Sumit Civil Well-Known Member India Dec 17, 2017 #1 Attached design excel sheets will help you in designing of column. Design excel sheets are here below. Attachments Bi-Axial Column.xlsx Bi-Axial Column.xlsx 31.7 KB · Views: 879 Column Design Steel Check.xlsx Column Design Steel Check.xlsx 47 KB · Views: 829 Column Design.xlsx Column Design.xlsx 43.4 KB · Views: 967 Reactions: vinayvjs, mandy and Omarbhati
MAR Founder Member Hyderabad Feb 19, 2018 #2 Sumit Chaudhary said: Attached design excel sheets will help you in designing of column. Design excel sheets are here below. Click to expand... Thanks for sharing this file
T Tejas Jain Senior Member Mumbai Apr 18, 2018 #3 Thank you so much for design excel sheet which are necessary for structural designer.
