Types of Painting and Polishing along with technical specifications
Paint preserves, protects and decorates surfaces and enables them to be cleaned easily.
Types of paints:
There are seven types of paints, used commonly are :
Oil paints
These are the traditions type having a linseed oil medium. Finishes vary from flat to oil-gloss. Oil paints dry by evaporation of the solvent and by oxidation, synthetic paints have replaced them.
Synthetic paint
The medium for these is a chemical compound, one type being oil-modified alkyd resin. They have the advantage over oil paints in setting more quickly and offering greater durability where corrosion is a main concern. They also have better flow and are easier to apply.
Water paints
Known also as distempers they are used mainly on internal walls and ceilings and most of them give a flat finish. They have a drying oil or varnish medium emulsified in water. They are prepared on the site by adding water to make a paste. Emulsion paint has super ceded water paint.
Emulsion Paints
These are mostly used on wall surfaces. Oil bound distemper is a type of emulsion paint. An emulsion paint has the pigments and medium dispersed as small globules in water. Oil, synthetic resin and bitumen are the common mediums. Among different emulsion paints are alkyd, bitumen, polyvinyl acetate and styrene emulsion paints. The finish obtained is flat to egg shell gloss.
Cellulose Paints
They are mostly used as spray paints in car industry because they dry very quickly by evaporation of solvents. They are not satisfactory for general building work but can be used for furniture and fittings in houses.
Special paints
Among the many kinds are aluminum paints, bituminous paints, chlorinated rubber paints, fire-resistant paints, heat-resisting paints, fungicidal paints, texture paints etc., These are used for special applications and manufacturer’s instructions should be followed for thinning and applications of the required number of coats.
Specifications for painting New Surfaces
Types of finishPrimer coatUnder coatFinishing
White wash​
1 coat of white wash​
2 coats​
Color wash​
1 coat of color wash​
2 coats​
Dry distemper​
Clear Cole, size, etc​
Filler to be used if required​
2 coats​
Oil bound distemper​
1 coat of alkali resistant cement Primer​
2 coats​
Emulsion paint​
1 coat of emulsion paint​
2 coats​
Flat/ semi gloss paint​
1 coat of alkali resistant cement primer​
2 coats​
Acrylic emulsion​
2 coats​
Cement paint​
1 coat of cement paint​
Nil​
2 coats​
Spreading Capacity of Different Paints for internal finishing
Type of finishCovering capacity (New work)
Lime for white washing​
33-34 m2 / quintal for 3 coats​
Plastic emulsion paints on primed and puttied smooth surfaces by brushing​
30-35 m2 / lt/coat
19-20 m2/ lt for 2 coats
13-14 m2/ lt for 3 coats​
Washable oil bound distemper, spreading by brushing​
20-25 m2/ kg per coat
12-15 m2/ kg per 2 coats
7-8 m2/ kg for 3 coats​
Cement primer​
20-25 m2/ lit coat​
Spreading Capacity of Different Paints for Exterior wall finishes
Acrylic emulsion paints​
5.5-6.0 m2/lit for 2 coats​
Cement paints​
2 to 4 m2 /kg for 2 coats for Cement-sand plaster, depends on its texture​
Metal/ Wood finishes​
Synthetic enamel paint​
15-22 m2/ lit /coat
10-12 m2/lit for 2 coats​
Aluminum paint (dual pack)​
20-22 m2/lit / coat​
Metal primer​
18-20 m2/ lit /coat​
Wood Primer​
Clear Wood Finishes​
Copal varnish​
10-13 m2/ lit /coat​
French polish (ready mixed)​
12-15 m2/ lit /coat​
Melamanised finishes​
8-10 m2/ lit /coat by brushing
5-6 m2/ lit /coat by spraying​
Poly urethane clear wood finish by brushing​
8-10 m2/ lit /coat​
Sealer​
8-10 m2/ lit /coat by brushing​
Measurements: Equivalent Plain Areas of Uneven surface
Description of workHow measuredMultiplying co-efficient
Paneled or framed and braced doors, window, etc​
Measured flat$​
1.3 (each side)​
Flush doors​
Measured flat$​
1.2 (each side)​
Part paneled and part glazed or gauzed doors, windows, etc.​
Measured flat$​
1.0 (each side)​
Fully glazed or gauzed doors, windows etc​
Measured flat$​
0.8 (each side)​
Fully venetioned or louvered doors, windows etc​
Measured flat$​
1.8 (each side)​
Trellis(or jaffri) work one way or two way​
Measured flat#​
2 for painting all over​
Carved or enriched work​
Measured flat​
2 (each side)​
Wood shingle roofing measured flat​
1.0 (each side)​
Boarding with cover fillets and match boarding​
Measured flat​
1.05(each side)​
Tiles &slate battering​
Measured flat#​
0.8 for painting all over​
Steel work, doors, windows etc​
Plain sheet steel doors &windows​
Measured flat​
1.1 (each side)​
Fully glazed or gauzed steel doors and windows*​
Measured flat​
0.5 (each side)​
Partly paneled and partly glazed or gauzed doors and windows​
Measured flat​
0.8 (each side)​
Corrugated sheet steel doors and windows​
Measured flat​
1.25 (each side)​
Collapsible gate measured flat​
Measured flat​
1.5 for painting all over​
Rolling shutters of interlocked laths​
Measured flat​
1.1 (each side)​
Expanded metal , grill work, MS bars in window frame, railing, palisade fencing, balustrade gates inc, standards, braces, stays etc in timber or steel​
Measured flat#​
1(for paint all over)​
CGI sheathing in roof, side cladding etc.​
Measured flat (not girthed)​
1.14 (each side)​
AC corrugated sheeting in roofs, side cladding, etc​
1.2 (each side)​
Wire gauze shutters including painting of wire gauge​
1.0 (each side)​
Notes
Measured flat ( Not girthed) including chowkat or frame, edges, chocks, cleats etc shall be deemed to be included in the item.
# - No deduction for open spaces, supporting members shall not be measured separately.
* - Excludes painting of wire gauge portion
Reactions: ashukhandelwal
