118 IS 13094:1992 Selection of ground improvement techniques for foundation in weak soils - Guidelines
119 IS 13301:1992 Vibration isolation for machine foundations - Guidelines
120 IS 13468:1992 Apparatus for determination of dry density of soil by core cutter method - Specification
121 IS 14593:1998 Design and construction of bored cast-in-situ piles founded on rocks - Guidelines
122 IS 14893:2001 Non-destructive integrity testing of piles (NDT) - Guidelines
123 IS 15284(Part 1):2003 Design and construction for ground improvement - Guidelines: Part 1 Stone columns
124 IS 15284(Part 2):2004 Design and construction for ground improvement - Guidelines: Part 2 Preconsolidation using vertical drains
125 SP 36(Part 1): 1987 Compendium of Indian standards on soil engineering: Part 1 Laboratory testing of soils for civil engineering purposes
126 SP 36(Part 2): 1988 Compendium of Indian standards on soil engineering: Part 2 Field testing of soils for civil engineering purposes
CED 44 METHODS OF MEASUREMENT OF WORKS OF CIVIL ENGINEERING (EXCLUDING WATER RESOURCES DEVELOPMENT DIVISION)
STANDARDS PUBLISHED
1 IS 1200(Part 1):1992 Methods of measurement of building and civil engineering works: Part 1 Earthwork (fourth revision)
2 IS 1200(Part 2):1974 Methods of measurement of building and civil engineering works: Part 2 Concrete works (third revision)
3 IS 1200(Part 3):1976 Methods of measurement of building and civil engineering
works: Part 3 Brickwork(third revision)
4 IS 1200(Part 4):1976 Methods of measurement of building and civil engineering works: Part 4 Stone masonry (third revision)
5 IS 1200(Part 5):2013 Methods of measurement of building and civil engineering works: part 5 Form work (fourth revision)
6 IS 1200(Part 6):1974 Methods of measurement of building and civil engineering works: Part 6 Refractory work (second revision)
7 IS 1200(Part 7):2013 Methods of measurement of building and civil engineering works: Part 7 Hardware (third revision)
8 IS 1200(Part 8):1993 Methods of measurement of building and civil engineering works: Part 8 Steel work and iron work (fourth revision)
9 IS 1200(Part 9):1973 Methods of measurement of building and civil engineering works: Part 9 Roof covering (including cladding) (second revision)
10 IS 1200(Part 10):2013 Methods of measurement of building and civil engineering works: part 10 Ceiling and linings (third revision)
11 IS 1200(Part 11):2013 Methods of measurement of building and civil engineering works: Part 11 Paving, floor finishes, dado and skirting (fourth revision)
12 IS 1200(Part 12):1976 Methods of measurement of building and civil engineering works: Part 12 plastering and pointing (third revision)
13 IS 1200(Part 13):1994 Methods of measurement of building and civil engineering works: Part 13 Whitewashing, colour washing, distempering and painting of building surfaces (fifth revision)
14 IS 1200(Part 14):1984 Methods of measurement of building and civil engineering works: Part 14 Glazing (third revision)
15 IS 1200(Part 15):1987 Method of measurement of building and civil engineering works: Part 15 painting, polishing, varnishing etc (fourth revision)
16 IS 1200(Part 16):1979 Method of measurement of building and civil engineering works: Part 16 Laying of water and sewer lines including appurtenant items (third revision)
17 IS 1200(Part 18):1974 Method of measurement of building and civil engineering works: Part 18 Demolition and dismantling (third revision)
18 IS 1200(Part 19):1981 Method of measurement of building and civil engineering works: Parts 19 Water supply, plumbing and drains (third revision)
19 IS 1200(Part 20):1981 Method of measurement of building and civil engineering works: Part 20 Laying of gas and oil pipelines (third revision)
20 IS 1200(Part 21):1973 Method of measurement of building and civil engineering works: Part 21 Wood-work and joinery (second revision)
21 IS 1200(Part 22):1982 Method of measurement of building and civil engineering works: Part 22 Materials
22 IS 1200(Part 23):1988 Method of measurement of building and civil engineering works: Part 23 Piling (fourth revision)
23 IS 1200(Part 24):1983 Method of measurement of building and civil engineering works: Part 24 Well foundations (third revision)
24 IS 1200(Part 25):1971 Method of measurement of building and civil engineering works: Part 25 Tunneling (second revision)
25 IS 1200(Part 26):1987 Method of measurement of building and civil engineering works: Part 26 Acid resistant lining
26 IS 1200(Part 27):2013 Method of measurement of building and civil engineering works: Part 27 Earth work done by mechanical appliances
27 IS 1200(Part 28):1992 Methods of measurement of building and civil engineering works: Part 28 Sound insulation work
28 IS 3861:2002 Method of measurement of plinth, carpet and rentable areas of buildings (second revision)
29 SP 27: 1987 Handbook on method of measurement of buildings works (first revision)
CED 46 NATIONAL BUILDING CODE
STANDARDS PUBLISHED
1 SP 7: 2005 National Building Code of India 2005: Part 0 Integrated Approach - Prerequisite for applying provisions of the Code
2 SP 7(Part 1): 2005 National Building Code of India 2005: Part 1 Definitions
3 SP 7(Part 2): 2005 National Building Code of India 2005: Part 2 Administration
4 SP 7(Part 3): 2005 National Building Code of India 2005: Part 3 Development control rules and general building requirements
5 SP 7(Part 4): 2005 National Building Code of India 2005: Part 4 Fire and life safety
6 SP 7(Part 5): 2005 National Building Code of India 2005: Part 5 Building materials
7 SP 7(Part 6): 2005 National Building Code of India 2005: Part 6 Structural design
Section 1 Loads, forces and effects
Section 2 Soils and foundations
Section 3 Timber and bamboo
3A Timber
3B Bamboo
Section 4 Masonry
Section 5 Concrete
5A Plain and reinforced concrete
5B Prestressed concrete
Section 6 Steel
Section 7 Prefabrication, systems building and mixed/composite construction
7A Prefabricated concrete
7B Systems buildings and mixed/composite construction
8 SP 7(Part 7): 2005 National Building Code of India 2005: Part 7 Constructional practices and safety
9 SP 7(Part 8): 2005 National Building Code of India 2005: Part 8 Building services
Section 1 Lighting and ventilation
Section 2 Electrical and allied installations
Section 3 Air conditioning, heating and mechanical ventilation
Section 4 Acoustics, sound insulations and noise control
