If the atmospheric pressure on the surface of an oil tank (sp. gr. 0.8) is 0.2 kg/cm", the pressure at a depth of 50 m below the oil surface will be
(a) 2 meters of water column
(b) 3 meters of water column
(c) 5 meters of water column
(d) 6 meters of water Column
(e) 7 meters of water column.
The correct Answer Is
Reactions: Sumit Civil
dhilip
6 m of water level
