  • LOUNGE
  • MCQ Questions
  • Surveying - MCQ
The angle between the reflection surfaces of a prism square is -
  • Thread starter Thread starter Dnyan Deshmukh
  • Start date Start date Jan 18, 2018
Pune
  • Jan 18, 2018
(a) 30 degrees
(b) 45 degrees
(c) 60 degrees
(d) 75 degrees.
The correct Answer Is
(b) 45 degrees
Reactions: Sumit Civil
The principle of tachometry is used -
  • Dnyan Deshmukh
  • Jan 18, 2018
Jan 18, 2018
A branch of surveying in which the horizontal and vertical distances of points are obtained by instrumental observation, is known as -
  • Dnyan Deshmukh
  • Jan 18, 2018
Jan 18, 2018
A curve of varying radius is known as -
  • Dnyan Deshmukh
  • Jan 18, 2018
Aug 7, 2019
Dolo Iddrissa
Dolo Iddrissa
The length of peg interval for flat curves is -
  • Dnyan Deshmukh
  • Jan 18, 2018
Jan 18, 2018
The method of surveying in which field work and plotting work are done simultaneously, is called -
  • Dnyan Deshmukh
  • Jan 18, 2018
Jul 3, 2018
Jaskaran Singh
J