Section 5 Installation of lifts and escalators
10 SP 7(Part 9): 2005 National Building Code of India 2005: Part 9 Plumbing services
Section 1 Water supply, drainage and sanitation (including solid waste management)
Section 2 Gas Supply
11 SP 7(Part 10): 2005 National Building Code of India 2005: Part 10 Landscaping, signs and outdoor display structures
Section 1 Landscape planning and Design
Section 2 Signs and outdoor display structures
CED 47 PORTS, HARBOURS AND OFFSHORE INSTALLATIONS
STANDARDS PUBLISHED
1 IS 4651(Part 1):1974 Code of practice for planning and design of ports and harbours: Part 1 Site investigation (first revision)
2 IS 4651(Part 2):1989 Ports and harbours - Planning and design - Code of practice: Part 2 Earth pressure (first revision)
3 IS 4651(Part 3):1974 Code of practice for planning and design of ports and harbours: Part 3 Loading_(first revision)
4 IS 4651(Part 4):1989 Code of practice for planning and design of ports and harbours: Part 4 General design consideration (second revision)
5 IS 4651(Part 5):1980 Code of practice for planning and design of ports and harbours: Part 5 Layout and functional requirements
6 IS 7314:1974 Glossary of terms relating to port and harbour engineering
7 IS 9527(Part 1):1981 Code of practice for design and construction of port and harbour structures: Part 1 Concrete monoliths
8 IS 9527(Part 3):1983 Code of practice for design and construction of port and harbour structures: Part 3 Sheet pile walls
9 IS 9527(Part 4):1980 Code of practice for design and construction of port and harbour structures: Part 4 Cellular sheet pile structures
10 IS 9527(Part 6):1989 Code of practice for design and construction port and harbour structures Part 6 Block work
11 IS 10020(Part 4):1981 Recommendations for design and construction of port and harbour components: Part 4 Slipways
CED 48 ROCK MECHANICS
STANDARDS PUBLISHED
1 IS 7317:1993 Code of practice for uniaxial jacking test for deformation modulus of rock (first revision)
2 IS 7746:1991 Code of practice for in-situ shear test on rock (first revision)
3 IS 8764:1998 Method of determination of point load strength index of rocks
4 IS 9143:1979 Method for the determination of unconfined compressive strength of rock materials
5 IS 9179:1979 Method for the preparation of rock specimen for laboratory
6 IS 9221:1979 Method for the determination of modulus of elasticity and Poisson's ratio of rock materials in uniaxial compression
7 IS 10050:1981 Method for determination of slake durability index of rocks
8 IS 10082:1981 Method of test for the determination of tensile strength by indirect tests on rock specimens
9 IS 10782:1983 Method for laboratory determination of dynamic modulus of rock core specimens
10 IS 11309:1985 Method of conducting pull-out test on anchor bars and rock bolts
11 IS 11315(Part 1):1987 Method for the quantitative description of discontinuities in rock mass: Part 1 Orientation
12 IS 11315(Part 2):1987 Method for the quantitative description of discontinuities in rock mass: Part 2 Spacing
13 IS 11315(Part 3):1987 Method for the quantitative description of discontinuities in rock mass: Part 3 Persistence
14 IS 11315(Part 4):1987 Method for the quantitative description of discontinuities in rock mass: Part 4 Roughness
15 IS 11315(Part 5):1987 Method for the quantitative description of discontinuities in rock mass: Part 5 Wall strength
16 IS 11315(Part 6):1987 Method for the quantitative description of discontinuities in rock mass: Part 6 Aperture
17 IS 11315(Part 7):1987 Method for the quantitative description of discontinuities in rock mass: Part 7 Filling
18 IS 11315(Part 8):1987 Method for the quantitative description of discontinuities in rock mass: Part 8 Seepage
19 IS 11315(Part 9):1987 Method for the quantitative description of discontinuities in rock mass: part 9 Number of sets
20 IS 11315(Part 10):1987 Method for the quantitative description of discontinuities in rock mass : Part 10 Block size
21 IS 11315(Part 11):1985 Method for the quantitative description of discontinuities in rock mass: Part 11 Core recovery and rock quality
22 IS 11315(Part 12):1992 Method for the quantitative description of discontinuities in rock mass:: Part12 Drill core study
23 IS 11358:1987 Glossary of terms and symbols relating to rock mechanics
24 IS 12608:1989 Methods of test for hardness of rock
25 IS 12634:1989 Method of determination for direct shear strength of rock joints
26 IS 12955(Part 1):1990 Code of practice for in-situ determination of rock mass deformability using a flexible dilatometer Part 1 Volume
27 IS 12955(Part 2):1990 Code of practice for in-situ determination of rock mass deformability using a flexible dilatometer Part 2 Radial displacement
28 IS 13030:1991 Method of test for laboratory determination of water content, porosity, density and related properties of rock material
29 IS 13047:1991 Method for determination of strength of rock materials in triaxial compression
30 IS 13063:1991 Code of practice for structural safety of buildings on shallow foundations on rocks
31 IS 13365(Part 1):1998 Quantitative classification system of rock mass - Guidelines : Part 1 RMR for predicting of engineering properties
32 IS 13365(Part 2):1992 Quantitative classification systems of rock mass-Guidelines Part 2 Rock mass quality for prediction of support pressure in underground openings
33 IS 13365(Part 3):1997 Quantitative classification system of rock mass - Guidelines Part 3 Determination of slope mass rating (SMR)
34् IS 13365(Part 4):2014् Quantitative Classification Systems of Rock Mass - Guidelines Part 4 Geological Strength Index (GSI)
35 IS 13372(Part 1):1992 Code of practice for seismic testing of rock mass: Part 1 within a borehole
36 IS 13372(Part 2):1992 Code of practice for seismic testing of rock mass: Part 2 Between the borehole
37 IS 13414:1992 Guidelines for monitoring of rock movement and multi-point borehole extensometers
38 IS 13946(Part 1):1994 Code of practice for in-situ determination of rock stress Part 1 Using hydraulic fracturing technique
39 IS 13946(Part 2):1994 Code of practice for determination of rock stress Part 2 Using USBM type drill hole deformation gauge
40 IS 13946(Part 3):1994 Code of practice for determination of rock stress Part 3 Using a CSIR or CSIRO type cell with 9 or 12 strain gauges
41 IS 13946(Part 4):1994 Determination of rock stress-Code of practice Part 4 Using flat jack technique
