Work Checklist - Aluminium Shuttering Works (Mivan Formwork)
Now a Days Aluminium formwork is very popular due to its light weight, durability and finish it gives to concrete surface.
This checklist provides a check points to engineer to ensure correct execution of work and avoid reworks.
Its very difficult having repairs later and cost huge and may cause losses to owner if not executed properly.
Checklist for Aluminium Formwork consist of following checkpoints in it;
  • Deviation report for survey record (kicker level)
  • Dimension of room checked as per drawing
  • Diagonal check done for room
  • All formwork has been cleaned and coated with release agent
  • Flat wall ties installed with proper tie sleeves
  • Verticality checked for external as well as internal wall
  • Check all pins and wedges
  • Check verticality of all props
  • Check outer tie for external beam and sunk portion
  • Slab soffit formwork level
  • Door spacer installed as per drawing issued
  • Vertical soldiers installed as per drawing
  • All kicker level have been lined and adjusted accordingly
  • All kicker bolts installed correctly
  • All excessive spaces between rocker and floor level have been sealed
Sample Checklist for Aluminium Formwork is attached herewith.
  • C4M Aluminium Shuttering Works - Mivan Formwork.docx
