Spreadsheet to Design One Way Solid Slab
Sumit Civil
Well-Known Member
The solid slab called One way slab when the aspect ratio for each panel is greater or equal to two: 2.0
The slab is therefore supported by the beams which are supported by columns or by girders.
Analysis and design of 1-m slab strip is then performed in the main direction and the design results are generalized allover the slab.
Minimum shrinkage (temperature) steel is provided in the other direction. The slab strip model is a continuous beam where the supports are beams.
Coefficient method of analysis is used if its conditions are satisfied.
Standard flexural RC design methods are used to determine the required reinforcement.
with this excel sheet you will easily design one way slab with given data of dimension and concrete materials.
One Way Slab Reinforcement Details Design​
One Way Slab Reinforcement Details Design is most important because most of the slab of a residential building or industrial building is design as a one-way slab because it owns advantages
The calculation of One Way Slab Reinforcement Details Design is extremely tedious and time-consuming and after give more time is not 100% sure that design is best or not and also if some minor change comes in design if force to calculate full design step again and again
So I provide you a platform by which you can calculate One Way Slab Reinforcement Details Design with 100% accuracy and in some second by using try and error method for best economical design with all safety
In excel sheet I cover point like
Effective Span
Load Calculation
B.M. Calculation
Effective Depth for flexure
Main steel
Distribution Steel
Check for cracking
Check for Deflection
Check for development
Check for shear
So you can easily design the best structural and economical design of One Way Slab Reinforcement Details Design
Download
Reactions: Rakesh Patel
