What are causes of white spot on plaster surface?
Using water of high TDS at the time of curing results in these type of patches, some time it has been also observed that there is no skirting on floor and if floor washed and water remains there so due to capillary action up to 5 feet height these patches comes. Before using bricks to be cure in low TDS water.
Reactions: kanagavel murugan
What are the Main Causes of White Spots on Plaster Surface? Explain According to your Practically Experience
WHITE SPOTS ON PLASTER SURFACE REPAIR BY KALMATRON® KF-G
KF-G liquid spray will stop efflorescence. After KF-G treatment, paint, stucco, etc can be applied and there won't be any leaching.
It can work on the concrete surface plastered with mortar?
KF-G works on concrete as well as mortar (stucco, plaster) surfaces to heal shrinkage cracks and crazing.
If the surface is painted does is it necessary that paint is to removed before application?
Paint removal is not necessary in most cases. It's important that the concrete or stucco is washed and cleaned of any loose materials before KF-G application and that the surface is moist and well-soaked with water. This prevents any loss of the KF-G solution through absorption by dry capillaries in the concrete.
YES IT IS ! With KF-G liquid as a spray or KF-G powder form in a slurry.
http://www.kalmatron.com/files/Files1/KF-G/KF-G_SLURRY_PREPARATION.pdf
adKF-G
Iron oxide based pigment will work the best. The visual pigmentation effect of KF-G will be similar to that produced by the usual surface stainining techniques, but liquid impermeability and abrasion and corrosion resistance will be increased.
Visit us at
www.kalmatron.com
http://www.kalmatron.com/KALMATRON_LINE_CARD.pd
"Strength of Concrete. Strength is the most valuable property in the concrete because it is directly related to the structure of cement paste."
It's called efflorescence, It does not directly affect but creates salt crystals which are water soluble and later voids are created. The best way to get rid is prevention from chlorides when mixing water in the ingredients do check the chlorides level.
They also appear on Concrete surface if curing water is high in chloride(for Ex: NaCl, MgCl, etc...) content