42 IS 14243(Part 1):1995 Guidelines for selection and development of site for building Jul 2010 in hill areas Part 1 Microzonation of urban centres
43 IS 14243(Part 2):1995 Guidelines for selection and development of site for building in hill areas Part 2 Selection and development
44 IS 14395:1996 Guidelines for monitoring of rock movements using probe inclinometer
45 IS 14396(Part 1):1996 Methods for laboratory testing of argillaceous swelling rocks Part 1 Methods of sampling storage and preparation of test
46 IS 14396(Part 2):1996 Methods for laboratory testing of argillaceous swelling rocks Part 2 Determination of maximum axial swelling stress
47 IS 14396(Part 3):1996 Methods for laboratory testing of argillaceous rocks Part 3 Determination of axial and radial free swelling strain
48 IS 14396(Part 4):1996 Methods for laboratory testing of argillaceous swelling rock Part 4 Determining axial swelling stress as a function of axial swelling strain
49 IS 14436:1997 Method of test for laboratory determination of resistivity of rock specimen
50 IS 14448:1997 Code of practice for reinforcement of rock slopes with plane wedge failure
51 IS 14881:2001 Method for blast vibration monitoring - Guidelines
52 IS 15026:2002 Guidelines for tunnelling methods in rock masses
53 IS 15180:2002 Guidelines for use in the prediction of subsidence and associated parameters in coal mines having nearly horizontal single seam workings
CED 50 PLASTIC PIPING SYSTEM
STANDARDS PUBLISHED
1 IS 4984:1995 Specification for high density polyethylene pipes for potable water supplies (fourth revision)
2 IS 4985:2000 Specification for unplasticised PVC pipes for potable water supplies (third revision)
3 IS 7634(Part 1):1975 Code of practice for plastic pipes work for potable water supplies: Part 1 Choice of materials and general
4 IS 7634(Part 2):2012 Code of practice for plastics pipe work for potable water supplies: Part 2 Laying and jointing of polyethylene (PE) pipes
5 IS 7634(Part 3):2003 Plastic pipes selection, handling, storage and installation for potable water supplies - Code of practice Part 3 Laying and jointing of UPVC pipes (first revision)
6 IS 7834(Part 1):1987 Specification for injection moulded PVC socket fittings with solvent cement joints for water supplies: Part 1 General requirements (first revision)
7 IS 7834(Part 2):1987 Specification for injection moulded PVC socket fittings with solvent cement joints for water supplies: Part 2 Specific requirements for 45 degrees elbows (first revision)
8 IS 7834(Part 3):1987 Specification for injection moulded PVC socket fittings with solvent cement joints for water supplies: Part 3 Specific requirements for 90 degree elbows (first revision)
9 IS 7834(Part 4):1987 Specification for injection moulded PVC socket fittings with solvent cement joints for water supplies: Part 4 Specific requirements for 90 degree tees (first revision)
10 IS 7834(Part 5):1987 Specification for injection moulded PVC socket fittings for solvent cement joints for water supplies: Part 5 Specific requirements for 45 degree tees (first revision)
11 IS 7834(Part 6):1987 Specification for injection moulded PVC socket fittings with solvent cement joints for water supplies: Part 6 Specific requirements for sockets (first revision)
12 IS 7834(Part 7):1987 Specification for injection moulded PVC socket fittings with solvent cement joints for water supplies: Part 7 Specific requirements for unions (first revision)
13 IS 7834(Part 8):1987 Specification for injection moulded PVC socket fittings with solvent cement joints for water supplies: Part 8 Specific requirements for caps (first revision)
14 IS 8008(Part 1):2003 Injection moulded/machined high density polyethylene (HDPE) fittings for potable water supplies - Specification: Part 1 General requirements for fitting (first revision)
15 IS 8008(Part 2):2003 Injection moulded/machined high density polyethylene (HDPE) fittings for potable water supplies - Specification Part 2 Specific requirements for 90 degree bend (first revision)
16 IS 8008(Part 3):2003 Injection moulded/machined high density polyethylene (HDPE) fittings for potable water supplies - Specification: Part 3 Specific requirements for 90 degree tees (first revision)
17 IS 8008(Part 4):2003 Injection moulded/machined high density polyethylene (HDPE) fittings for potable water supplies - Specification : Part 4 Specific requirements for reducers (first revision)
18 IS 8008(Part 5):2003 Injection moulded/machined high density polyethylene (HDPE) fittings for potable water supplies - Specification Part 5 Specific requirements for ferrule reducers (first revision)
19 IS 8008(Part 6):2003 Injection moulded /machined high density polyethylene (HDPE) fittings for potable water supplies - Specification: Part 6 Specific requirements for pipe ends (first revision)
20 IS 8008(Part 7):2003 Injection moulded /machined high density polyethylene (HDPE) fittings for potable water supplies - Specification : Part 7 Specific requirements for sandwich flanges (first revision)
21 IS 8008(Part 8):2003 Injection moulded/machined high density polyethylene (HDPE) fittings for potable water supplies: Part 8 Specific requirements for reducing tees (first revision)
22 IS 8008(Part 9):2003 Injection moulded/machined high density polyethylene (HDPE) fittings for potable water supplies - Specification Part 9 Specific requirements for ends caps (first revision)
23 IS 8360(Part 1):1977 Specification for fabricated high density polyethylene (HDPE) fittings for potable water supplies: Part 1 General requirements
24 IS 8360(Part 2):1977 Specification for fabricated high density polyethylene (HDPE) fittings for potable water supplies, Part 2 Specific requirements for 90 degree tees
25 IS 8360(Part 3):1977 Specification for fabricated high density polyethylene (HDPE) fittings for potable water supplies, Part 3 Specific requirements for 90 degree bends
26 IS 9271:2004 Unplasticized polyvinyl chloride UPVC single wall corrugated pipes for drainage - Specification (First Revision)
27 IS 10124(Part 1):2009 Fabricated PVC-U fittings for potable water supplies - Specification: Part I General requirements (second revision)
28 IS 10124(Part 2):2009 Fabricated PVC-U fittings for potable water supplies - Specification: Part 2 Specific requirements for sockets (second revision)
