What is the Use of HOLDFAST in construction usage?
Holdfast is a member which project from the body of door or window frame which holds the window or door frame in walls.
Holdfasts are useful when the window and door frames are installed in place at the time of brickwork or blockwork, as those holdfast need to be anchored in wall.
If we do a brickwork or blockwork first by keeping opening for doors and windows in wall. we can fix the frame in position with the help of anchor fasteners which work same as a hold fast.
Reactions: Papa
