By:
By:
Advanced…
    New posts Search forums
What's new
By:
By:
Advanced…
  • Search forums
  • LOUNGE
  • MCQ Questions
  • Reinforced Concrete - MCQ
For M 150 grade concrete (1:2:4) the moment of resistance factor is
  • Thread starter Thread starter Srinivasan
  • Start date Start date Jan 30, 2018
Srinivasan
Srinivasan
Prime CE
mumbai
  • Jan 30, 2018
(A) 0.87
(B) 8.50
(C) 7.50
(D) 5.80
The correct Answer Is
(B) 8.50
S
SKK
Active Member
Delhi
  • Nov 30, 2019
  • #2
Answer is option (A) 0.87.............................
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Jun 6, 2019
Ayuba
Ayuba
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 8, 2018
Feb 8, 2018
Srinivasan
Srinivasan