29 IS 10124(Part 3):2009 Fabricated PVC-U fittings for potable water supplies - Specification: Part 3 Specific requirements for straight reducers
30 IS 10124(Part 4):2009 Fabricated PVC-U fittings for potable water supplies - Specification: Part 4 Specific requirements for caps (second revision)
31 IS 10124(Part 5):2009 Fabricated PVC-U fittings for potable water supplies - Specification: Part 5 Specific requirements for equal tees (second revision)
32 IS 10124(Part 6):2009 Fabricated PVC-U fittings for potable water supplies - Specification: Part 6 Specific requirements for flanged tail piece with metallic flanges (second revision)
33 IS 10124(Part 7):2009 Fabricated PVC-U fittings for potable water supplies - Specification: Part 7 Specific requirements for threaded adaptors (second revision)
34 IS 10124(Part 8):2009 Fabricated PVC-U fittings for potable water supplies - Specification: Part 8 Specific requirements for 90 degree bends (second revision)
35 IS 10124(Part 9):2009 Fabricated PVC-U fittings for potable water supplies - Specification: Part 9 Specific requirements for 60 degree bends (second revision)
36 IS 10124(Part 10):2009 Fabricated PVC-U fittings for potable water supplies - Specification: Part 10 Specific requirements for 45 degree bends (second revision)
37 IS 10124(Part 11):2009 Fabricated PVC-U fittings for potable water supplies - Specification: Part 11 Specific requirements for 30 degree bends (second revision)
38 IS 10124(Part 12):2009 Fabricated PVC-U fittings for potable water supplies - Specification: Part 12 Specific requirements for 22 1/2 degree bends (second revision)
39 IS 10124(Part 13):2009 Fabricated PVC-U fittings for potable water supplies - Specification: Part 13 Specific requirements for 11 1/4 degree bends (second revision)
40 IS 12231:1987 Specification for unplasticized PVC pipes for use in suction and delivery lines of agricultural pump sets
41 IS 12235(Part 1):2004 Thermoplastic pipes and fittings - Methods of test: Part 1 Measurement of dimensions
42 IS 12235(Part 2):2004 Thermoplastic pipes and fittings - Methods of test: Part 2 Determination of vicat softening temperature
43 IS 12235(Part 3):2004 Thermoplastic pipes and fittings - Methods of test: Part 3 Test for opacity
44 IS 12235(Part 4):2004 Thermoplastic pipes and fittings - Methods of test: Part 4 Determining the detrimental effect on the composition of water
45 IS 12235(Part 5/Sec Thermoplastic pipes and fittings - Methods of test: Part 5 1):2004 Longitudinal reversion Section 1 Determination methods
46 IS 12235(Part 5/Sec Thermoplastic pipes and fittings - Methods of test: Part 5 2):2004
47 IS 12235(Part 6):2004 Thermoplastic pipes and fittings - Methods of test: Part 6 Stress relief test
48 IS 12235(Part 7):2004 Thermoplastic pipes and fittings - Methods of test: Part 7 Resistance of sulphuric acid
49 IS 12235(Part 8/Sec Thermoplastic pipes and fittings - Methods of test: Part 8 1):2004 Resistance to internal hydrostatic pressure Section 1 Resistance to internal hydrostatic pressure at constant internal
50 IS 12235(Part 8/Sec Thermoplastic pipes and fittings - Methods of test: 2):2004 Part 8 Resistance to internal hydrostatic pressure Section 2 Leak-tightness of elastomeric sealing ring type socket joints under positive internal pressure and with angular deflection
51 IS 12235(Part 8/Sec Thermoplastic pipes and fittings - Methods of test: 3):2004 Part 8 Resistance to internal hydrostatic pressure Section 3 Leak-tightness of elastomeric sealing ring type socket joints under negative internal pressure and with angular deflection
52 IS 12235(Part 8/Sec Thermoplastic pipes and fittings - Methods of test: 4):2004 Part 8 Resistance to internal hydrostatic pressure Section 4 Leak-tightness of elastomeric sealing ring type socket joints under positive internal pressure without angular deflection
53 IS 12235(Part 9):2004 Thermoplastic pipes and fittings - Methods of test: Part 9 Resistance to external blows (Impact resistance) at 0° C (Round-the-clock method)
54 IS 12235(Part 10):2004 Thermoplastic pipes and fittings - Methods of test: Part 10 Determination of organotin as tin aqueous solution
55 IS 12235(Part 11):2004 Thermoplastic pipes and fittings - Methods of test: Part 11 Resistance to dichloromethane at specified temperature
56 IS 12235(Part 12):2004 Thermoplastic pipes and fittings - Methods of test Part 12 Determination of titanium dioxide content
57 IS 12235(Part 13):2004 Thermoplastic pipes and fittings - Methods of test Part 13 Determination of tensile strength and elongation
58 IS 12235(Part 14):2004 Thermoplastic pipes and fittings - Methods of test Part 14 Determination of density/relative density (specific
59 IS 12235(Part 15):2004 Thermoplastic pipes and fittings - Methods of test Part 15 Determination of vinyl chloride monomer content
60 IS 12235(Part 16):2004 Thermoplastic pipes and fittings - Methods of test Part 16 High temperature test
61 IS 12235(Part 17):2004 Thermoplastic pipes and fittings - Methods of test Part 17 Determination of ash content and sulphated ash content
62 IS 12235(Part 18):2004 Thermoplastic pipes and fittings - Methods of test Part 18 Determination of ring stiffness
63 IS 12235(Part 19):2004 Thermoplastic pipes and fittings - Methods of test Part 19 Flattening test
64 IS 12709:1994 Specification for glass-fibre reinforced plastic (GRP) pipes joints and fittings for use for potable water supply (first revision)
65 IS 12818:2010 Unplasticized polyvinyl chloride (PVC-U) screen and casing pipes for bore/tubewells - Specification (Second Revision)
66 IS 13592:2013 Unplasticized polyvinyl chloride (PVC-U) pipes for soil and waste discharge system for inside and््outside buildings including ventilation and rain water system - Specification
67 IS 13593:1992 Specification for UPVC pipe fittings to be used with the UPVC pipes in the suction and delivery lines of agricultural pumps
68 IS 13916:1994 Code of practice for installation of glass fibre reinforced plastic (GRP) piping system
69 IS 14333:1996 High density polyethylene pipes for sewerage - Specification
70 IS 14402:1996 Specification for GRP pipes, joints and fittings for use for sewerage, industrial waste and water (other than potable)
71 IS 14735:1999 Unplasticized polyvinyl chloride (UPVC) injection moulded fittings for soil and waste discharge system for inside and outside buildings including ventilation and rain water system - Specification.
