What is Difference between alcofine and microsilica
What are the properties of alcofine and microsilica. Which are better for higher Grade of concrete above M60 Grades and Which admixture gives higher performance for high grade of concrete.
Reactions: Er.Deepak Kumar
See we should not go by name of the product to compare because it will only increase the confusion level.
You can ask its manufacturer, what material it is and is manufactured / packed as per which standard code.
according to me Micro silica and alocfine is the same material, there may be difference in particle size as name suggesting its ultra fine powder.
