By:
By:
Advanced…
    New posts Search forums
What's new
By:
By:
Advanced…
  • Search forums
  • LOUNGE
  • MCQ Questions
  • Reinforced Concrete - MCQ
The pitch of the main bars in a simply supported slab, should not exceed its effective depth by
  • Thread starter Thread starter Srinivasan
  • Start date Start date Jan 30, 2018
Srinivasan
Srinivasan
Prime CE
mumbai
  • Jan 30, 2018
(A) Three times
(B) Four times
(C) Five times
(D) Six times
The correct Answer Is
(D) Six times
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Jun 6, 2019
Ayuba
Ayuba
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 8, 2018
Feb 8, 2018
Srinivasan
Srinivasan