72 IS 14787:2000 Unplasticized PVC pipes (ducts) and fittings for underground telecommunications cable installation - Specification
73 IS 14885:2001 Specification for polyethylene pipe for supply of gaseous fuel
74 IS 15265:2003 Flexible PVC pipes polymer reinforced thermoplastic hoses for suction and delivery lines of agricultural pumps - Specification
75 IS 15328:2003 Unplasticized non-pressure polyvinyl chloride (PVC-U) pipes for use in underground drainage and sewerage system - Specification
76 IS 15450:2004 Specification for polyethylene/aluminium/polyethylene composite pressure pipes for hot and cold water supplies
77 IS 15778:2007 Chlorinated polyvinyl chloride (CPVC) pipes for potable hot and cold water distribution supplies - Specification
78 IS 15801:2008 Polypropylene-random copolymer pipes for hot and cold water supplies - Specification
79 IS 15927(Part 1):2012 Specification for polyethylene fittings for use with polyethylene pipes for the supply of gaseous fuels: Part 1 Fittings for sockets using heated tools
80 IS 15927(Part 2):2012 Specification for polyethylene fittings for use with polyethylene pipes for the supply of gaseous fuels: Part 2 Spigot fittings for butt fusion jointing or socket fusion using heated tools, spigot fittings for use with electro-fusion fittings
81 IS 15927(Part 3):2011 Specification for polyethylene fittings for use with polyethylene pipes for the supply of gaseous fuels: Part 3 Electro-fusion fittings
82 IS 16098(Part 1):2013 Structured - Wall Plastics Piping Systems for Non- Pressure Drainage and Sewerage - Specification Part 1: Pipes and Fittings with Smooth External Surface, Type A
83 IS 16098(Part 2):2013 Structured - Wall Plastics Piping Systems for Non- Pressure Drainage and Sewerage - Specification Part 2: Pipes and Fittings with Non-Smooth External Surface, Type B
84् IS 16130:2014 Thermoplastics Materials for Pipes and Fittings for Pressure Applications – Classification and Designation – Overall Service (Design) Coefficient (Adoption of ISO 12162)
85 SP 57: 1993 Handbook for pipes and fittings for drinking water supply
CED 51 PLANNING, HOUSING AND PREFABRICATED CONSTRUCTION
STANDARDS PUBLISHED
1 IS 962:1989 Code of practice for architectural and building drawings
2 IS 1553:1989 Design of library buildings - Recommendations relating to its primary elements (second revision)
3 IS 2661:1978 Specification for mobile library van (first revision)
4 IS 2662:1978 Specification for packages for use of libraries (first revision)
5 IS 2663:1989 Design of buildings for archives - Recommendations relating to its primary elements (second revision)
6 IS 3201:1988 Criteria for design and construction of precast-trusses and purlins (first revision)
7 IS 4878:1986 Byelaws for construction of cinema buildings (first revision)
8 IS 4919:1981 Glossary of terms applicable to landscape and horticulture work
9 IS 4993:1983 Glossary of terms relating to modular co-ordination
10 IS 5197:1987 Recommendations for layout and planning of drawings offices
11 IS 6072:1971 Specification for autoclaved reinforced cellular concrete wall slabs
12 IS 6073:2006 Specification for autoclaved reinforced cellular concrete floor and roof slabs (first revision)
13 IS 6408(Part 1):1990 Recommendations for modular co-ordination in building industry: Tolerances Part 1 Glossary of terms (first revision)
14 IS 6408(Part 2):1992 Recommendations for modular co-ordination in building industry: Tolerances Part 2 Principles and applications
15 IS 6820:1987 Recommendations for modular co-ordination in building industry: Applications (first revision)
16 IS 7564(Part 1):1974 Recommendations for co-ordination of dimensions in buildings-Arrangements of building components and assemblies: Part 1 Functional group 1 - Structures
17 IS 7564(Part 2):1974 Recommendations for co-ordination of dimensions in buildings-Arrangements of buildings components and assemblies Part 2 Functional group 2 - External envelope
18 IS 7564(Part 3):1974 Recommendations for co-ordination of dimensions in buildings-Arrangements of building components and assemblies: Part 3 Functional group 3 Internal subdivision
19 IS 7564(Part 4):1975 Recommendations for co-ordination of dimensions in buildings-Arrangements of building components and assemblies: Part 4 Functional group 4 Services and drainage
20 IS 7564(Part 5):1975 Recommendations for co-ordination of dimensions in buildings-Arrangements of building components and assemblies: Part 5 Functional group 5 Fixtures, furniture and equipment
21 IS 7921:1987 Recommendations for modular co-ordination in building industry : Horizontal co-ordination (first revision)
22 IS 7922:1987 Recommendations for modular co-ordination in building industry: Vertical co-ordination (first revision)
23 IS 7973:1976 Code of practice for architectural and building working
24 IS 8338:1976 Recommendations relating to primary elements in the design of school library buildings
25 IS 8888(Part 1):1993 Guide for requirements of low income housing: Part 1 Urban area (first revision)
26 IS 10297:1982 Code of practice for design and construction of floors and roofs using precast reinforced/prestressed concrete ribbed or cored slab unit
27 IS 10316:1986 Recommendations for modular co-ordination - basic module and sub-modular increments (Equivalent to ISO 1006:1973 and
28 IS 10505:1983 Code of practice for construction of floors and roofs using precast concrete waffle units
29 IS 10600:1983 Recommendations for modular co-ordination - principles and rules
30 IS 11447:1985 Code of practice for construction with large panel prefabricates
31 IS 11775:1986 Recommendations for modular co-ordination: notations and symbols for modular drawings
32 IS 12073:1987 Recommendations for modular co-ordination: Co-ordinating sizes for door-sets and window-sets
33 IS 13612(Part 1):1993 Modular co-ordination for normal brickwork - Recommendation: Part 1 Burnt clay bricks
34 IS 13613:1992 Recommendations for modular co-ordination in building industry: Location of structural walls and floor slabs
35 IS 13727:1993 Guide for requirements of cluster planning for housing
