When a portal frame with equal leg heights is subjected to an unequal rise in temperature, the sway of the frame
(a) Towards the column under lower temperature
(b) Towards the column under higher temperature
(c) Towards the larger area columns
(d) Away from the larger area of the column.
The correct Answer Is
