What is the tallest structure that can built on the Earth by humans and why?
Thank you sir, but once I listened that limit is 8848m which is equal to height of the Mt.Everest. So, I raised this question to know weather it is whisper or truth?
As you may know new Tallest tower is under construction in Dubai which is scheduled to built by 2020 ,is more than 1Km high....So Height of stucture depends upon the Design and ground condition....
The height also depends on the charactoristic of material used to built structure.
This is the main limit because once material fails to take load of superstructure it will fall dawn.
As you go high the other factors make more attacks on structure like wind pressure and earth vibration.
As we go high and high the design parameters are changed according to conditions at that level.
We can build as high as mount everest or may be beyond this provided humans get enough oxygen level.
Difficulties are more and forces are different beyond certain heights.
