Tell me the values of testing the strength of concrete?
Strength of the concrete is determined by testing the concrete cube under cube testing machine.
The strength of the concrete can be calculated upon testing by Load taken by cube before failure divided by Surface area of the cube.
Normally cube testing machines applies loads in Kn per Sec, the unit of measuring of the strength is N per mm[SUP]2 [/SUP], so you need to convert or measure the data in those units or as per your measuring system.
