Project Planning and Monitoring Tool
This tool assists in organizing and monitoring project work. By using the task planning section, project milestones and tasks can accurately be planned out. Once the project begins, real-time progress is tracked and the project is monitored against the set baselines.
Alternatively, information entered in Microsoft Project can be copied and pasted into this tool to take advantage of its reporting capabilities. A simple copy and paste will work, however there is some preparation needed:
Enclosed herewith the detailed excl sheet which will help you to understand the project schedule
  • Project_Scheduling_and_Monitoring_Tool.xls.xlsx
ISMAIL407ER
Apprentice
nice work ..thanks for providing such usefull things,
can u anyone provide details sample working of this drawing as using this sheet will be understood if some one or @
archdevil provides sample working sheet
amd007
Elite Member
Its seems to be a good project planning and monitoring tool, however the explanations are not enough to work on it.
I tried using one of my existing schedules however it does not work.
Can you demonstrate with an example with current dates at dates in it are of 2009
very useful for monitoring project schedule day to day,
we are just to start industrial project, is there any key tools to monitor smoothly and reporting to superiors day to day.
Herramienta de planificación y seguimiento de proyectos
Esta herramienta ayuda a organizar y monitorear el trabajo del proyecto. Mediante el uso de la sección de planificación de tareas, los hitos y las tareas del proyecto se pueden planificar con precisión. Una vez que comienza el proyecto, se realiza un seguimiento del progreso en tiempo real y se supervisa el proyecto con respecto a las líneas de base establecidas.
Alternativamente, la información ingresada en Microsoft Project se puede copiar y pegar en esta herramienta para aprovechar sus capacidades de generación de informes. Un simple copiar y pegar funcionará, sin embargo, se necesita algo de preparación:
Se adjunta a la presente la hoja de exclusión detallada que le ayudará a comprender el cronograma del proyecto
Buenisimo!!! agregue la curva S y quedo perfecto.
