After the construction of watermain, prior to hydrostatic pressure test, swabbing is carried out. What is the purpose of swabbing?
Answer: Pipelines should be tested before commissioning to check the strength of watermain and the absence of leak. Before carrying out hydrostatic pressure test, swabbing is conducted to clear out rubbish and dirt left inside the pipeline during construction. Swabbing is required for pipes less than 600mm diameter because for larger size of pipes, they can be inspected internally to ensure cleanliness.
After carrying out of hydrostatic pressure test, test for water sterilization is then conducted which involves collecting water sample from the pipeline. The purpose is to check the water quality like colour, turbidity, odour, pH value, conductivity etc. and is compared with the quality of water drawn from water supply point.
