i want to know shuttering cost to be considered per sq.ft.
What may be the shuttering material cost to be considerd per sq.ft.
e.g. We have 1 slab area of 8600 sq.ft. , and total building area is 1,20,000 sq.ft.
Considering all materials like ply , jack props , chavi , patti , sikanja , acrow span , etc.
e.g. if say 12,00,000 total cost to be spent on shuttering including supporting, staging , etc , then it will come to be 10rs / sq.ft.
like this whats approximate shuttering material cost.
Please guide...
Dear Umesh,
The shuttering cost of the total project usually varies and depends on the following factors.
1. What kind of material.? (Ply board or MS or PVC or Moving)
2. What will be typical structure.? If all floors are typical then there will be no making again and again and the material required and wastage will be less.
3. How many repetitions they using shuttering material.?
These are the major factors which can effect the shuttering cost.
As per the site inputs and based on different type of projects the cost required is as follows.
Labour required- ₹40/sft on SBA
Material required-₹140/sft on SBA
Shuttering material required-2.7sft/sft on SBA
The above values are averaged by using all kind of projects
I hope it will helps your quiery.
Thanks
Sudhakar reddy
Dear Umesh,
Thanks
Sudhakar reddy
Sir is SBA super built up area? If yes than please provide rate into built up area if possible
Dear Umesh,
Thanks
Sudhakar reddy
SIR,ITS IS VERY USEFUL .YOU WERE MENTIONED METERIAL REQUIRED 140/SQ FT. CAN YOU EXPLAIN WHAT ARE THE ITEMS WILL COME UNDER THE MATERIAL CATAGORY?
