  • LOUNGE
  • MCQ Questions
  • Reinforced Concrete - MCQ
The modular ratio m of a concrete whose permissible compressive stress is C, may be obtained from the equation.
  • Thread starter Thread starter Srinivasan
  • Start date Start date Jan 30, 2018
Srinivasan
Srinivasan
Prime CE
mumbai
  • Jan 30, 2018
from the equation.
(A) m = 700/3C
(B) m = 1400/3C
(C) m = 2800/3C
(D) m = 3500/3C
The correct Answer Is
(C) m = 2800/3C
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Jun 6, 2019
Ayuba
Ayuba
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 8, 2018
Feb 8, 2018
Srinivasan
Srinivasan
