How many cubic meters are on one ton of GSB?
It all depend on the properties of material and at what level you are looking at it like compacted or bulk density.
Best way is to measure this property by own by filling the material in metallic cylinder or box of known volume and calculating its weight.
Weight / Volume will give you the density of material in Kg per cum or in Kg per Cft as per your measurement standards.
Then as per that volume you can calculate its weight in place.
