  • LOUNGE
  • MCQ Questions
  • Reinforced Concrete - MCQ
The maximum diameter of a bar used in a ribbed slab, is
  • Thread starter Thread starter Srinivasan
  • Start date Start date Feb 4, 2018
Srinivasan
Srinivasan
Prime CE
mumbai
  • Feb 4, 2018
(A) 12 mm
(B) 6 mm
(C) 20 mm
(D) 22 mm
The correct Answer Is
(D) 22 mm
M
Mahender
Hyderabad
  • Feb 4, 2018
  • #2
12
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Jun 6, 2019
Ayuba
Ayuba
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 8, 2018
Feb 8, 2018
Srinivasan
Srinivasan