36 IS 13990:1994 Specification for precast reinforced concrete planks and joists for flooring and roofing
37 IS 13994:1994 Code of practice for design and construction of floor and roof with precast reinforced concrete planks and RC joist
38 IS 14142:1994 Code of practice for design and construction of floors and roofs with prefabricated brick panel
39 IS 14143:1994 Specification for prefabricated brick panel and partially precast concrete joist for flooring and roofing
40 IS 14201:1994 Specification for precast reinforced concrete channel unit for construction of floors and roofs
41 IS 14213:1994 Code or practice for construction of walls using precast concrete stone masonry blocks
42 IS 14215:1994 Code of practice for design and construction of floors and roofs with precast reinforced concrete channel units
43 IS 14241:1995 Specification for precast reinforced concrete L-panel for roofing
44 IS 14242:1995 Code of practice for design and construction of roof with L- Panel units
45 IS 15916:2010 Building design and erection using prefabricated concrete - Code of practice
46 IS 15917:2010 Building design and erection using mixed/composite construction - Code of practice
CED 53 CEMENT MATRIX PRODUCTS
STANDARDS PUBLISHED
1 IS 458:2003 Precast concrete pipes (with and without reinforcement) - Specification (fourth revision)
2 IS 459:1992 Specification for unreinforced corrugated and semi-corrugated asbestos cement sheets (third revision)
3 IS 783:1985 Code of practice for laying of concrete pipes (first revision)
4 IS 784:2001 Specification for prestressed concrete pipes (including specials)
5 IS 785:1998 Specification for reinforced concrete poles for overhead power and telecommunication lines (second revision)
6 IS 1332:1986 Specification for precast reinforced concrete street lighting poles (first revision)
7 IS 1592:2003 Specification for asbestos cement pressure pipes and joints
8 IS 1626(Part 1):1994 Specification for asbestos cement building pipes and pipe fittings, gutters and gutter fittings and roofing fittings Part 1 Pipe and pipe fittings (second revision)
9 IS 1626(Part 2):1994 Specification for asbestos cement building pipes and pipe fittings, gutters and gutter fittings and roofing fittings Part 2 Gutter and gutter fittings (second revision))
10 IS 1626(Part 3):1994 Specification for asbestos cement building pipes and pipe fittings, gutters and gutter fittings and roofing fittings: Part 3 Roofing fitting
11 IS 1678:1998 Specification for prestressed concrete poles for overhead power, traction and telecommunication lines (second revision)
12 IS 1916:1989 Specification for steel cylinder pipe with concrete lining and coating (first revision)
13 IS 2096:1992 Specification for asbestos cement flat sheets (first revision)
14 IS 2098:1997 Specification for asbestos cement building boards (first revision)
15 IS 2174:1962 Specification for reinforced concrete dust bins
16 IS 2185(Part 1):2005 Specification for concrete masonry units: Part 1 Hollow and solid concrete blocks (third revision)
17 IS 2185(Part 2):1983 Specification for concrete masonry units: Part 2 Hollow and solid light weight concrete blocks (first revision) (superseding IS 3590)
18 IS 2185(Part 3):1984 Specification for concrete masonry units Part 3 Autoclaved cellular Aerated concrete blocks (first revision) (Superseding IS 5482)
19 IS 2185(Part 4):2008 Concrete masonry units - Specification: Cellular concrete blocks using preformed foam
20 IS 2193:1986 Specification for precast prestressed concrete street lighting poles (first revision)
21 IS 2572:2005 Code of practice for construction of hollow and solid concrete block masonry (first revision)
22 IS 2905:1989 Methods of test for concrete poles for overhead power and telecommunication lines (first revision)
23 IS 3007(Part 1):1999 Code of practice for laying of asbestos cement sheets: Part 1 Corrugated sheets(first revision)
24 IS 3007(Part 2):1999 Code of practice for laying of asbestos cement sheets: Part 2 Semi-corrugated sheets (first revision)
25 IS 3597:1998 Methods of test for concrete pipes (second revision)
26 IS 3632:1969 Method of test for determination of wet volume of asbestos
27 IS 4350:1967 Specification for concrete porous pipes for under-drainage
28 IS 4844:1968 Method of sampling and preparation of asbestos fibre for laboratory test purposes
29 IS 4996:1984 Specification for reinforced concrete fence posts (first revision)
30 IS 5328:1969 Method of test for determination of chemical composition of asbestos fibre
31 IS 5748:1969 Methods of test for tensile strength of asbestos fibre
32 IS 5751:1984 Specification for precast concrete coping blocks (first revision)
33 IS 5758:1984 Specification for precast concrete kerbs channels, edgings, quadrants and gutter aprons (first revision)
34 IS 5820:1970 Specification for precast concrete cable cover
35 IS 5913:2003 Methods of test for asbestos cement products (second revision)
36 IS 6041:1985 Code of practice for construction of autoclaved cellular concrete block masonry (first revision)
37 IS 6042:1969 Code of practice for construction of lightweight concrete block masonry
38 IS 6441(Part 1):1972 Methods of test for autoclaved cellular concrete products: Part 1 Determination of unit weight or bulk density and moisture
39 IS 6441(Part 2):1972 Methods of test for autoclaved cellular concrete products: Part 2 Determination of drying shrinkage
40 IS 6441(Part 4):1972 Methods of test for autoclaved cellular concrete products: Part 4 Corrosion protection of steel reinforcement in autoclaved cellular concrete
4 IS 6441(Part 5):1972 Methods of test for autoclaved cellular concrete products: Part 5 Determination of compressive strength
42 IS 6441(Part 6):1973 Methods of test for autoclaved cellular concrete products: Part 6 Strength, deformation and cracking of flexural members subjects to bending, short duration loading test
43 IS 6441(Part 7):1973 Methods of test for autoclaved cellular concrete products: Part 7 Strength, deformation and cracking of flexural members subject to bending sustained loading test
44 IS 6441(Part 8):1973 Methods of test for autoclaved cellular concrete products: Part 8 Loading tests for flexural members in diagonal tension
