By:
By:
Advanced…
    New posts Search forums
What's new
By:
By:
Advanced…
  • Search forums
  • LOUNGE
  • MCQ Questions
  • Reinforced Concrete - MCQ
The ratio of the breadth to effective depth of a beam is kept
  • Thread starter Thread starter Srinivasan
  • Start date Start date Feb 4, 2018
Srinivasan
Srinivasan
Prime CE
mumbai
  • Feb 4, 2018
(A) 0.25
(B) 0.50
(C) 0.70
(D) 0.75
The correct Answer Is
(B) 0.50
S
SKK
Active Member
Delhi
  • Nov 30, 2019
  • #2
Answer is option (B) 0.50...........................
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Jun 6, 2019
Ayuba
Ayuba
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 8, 2018
Feb 8, 2018
Srinivasan
Srinivasan