45 IS 6441(Part 9):1973 Methods of test for autoclaved cellular concrete products: Part 9 Jointing of autoclaved cellular concrete elements
46 IS 6523:1983 Specification for precast reinforced concrete door and window frames (first revision)
47 IS 6530:1972 Code of practice for laying of asbestos cement pressure pipes
48 IS 6908:1991 Specification for asbestos cement pipes and fittings for sewerage and drainage(first revision)
49 IS 7319:1974 Specification for perforated concrete pipes
50 IS 7321:1974 Code of practice for selection, handling and erection of concrete poles for overhead power and telecommunication
51 IS 7322:1985 Specification for specials for steel cylinder reinforced concrete pipes (first revision)
52 IS 7639:1975 Methods of sampling of asbestos cement products
53 IS 8870:1978 Specification for asbestos cement cable conduits and troughs
54 IS 9375:1979 Specification for precast reinforced concrete plant guards
55 IS 9627:1980 Specification for asbestos cement pressure pipes (light duty)
56 IS 9690:1980 Method of test for determination of openness or fibrization of chrysotile asbestos fibre by air permeability method using Dyckerhoff apparatus
57 IS 9691:1980 Method of test for length distribution (wet classification of fibrelength) of chrysotile asbestos fibre using Bauer Mcnett classifier
58 IS 9745:1981 Method for determining strength giving properties of asbestos
59 IS 9872:1981 Specification for precast concrete septic tanks
60 IS 9893:1981 Specification for precast concrete lintels and sills
61 IS 11267:1985 Method of test for length distribution (wet classification of fibre length) of chrysotile asbestos fibre using Turner and Newall classifier
62 IS 11275:1985 Method of test for determination of crudiness and grit content of asbestos fibre
63 IS 11276:1985 Method of test for determination of openness or fiberization of chrysotile asbestos fibre by air permeability method using rapid surface area apparatus
64 IS 11450:2006 Method for determination of airborne asbestos fibre concentration in work environment by light microscopy (membrane filter method) (first revision)
65 IS 11451:1986 Recommendations for safety and health requirements relating to occupational exposure to asbestos
66 IS 11707:1986 Glossary of terms relating to asbestos
67 IS 11767:2005 Recommendations for cleaning of premises and plants using asbestos fibres (first revision)
68 IS 11768:1986 Recommendations for disposal of asbestos waste material
69 IS 11769(Part 1):1987 Guidelines for safe use of products containing asbestos: Part 1 Asbestos cement products
70 IS 11769(Part 2):2005 Guidelines for safe use of products containing asbestos: Part 2 Friction materials (first revision)
71 IS 11769(Part 3):1986 Guidelines for safe use of products containing asbestos: Part 3 Non-cement asbestos products other than friction materials
72 IS 11770(Part 1):1987 Recommendations for control of emission of asbestos dust in premises manufacturing products containing asbestos: Part 1 Asbestos cement products
73 IS 11770(Part 2):2006 Recommendations for control of emission of asbestos dust in premises manufacturing products containing asbestos: Part 2 Friction materials (first revision)
74 IS 11770(Part 3):1987 Recommendations for control of emission of asbestos dust in premises manufacturing products containing asbestos: Part 3 Non-cement asbestos products other than friction materials
75 IS 12078:1987 Recommendations for personal protection of workers engaged in handling asbestos
76 IS 12079:1987 Recommendations for packaging, transport and storage of asbestos
77 IS 12080:1987 Recommendations for local exhaust ventilation systems in premises manufacturing products containing asbestos
78 IS 12081(Part 1):1987 Recommendations for pictorial warning signs and precautionary notices for asbestos and products containing asbestos: Part 1 Workplaces
79 IS 12081(Part 2):1987 Recommendations for pictorial warning signs and precautionary notices for asbestos and products containing asbestos: Part 2 Asbestos and its products
80 IS 12082(Part 1):2006 Recommendations for control of asbestos emission: Part 1 Mining of asbestos ore (first revision)
81 IS 12082(Part 2):2006 Recommendations for control of asbestos emission: Part 2 Miling of asbestos ore (first revision)
82 IS 12440:1988 Specification for precast concrete stone masonry blocks
83 IS 12592:2002 Specification for precast concrete manhole covers and frames
84 IS 13000:1990 Specification for silica asbestos cement flat sheets
85 IS 13008:1990 Specification for shallow corrugated asbestos cement sheets
86 IS 13158:1991 Specification for prestressed concrete circular spun poles for overhead power, traction and telecommunication lines
87 IS 13356:1992 Specification for precast ferrocement water tanks (Up to 10000 litres capacity)
88 IS 14862:2000 Specification for fibre cement flat sheets
89 IS 14871:2000 Specification for products in fibre reinforced cement - long corrugated or asymmetrical section sheets and fittings for roofing and cladding
90 IS 15155:2002 Specification for bar/wire wrapped steel cylinder pipes with mortar lining and coating (including specials)
CED 54 CONCRETE REINFORCEMENT
STANDARDS PUBLISHED
1 IS 432(Part 1):1982 Specification for mild steel and medium tensile steel bars and hard-drawn steel wire for concrete reinforcement: Part 1 Mild steel and medium tensile steel bars (third revision)
2 IS 432(Part 2):1982 Specification for mild steel and medium tensile steel bars and hard-drawn steel wire for concrete reinforcement: Part 2 Hard- drawn steel wire (third revision)
3 IS 1566:1982 Specification for hard-drawn steel wire fabric for concrete reinforcement (second revision)
4 IS 1785(Part 1):1983 Specification for plain hard-drawn steel wire for prestressed concrete: Part 1 Cold-drawn stress relieved wire (second revision)
5 IS 1785(Part 2):1983 Specification for plain hard-drawn steel wire for prestressed concrete: Part 2 As drawn wire (first revision)
6 IS 1786:2008 High strength deformed steel bars and wires for concrete reinforcement - Specification (fourth revision) (superseding IS 1139:1966)
7 IS 2090:1983 Specification for high tensile steel bars used in prestressed concrete (first revision)
8 IS 6003:2010 Specification for indented wire for prestressed concrete (second revision)
9 IS 6006:1983 Specification for uncoated stress relieved strand for prestressed concrete (first revision)
10 IS 9417:1989 Welding - cold-worked steel bars for reinforced concrete construction recommendations for welding (First Revision)
11 IS 10790(Part 1):1984 Methods of sampling of steel for prestressed and reinforced concrete: Part 1 Prestressing steel
12 IS 10790(Part 2):1984 Methods of sampling of steel for prestressed and reinforced concrete: Part 2 Reinforcing steel
13 IS 13620:1993 Fusion bonded epoxy coated reinforcing bars - Specification
14 IS 14268:1995 Uncoated stress relieved low relaxation seven ply strand for prestressed concrete - Specification
CED 55 SIEVES, SIEVING AND OTHER SIZING METHODS
STANDARDS PUBLISHED
1 IS 460(Part 1):1985 Specification for test sieves: Part I Wire cloth test sieves
2 IS 460(Part 2):1985 Specification for test sieves: Part II Perforated plate test sieves
3 IS 460(Part 3):1985 Specification for test sieves: Part III Methods of examination of apertures of test sieves (third revision)
4 IS 1568:1970 Specification for wire cloth for general purposes (first revision)
5 IS 1607:2013 Methods for test sieving (second revision)
6 IS 2405(Part 1):1980 Specification for industrial sieves: Part 1 Wire cloth sieves
7 IS 2405(Part 2):1980 Specification for industrial sieves: Part 2 Perforated plates
8 IS 3150:1982 Specification for hexagonal wire netting for general purposes
9 IS 4124:1981 Glossary of terms relating to powders (first revision)
10 IS 4879:1968 Method of sub-division of gross sample of powder used for determination of particle size
11 IS 4961:1968 Determination of particle size of powders by air elutriatioin
12 IS 5257:1969 Specification for eyepiece and screen graticule for determination of particle size of powders
13 IS 5258:1969 Determination of particle size of powders by optical microscope method
14 IS 5282:1969 Liquid sedimentation methods for determination of particle size of powders
15 IS 5421:2013 Glossary of terms relating to test sieves and test sieving
16 IS 5742(Part 1):1970 Terms and symbols for sieve bottoms: Part 1 Woven and welded wire screens
17 IS 5742(Part 2):1970 Terms and symbols for sieve bottoms: Part 2 Perforated plates
18 IS 10483:1983 Code for designating perforations of industrial plate sieves
CED 56 HILL AREA DEVELOPMENT ENGINEERING
STANDARDS PUBLISHED
1 IS 14458(Part 1):1998 Retaining wall for hill area - Guidelines: Part 1 Selection of type of wall
2 IS 14458(Part 2):1997 Retaining wall for hill area - Guidelines: Part 2 Design of retaining/breast walls
3 IS 14458(Part 3):1998 Retaining wall for hill area - Guidelines: Part 3 Construction of dry stone walls
4 IS 14496(Part 2):1998 Preparation of landslide hazard zonation maps in mountainous terrains - Guidelines: Part 2 Macro-zonation
5 IS 14680:1999 Landslide control - Guidelines
6 IS 14804:2000 Siting design and selection of materials for residential buildings in hilly areas - Guidelines
7 IS 14961:2001 Rainwater harvesting in hilly areas by roof water collection system – Guidelines
CED 57 CYCLONE RESISTANT STRUCTURES
STANDARDS PUBLISHED
1 IS 15498:2004 Guidelines for improving the cyclonic resistance of low rise houses and other buildings/structures
2 IS 15499:2004 Guidelines for survey of housing and building typology in cyclone prone areas for assessment of vulnerability of regions and post cyclone damage estimation
Water Leak Detection and Insulation Solutions for Homes and Buildings​
Water leak detection and waterproofing and thermal insulation services are essential for home and building maintenance. Neglecting these services can lead to significant damage, such as moisture buildup, mold growth, and wall deterioration. By relying on the best insulation companies and water leak detection companies, you can minimize these risks and extend the lifespan of your property. In this article, we will explore leak detection and insulation services and the importance of choosing experienced and specialized companies.
The Importance of Water Leak Detection and Repair​
A water leak detection company is a great solution for preventing damage caused by water leaks. These companies provide specialized leak detection services using advanced devices such as the water leak detection device, which identifies leaks without the need to break walls or floors.
Water Leak Detection Devices​
The leak detection device is highly accurate in pinpointing the source of leaks. It uses acoustic or thermal technology to detect escaping water. This device is a vital tool for leak detection companies, helping save time, effort, and costs.
Water Leak Inspection and Repair Services​
The water leak inspection process is carried out by expert technicians who accurately determine the type and location of the leak. Once the issue is identified, water leak repair services come into play, using high-quality materials to prevent leaks and provide long-term protection. Choosing an experienced water leak repair company ensures reliable and lasting results.
Types of Insulation Services: Waterproofing and Thermal Insulation​
Roof Waterproofing Company​
Roof waterproofing aims to protect buildings from the harmful effects of rain, especially during winter. A roof waterproofing company provides high-quality insulation materials that prevent water from seeping into the structure, ensuring durability.
Roof Waterproofing Services​
These specialized services help protect structures from water damage, which can cause concrete erosion and cracks. Waterproofing is a crucial solution for long-term structural protection.
Best Roof Insulation Company​
When looking for the best roof insulation company, it’s essential to choose one with extensive experience and high-quality materials to ensure long-term protection.
This article provides an overview of water leak detection and insulation solutions, highlighting their importance and the best companies that offer these services.
